Case Mod - In Progress Project Extreme Lian Li II (Part 2)
Discussion in 'Project Logs' started by Ediejo, 30 Mar 2007.
  1. Ediejo
    Ediejo What's a Dremel?
    31 Jul 2005
    Gift from Lian Li at the Cebit.............. Thanks Lian Li.
    Sponsors
    [​IMG] [​IMG] [​IMG]
    This will be the Extreme Lian Li II
    Phase change and water cooling will come in the case. :thumb:
  2. G69T
    G69T CNC Modder
    6 Jun 2004
    WOW a new casemod! :rock:
  3. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    What a beauty!
    Whats the price on the case?
  4. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    I've never seen that Lian Li before! :O
  5. lamboman
    lamboman What's a Dremel?
    25 Jul 2006
    Jealous, is me!
  6. KayinBlack
    KayinBlack Unrepentant Savage
    2 Jul 2004
    Big fan of previous work, what's the theme for this one?
  7. Pre_Tender
    Pre_Tender What's a Dremel?
    8 Oct 2006
    looks promising :thumb:
    i've never seen that case of lian li :confused:
    is it a new model?
    and... what's the theme going to be ?
  8. Fod
    Fod what is the cheesecake?
    26 Aug 2004
    dude! what model lian li is that? i may have to make it mine!
  9. Ediejo
    31 Jul 2005
    It is a new model. The continuator from de G-70. So far as I know it is not in production now. Only the midi towerPC-7S
    Theme from the case. Extreme. Same as the Extreme Lian Li. But than the cooling in the case.
  10. eegg
    eegg What's a Dremel?
    29 Aug 2006
    the hdd holders don't look good
  11. Guest-23315
    Guest-23315 Guest
    ooh...
    Now less talk, more work!
  12. Ediejo
    31 Jul 2005
    I take the hdd holders out so no problem. ;)
    The case is also in development. So I think Lian Li will change that. :dremel:
  13. Faried112
    Faried112 What's a Dremel?
    15 Jan 2007
    Go go go go go go go
  14. Axel
    Axel What's a Dremel?
    20 Feb 2007
    Nice case,is that 12cm fan in the back?
  15. GoTaLL
    GoTaLL What's a Dremel?
    17 May 2005
    sweet .. :)
  16. RonaldoR9
    RonaldoR9 What's a Dremel?
    17 Dec 2006
    sweet case it looks like they have already made the mid tower version of that case on thier site
    i just wish they would make an all black one also then i might consider it =)
    BTW when do u plan on starting this project
    cuz im looking forward to seeing this mod, specially at the speed you modded your other lian li
    MOD ON!!! :clap:
  17. Evenge
    Evenge Minimodder
    16 Sep 2006
    Cool... :cooldude:
  18. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    It's always nice to see a good modded lian li, and because it's you I know it will be good :D
  19. Ediejo
    31 Jul 2005
    Before I can start with the Extreme Lian Li 2 I have to dismantle the first one.
    After one hourers it looks like this..
    And 2 hours later like this.
    I need to clean the water cooling parts. But this is the place for the 2 tanks.
    Also remove the hard disk bay. It’s a nice place for the dual radiator.
    I have to fix a little thing than it fits.
    Now let’s see where I put the power supply and the 2 pumps.
    It’s a big case so I can change something.
    But to much empty space at the top part.
    This looks better. Where the hard disk bay sits. There will come an air tunnel to the top of the case.
    The power supply must go upstairs because the phase change.
    This times not a feet but wheels under the case.
    See you soon.
  20. ComputerKing
    8 Sep 2006
    JUST OMG OMG OMG :wallbash:
    I WANT your skills :waah:
