After the idée from Payne280 to start a project log. At these a project log from the Extreme Lian Li. I have worked 2 years on this case (about 600 hours) The end result Update 1 Update 2 Update 3 Update 4 Update 5 Update 6 Update 7 Update 8 Update 9 Update 10 The beginning Chroming several hardware housing Polish parts of the Lian Li. The first result On this pic you can see some watering plate sheet. That covered the complete case before. After I have seen the marvellous casemod the Orac3 I had the solution for the cable sleeve. To do in the next updates: Chance the cable sleeve it is to long done Case front modding done Mirror mod on the bottom form the case done Building and rebuilding the water-cooling part 95% Rebuilding the prometeia mach gt2 20 % Soon more. Here you can say what you think about it.
No thnx i update the project log tomorrow. It's now to late, i go to sleep soon. Have a lot of work to do tomorrow.
Update 1 I make the cable sleeve a bit shorter. Looks better in my eyes. Meanwhile there is also water-cooling for the Lian Li the Koolance Exos very nice but a bit to small for the pc 70 from lian li, It is appropriate, at the pc. 60. So I try to rebuild this thing. I can do a lot but chance the Exos so it fit on the pc 70 I can forget. So I start to make the first water-cooling part. It is big much too big. But this is the idée Making the front for the reservoirs. Making the top plate. 2 eheim 1048 for 2 loops. Meanwhile I sunk the drive bays in the front of the case. Because I sunk the drive bays I must also sunk the reservoirs from the water cooling. How I did it? I glow it. Soon more. Here you can say what you think about it.
Update 2 # 23-12-2005 And directly update 2 More from the water cooling part. I use the same sleeve for the water tubes. Because I carry out of tulles I just had this solution. Tubes outside. A close up from the top n the dark. More tubes outside. I chance the look from the back plates with a poster. Than also remove the last part watering plate I see what troop in the cools water block. Directly cleaning the system. And polish the blocks. Also some new memory that’s adapted to the casemod. At this moment I starting with the mirror mod that is something that I introduced in the Dutch casemod community. And directly the first problem the cable sleeve covertly the mirror mod. Making the side panel for the water cooling part. In the same style as the Lian Li. Also I chance the headstock nails from the side panel from the Lian Li. Soon more. Here you can say what you think about it.
Update 3 I had some troubles with some part from the water-cooling. for these connections I have waited weeks. problems with the supply. Now i can connect the water cooling. For the mirror mod I must chance the cable sleeve again. For the green light I just dismantled 2 ccfl’s. and place them under the mirror. Then I make the coo lwater red. The front……… yes it is a big case. Connecting the power for the ccfl’s and case fans. One plug for al the power from the water cooling. And glue it. At this moment A.P Versteeg a famous Casemodder from the Nederland’s contacted me for showing my system at a big event in the Nederland’s the HCCDagen2004 The first solution for the water tubes. The transport box. Soon more. Here you can say what you think about it.
Update 4 During the HCCDagen I met Point Of View a graphic cards company from the Nederland’s. And their want the Lian Li for the Cebit 2005 in Hannover. But this hardware is old school for the Cebit. So chance the hardware! The graphic cards Point of View 6800GT A Prometeia Mach GT2 The first ting to do polish the Cool blocks from Innovatek. Starting with the polishing. For polishing I use this. The result. For protection and for the finishing touch. And than it is like a mirror. The blocks on the cards. Soon more. Here you can say what you think.
Update 5 To make it an extreme machine……… A Prometeia Mach GT But it is to short for the pc 70 series from Lian Li. So I make it just as long as the pc 70 The 2 Power supplies Bon Chic (2 x 420 Watt) The first test run. The last thing to do for the Cebit 2005. Make the Logo from XCS on the side panel from the Prometeia. Also chance the mirror for the prometeia and make the Point of View logo on the mirror. Now you can see the logo on the water cooling block. And ready for transport to the Cebit 2005-12-24 First day on the Cebit 2005 everybody is working hard to finch The place for the case. Look the people from NVIDIA smiling when the see the look from the ATI people And back home I have to work travelling three times to Hanover during the Cebit. Soon more. Here you can say what you think.
I make a cut so that i can open it with a screwdriver. The correct bit tool to open it is from innovatek. At that moment I not have then. Now i have then. Thnx Innovatek.
