Case Mod - In Progress Project: Fallout Terminal, Completed 24-5-08
Discussion in 'Project Logs' started by W-fault, 27 Apr 2008.
  1. W-fault
    W-fault Otherwise known as widefault
    16 Mar 2008
    Okay, the name isn't a reference to anything in particular, but a description that somehow sounds cooler than it may be. It's going to be a basic Linux system that hooks into a terminal server, and it's being housed in a surplus US Civil Defense CDV-715 Radiation Fallout Meter. Despite what many think, this model is not a geiger counter. Its made for use after the nukes fall and to read the level of fallout. Basically, if you need to use one of these you're probably going to die pretty soon. For the collector types, I only use damaged or broken meters for my projects. I won't pay the price for a working one, and have managed to build up a nice stash of bad ones.
    First off, if this seems familiar, you may have seen a few of the other mods I've done using these meters. For the past few years I've been modding them into USB, firewire, and now eSATA 3.5" hard drive enclosures. Most have gone to friends and family, but there are a few extras that have made it into the wild.
    I've also built two PCs in these cases using embedded 3.5" boards. One is a Pentium-M 1.8GHz, the other a Via C3@667MHz. Never really used either of them, the Pentium-M was too loud and the C3 had power issues. Well, I stole the PSU from it for another project so it's been boxed up until I get around to wiring it back together. I still have both, and while they'd work fine for what I'm doing, I'd rather have a much lower power system built for the purpose.
    Anyway, on to the hardware...
    For this project, I'll be using another embedded 3.5" form factor motherboard. This time it will be an Advantech PCM-5825. This uses a NationalSemi GeodeGX1 CPU@300MHz. Performance is equivalent to a PentiumMMX@~200MHz. It's descended from the old Cyrix MediaGX and is a kind of half-breed 486/586 core with onboard audio and video that rely heavily on the CPU. It's weak, but for what I'm doing it should be fine. It helps that this CPU(now owned by AMD) is used by Wyse in a lot of their Winterm models, so I know it will work for a terminal setup. There are updated versions of the CPU/chipset that increase clockspeed and add DDR support as well as more USB and even SATA on some versions. The base core is still the same.
    So it's a poor performer, why would I use it? This board, running from a 45 watt PSU, pulls between 6-7 watts idling in the BIOS and requires about zero effort for cooling.
    And a quick word on the 3.5" embedded form factor, since someone will ask eventually. The board size is 105mm x 145mm, same as a 3.5" hard drive. They're available with CPUs ranging from the 386 up to 800MHz bus mobile Core 2 Duos@2.6GHz. I've also seen them using xScale and other non-x86 CPUs, and recently saw there'll be one based on the Intel Atom. I like the form factor a lot, but they're hard to find and not cheap unless you buy used. Oh yeah, there's also an identically sized embedded form factor called ECX which is backed by Intel. Only real difference is ECX has a "standardized" PCI-e/USB/PCI expansion bus and most E3.5 use PC/104, PCI/104, and/or mini-PCI.
    And finally, pics of the victims.
    The board.
    Bottom. Currently only have 128MB of ram, need to get it running and see if I need more. I also plan on running the whole works of a compact flash card. I've got a few different ones to play with, hopefully the board will play nice.
    The unmolested case.
    The guts.
    Guts removed. I'll be cutting the "legs" off for clearance.
    The gauge will show drive activity even though there won't be much when it's being used on the terminal server.
    And I've started my layout for the ports.
    For the ports, I have a method that works pretty well. Consists of a drill, an old slot bracket, files, and a lot of arm motion. The big issue will be keeping things lined up. Get one port finished, then start another, constantly checking alignment. Consider there are 7 holes on this one, and I've got a challenge.
    I'm also going to have to find cables for USB and audio as well as plan how I'm going to power the unit. It will run off a single 5 volt source, but the standard power mode is AT. It does have an ATX mode, but it's designed to be run with a real ATX PSU. I could use a PicoPSU and custom cables, but that's more money to spend and more chance of complications. I'd like to get the ATX mode working, but it's not really that big a deal if I can't. With 7 watts power use I could just leave it running all the time.
  2. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    this is very interesting, shame you are not using a pico itx.
  3. Cheapskate
    13 May 2007
    I like the future case. This should be fun, I just hope you never need to go through an airport terminal with it.
  4. W-fault
    16 Mar 2008
    I'm not a big fan of PicoITX, too many extra cables to get full functionality. They also cost more than what I paid for this board, so that's what really made the decision for me.
    Cheapskate, I had started building a CarPC using one of these cases, but eventually abandoned the idea when I changed vehicles. One of my big concerns there was how the police would react if I got pulled over. I imagine that would have been a giant pain in the ass to explain.
  5. W-fault
    16 Mar 2008
    And a little update for today.
    First up, a pictorial of how I do ports.
    Step one, after layout, drill two holes, then using screws and nuts affix the serial port slot bracket to the case to be cut.
    Step two, drill a bunch of holes to remove material.
    Step three, file like a madman using the slot bracket as a guide. The case is aluminum and the bracket is steel, so using a light touch means the files won't dig into the steel once you hit the edge and you should get a very nice port.
    Step four, ogle your well shaped port.
    About an hour and a half later, I had both VGA and serial openings complete as well as ones for the network jack and LEDs, and on the far right the hole for the reset button.
    I still need to do the opening for the PS/2 port, then start wiring up the USB and audio cables. Power will be last, have some things to test in regards to the ATX mode.
    I'm contemplating adding a USB hub since the board only has two ports, but with the onboard only being USB1.1 it's sort of pointless. I'll save that for the next one I build. Yes, there'll be another one being done when I finish this. I've got another Via C3 board that will be the basis for a system to run a 10 year old guitar MIDI interface.
  6. W-fault
    16 Mar 2008
    Little pic of how well the 3.5" embedded form factor fits into these cases. Snug, but lots of room on the ends for passing cables between the top of the board and bottom of the case.
    Got the PS/2 port done but no pics yet. Also stuck on some rubber feet I had left over from a HD case build. This one doesn't really need them as it won't have a fan on the bottom, but there will be some holes put in for airflow.
    Right now I'm waiting for USB and audio cables. Found a set of the original cables, which will make things much easier since the board uses a narrower pitch on the pin headers than a standard board. The USB cable will be unmodified, but I'll have to change the audio cable to use different jacks.
    I've decided I'm not going to bother with ATX mode for power, I'll save that for the next one. Much easier wiring and it lets me get this done a bit quicker.
    And one of these days I have to work on the wiring for the gauge.
  7. JJ McTiss
    JJ McTiss What's a Dremel?
    2 May 2008
    nice idea :clap:
  8. Squadexodus
    Squadexodus I got my cookie. What about you?
    5 Jan 2008
    Scratch it on the way down did we?
  9. Macros_the_Black
    Macros_the_Black Yup.. I'm a f-ing reptile
    7 Jul 2007
    Great job on the port holes. Seems like you pay a lot attention to detail and are inventive.. this log should be great fun to follow! Keep it up! =D
  10. Cheapskate
    13 May 2007
    The inside looks rough. I'd sand it down and polish it.:D (I'm crazy like that...)
  11. W-fault
    16 Mar 2008
    The scratches on the interior are a result of deburring the inside of the ports after drilling and filing. I'm not too concerned about that, hopefully once I have everything inside I'll never have to open it back up.
    I've considered polishing the outside of one of these cases, but I don't have the patience to do it properly. I may paint one of the spare cases I have that's in bad condition, but that's a project for another day.
    Got my USB and audio cables today. Going to get the USB ports done tonight or tomorrow, then I'll start messing with the audio cables. I'm actually stealing an audio cable from another board, then swapping part of the cable onto the socket from the cable set for this board. The other board is another Geode board that was deemed "meh" due to a poor layout. It'll eventually get used for something, and then I'll have to make another audio cable for that one. Or I'll sell it and let the next guy worry about it. Would be a lot easier if they used standard pitch pin headers.
    And pics, because I took some.
    The bag of cables
    what I'm actually using
    And a shot showing the PS/2 port and rubber feet
    And if anyone wonders, that's a sheet of ~2mm orange UV-proof plastic as a work surface. I got it when I bought an LCD; the seller used it to protect the screen in shipment. Fits perfectly inside of a drawer on my desk and is at the perfect height for working on projects while sitting in my computer chair.
  12. MrWizard
    MrWizard What's a Dremel?
    5 Feb 2008
    Something a little different for a change, I like it :thumb:
  13. Stonewall78
    Stonewall78 What's a Dremel?
    21 Oct 2005
    Watch the edges of the PCB against the metal. Multilayer boards and short out like that and kill the board. I like the idea though it should look pretty neat when done.
  14. W-fault
    16 Mar 2008
    Shorting isn't an issue so far. There's a good 3mm gap on the back side, and the video and serial ports hold the board away from the casing by a very slight amount. Plus the board itself doesn't have much near the edge of the board by the ports, mostly ground plane.
    And one new pic, got the USB ports 99% done. Need to pull things apart and fine tune things a tiny bit
    Now I need to make a trip for parts, so I probably won't have any new pics or updates until this weekend. I need to pick up some stereo jacks for the audio and I want to see what I can find for a power switch. I have a toggle in my parts box, but it's a bit larger than what I wanted. I'd love to find a rotary switch that will fit the spot where the original power switch was, but so far they're all too large.
  15. W-fault
    16 Mar 2008
    Got a little more done today. Got up, ate something, then took a run to Radio Shack to spend too much for parts that I didn't feel like ordering online. I'll get to some of those in a few.
    First, need to back to some earlier shots of the top of the case. If you look here, you can kind of see the raised sections where the original power/level select knob and the zeroing knobs were.
    A few better pics of those areas.
    Had to take about a half hour today to clean that up for some other components to fit, as well as cut the legs off for better clearance. Here's a few new pics to see what has been done.
    Hmmm, what's in those spots now? That big one looks like a switch, but what's the second? Maybe a few more pics will help.
    Yep, managed to find a rotary switch to use for power, and put a power jack into the area where the zero knob was. Wasn't really what I wanted, but for ease of wiring it was better to put the power jack on the same part the switch was on. If not, I would have ended up with more wiring to stick into the case as well as tied them all together. Wouldn't be simple to even get it together if the jack was on the lower part.
    Started cutting and placing wires, soldering will be done tomorrow when I also deal with these.
    Line in and out only, maybe I'll throw on a jack for the mic. Interesting thing, the board also has powered, albeit very low power, speaker out headers. Not going to use them, but I was tempted to put a pair of RCA outs onto the case for those.
  16. Yemerich
    Yemerich I can has PERSUADETRON?
    15 Sep 2004
    First time i saw this Thread, i thought it was going to be a Fallout (the game) mod. Now i realized this is from a fallout counter... hmmmm
    Wouldn't be nice to mix them both? After all a third game is on the way for this year. ZI would love to see a Pip Boy-like mod :)
    Cheers for the idea anyway :)
  17. W-fault
    16 Mar 2008
    Ya know, I wondered if people would make that assumption when I put the name down. I'll leave the game related version for someone who actually does game. Closest I come is solitaire, and that's pretty rare these days.
    Little bit of an update here. Didn't get around to soldering things until tonight, and only got the power and power LED done, but happily everything is working. I'm actually using a 5 volt, 2.1amp wall wart for power right now. This thing uses so little power it's creepy. I'll have to move up to a larger one for the software install, my USB CD drive uses almost as much power as the full system.
    And pics...
    First, the semi complete wiring for the top half. Still need to get the wiring done for the meter. Power molex goes to the board, and I need to add headers for the HD activity to the board where it used to have an HD activity LED.
    And power hooked up, off.
    And power hooked up, on.
    And power hooked up, on, flash off.
  18. Langer
    Langer Jesse Lang
    24 Jan 2004
    Great mod... love it.
    Have you considered somehow making the meter move?
    perhaps with HDD activity.
  19. MrWizard
    5 Feb 2008
    That would be sweet.
  20. Thacrudd
    Thacrudd Where's the any key?!?
    27 Oct 2006
    :read::read::read::read:
