Case Mod - In Progress Project Extreme Lian Li II (Part 2)
Discussion in 'Project Logs' started by Ediejo, 30 Mar 2007.
  1. exitus
    exitus What's a Dremel?
    25 Apr 2007
    who needs 1100 Watts? Isn't that a little too overkill?
    very nice work with the case, though :)
  2. Ediejo
    Ediejo What's a Dremel?
    31 Jul 2005
    @G69T, TAGAN is a very stabile psu. In the first ELL 2 x480 watt TAGAN. ;)
    @ exitus, yes and no about the overkill. The prometeia needs power. The lighting. The casefans. And over clocking takes also some extra power. And it’s stabile that’s the important part from OC.
    And continue with the front. I make some plexi to mount the 2 reservoirs.
    I need the edges from the original front. So I can place the reservoirs exactly in the center.
    I use the standard mounting plates only for drawing.
    Dan saw the plexi.
    Filing and sanding.
    That’s fit well.
    Almost the same as the plexi from the front. But this is to hide the plexi for a part.
    Again filing.
    Also the small holes.
    The black anodized will be removed. And it will be polishing.
    See you soon.
  3. Kylevdm
    Kylevdm The Mod Zoo Podcast Host
    4 Oct 2007
    looking great i loved your old case :p
    the original was what got me interested in modding
    keep up the good work
  4. Guest-23315
    Guest-23315 Guest
    Very nice work..!
    No DVD Drive?
  5. Ediejo
    31 Jul 2005
    @Kylevdm, I love it also, but it was too big and too heavy. That’s nice to hear that the original get you interested to modding. :rock:
    @Mankz, you are the first one who asks about the DVD dive. :clap:
    Your right no DVD drive in that part. :confused:
  6. Stievius
    Stievius Industrial Design Student
    12 Nov 2006
    You're up to something! ^^
  7. Kylevdm
    4 Oct 2007
    it will be in one of the one of the hundreds :p of other levels he sticks on :D
  8. Ediejo
    31 Jul 2005
    @Stievius, popup dvd rom in de top panel. That means it comes straight out the top. (vertical) :dremel:
  9. E.E.L. Ambiense
    E.E.L. Ambiense Acrylic Heretic
    26 Jul 2007
    Somehow I already knew that, Ediejo. Why is that? ;) Perhaps it's all the past ideas you've come up with on your other mods. Man, this is lookin' nice.
  10. Fishlock
    Fishlock .o0o.
    22 Nov 2004
    Very high level of construction and detail to your work there, top stuff!
  11. Darkened
    Darkened What's a Dremel?
    28 Feb 2004
    Why isn't there 5 stars on this project already?
    Always great to see your work Ediejo, looking forward to seeing this one finished.
    Darkened
  12. razzta010
    razzta010 mod addict
    9 Aug 2007
    Finally I have some time to come back to bit tech ... and enjoy your work mate! awesome work!!!
    Just a question: do the Novus products really work so well for cleaning /removing scratches from plexi? you buy them over here in europe?
    will keep an eye on this project till finished :)
  13. Evenge
    Evenge Minimodder
    16 Sep 2006
    I haven't given any? Naughty me! :duh:
    Your work is indeed spectacular Ediejo, waiting to see more magic! :thumb:
  14. Ediejo
    31 Jul 2005
    At this moment I work very hard on the Benelux Casemod League. that is a casemod compo in the Netherlands. And I do some organization for that event. At the moment priority 1 for me. Updates will come but later.
  15. Marco André
    Marco André Shipwrecked Lian Li
    3 May 2007
    Looks really good! Amazing work mate! :rock:
  16. Asulc
    Asulc Minimodder
    18 Jul 2007
    I am loving the case. You guys work wonders with computers. I want updates!
  17. Kylevdm
    4 Oct 2007
    lol
    so do we all and everyone has priorities and the second extreme isn't one at moment.
    but mod on!!!!!!!!!
  18. Ediejo
    31 Jul 2005
    Updates will be coming after gameplay.
    Next week we have the final from the Benelux Casemod League at gameplay.
    Last year at gameplay 32.000 visitors in 3 days. :jawdrop:
    The biggest game-event from the Benelux. :thumb:
    So at this moment the organization from it takes all my free time. But after gameplay the will be updates . ;)
  19. Kylevdm
    4 Oct 2007
    have fun!
  20. Ediejo
    31 Jul 2005
    After a long time an update.
    Polishing the front plate for the reservoirs.
    I change to real chrome. When you hit the aluminum there is a scratch on.
    Also make a start for the place for the DVD rom.
    It will come in the top of the case.
    There is still enough place for the tubes.
    The aluminum part for the psu will change for big one. That takes the whole top part. I need that so that I can make the power connector exactly above the connector on the mainbaord.
    Also looking for a place for the pump. I thought it’s a good place somewhere in the middle of the case. But it will not fix with the graphic cards. The line for the tubes where good in my eyes.
    So the place for the pump will be at the bottom from the case. It’s also possible to give the tubes a straight line. But the there must be come something to hold them straight. That’s for later.
    At the bottom there is also place for the hard disks. This is not the part that I will use for it. It’s only to look of it fits with the main board.
    The place is big enough. It fits with the high from the main board. Only the hard disk bay is too small. There is a big empty place behind it.
    This time no water cooled hard disks. I only use the water cooling for the 3 graphic cards.
    I gone make a custom hard disk bay. Bigger than this one with place for 2 x 80 mm fans for the airflow.
    See you soon.
