Case Mod - In Progress Project Extreme Lian Li II (Part 2)
Discussion in 'Project Logs' started by Ediejo, 30 Mar 2007.
  1. Ediejo
    Ediejo What's a Dremel?
    31 Jul 2005
    @ComputerKing, it’s just a hobby. But I try to do my best. I cannot live from casemodding so I must still work for my money. :duh:
    Today starting with a big vile and sanding job.
    That’s fit.
    Some drawing for the part I must saw.
    This is not so hard to saw.
    But this is really exciting to saw so close to the edge.
    Last part of it I will do it with file and sanding paper.
    Remove a part from the case and place the Plexiglas on his place. It fits nice with the side panel.
    The left side looks terrible but it’s so close to the edge to saw. So I keep that part for the file and the sanding paper. When I saw it so close to the edge, I think it will break when I do some work at it.
    See you soon.
  2. ComputerKing
    8 Sep 2006
    HAHAH This is my Lucky day! all Nice updates on it ;) I really Love it, Your work is amazing!!!!!! You doing very well :)
    hey you not gonna cut that little part at the end of the Pexil! or it will be useble on the other part ;)
    Also I don't know if it the photo or my eye or some thing! you can see that place for the mobo I\O on the left it's kinda not in one line! I don't know ( It sux, You said that but it make it look sux ) don't know what happen with you
    Well done
  3. Ediejo
    31 Jul 2005
    Today I started with the file job. It’s a job that takes some time. I must be careful. It’s small and Plexiglas
    This is not so hard.
    This part will be exiting. I do it step by step. Maximum peace of Plexiglas between 2 grips 5 cm. File that part. Move the grips and do the same again.
    And not broken. :rock:
    Also for the other parts that I must file. I use the iron (Dutch name angle line) When I hit the iron with the file. It’s ready. ;)
    Some close up photos.
    Next part for tomorrow. ;)
  4. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    looking good as allways ediejo:thumb:
  5. ComputerKing
    8 Sep 2006
    That's is slick! It's perfect cut! well done. I don't know how it happned, it was sux then some sanding and it's shiny ;)
    I love the work
  6. theAlien
    theAlien I know what a Dremel is....
    20 Aug 2007
    looking very good......I love the mirror polished finish of the PSU bracket....that piece alone is just beautiful....:thumb:
    Alan
  7. Ediejo
    31 Jul 2005
    @x06jsp, thanks.
    @ComputerKing, ;)
    @theAlien, there will be more aluminum that’s like the PSU bracket.
    And continue with the file job from the backside.
    First lock up the Plexiglas again.
    Almost nothing to see but I am try to file here.
    And straight.
    Next part. ;)
    First part done. Only the fan hole to go.
    But that’s for tomorrow.
  8. IanJackson
    IanJackson Photographer & Modder
    22 Mar 2007
    cant wait for the finished product!!! keep it up!!!:thumb:
  9. THEkorean
    THEkorean 42
    10 Jun 2005
    wow! nice work, what kind of scroll saw blade are you using there?? is it spiral bit, what TPI is it? haha sorry about all the questions, I'm just frustrated cause i cant figure out what kind of blades to buy for my saw so i can cut plexi like that
  10. theAlien
    20 Aug 2007
    aahh.........more SEXY stuff to follow....... [​IMG] can't wait to see it....
    Alan
  11. arkadur
    arkadur What's a Dremel?
    3 May 2005
    very nice work on the Plexiglas !
  12. ComputerKing
    8 Sep 2006
    Nice work budy, Very nice it worth what you doing! now it's kinda perfect, you fixed it very well!
  13. Ediejo
    31 Jul 2005
    And continue with the fanhole.
    The worst part is coming..
    When there is 2 mm of aluminum behind the Plexiglas it’s much.
    And now way to use the iron to clasp it.
    I keep it a little bigger. I think when I make it smaller it breaks.
    Use sanding paper for the edges and I like t this way.
    It starts to look something.
    Next part same story but this time aluminum.
    Drawing the contours from the plexi on the aluminum.
    And sawing the aluminum.
    Still some file and sanding work to do.
    And polishing but that’s for next week. ;)
    It will be a worse job to put some led’s in the small plexi but I try it.
    See you soon.
  14. Guest-23315
    Guest-23315 Guest
    That looks very nice indeed.
  15. x06jsp
    2 Apr 2007
    looking awesome as usual!
  16. Ediejo
    31 Jul 2005
    I use these blades.
    The 28 740 for the Plexiglas.
    The 28 744 for aluminum
    The 28 106 also for aluminum very fine saw.
  17. tranc3
    tranc3 ADHD Modder
    16 Jul 2007
    wow. thats beautiful.. how hard would you say cutting aluminum is? and were did you order it from?
  18. Ediejo
    31 Jul 2005
    @trance3, it’s easy to saw that aluminum. I buy the saws here at the local store just around the corner from me. Only for you to far away. Check the site from proxxon and you will found a store close to you.
    Some more file work to do.
    This time I do not using the iron with the file job.
    That aluminum from AC-Ryan is very good to handle.
    First part done.
    But enough to do.
    I like t.
    At last the long small peace.
    Sanding and polishing is for tomorrow.
    See you soon.
  19. x06jsp
    2 Apr 2007
    looking great as per usuall.
  20. widmod
    widmod Minimodder
    9 Oct 2006
    stunning work
    :jawdrop: :jawdrop: as always
