Project Fibonacci Sequence
Discussion in 'Project Logs' started by Pfaffen, 5 Jun 2007.
  1. Pfaffen
    Pfaffen What's a Dremel?
    18 Mar 2007
    Here are some other shots.
  2. Hugo.B
    Hugo.B What's a Dremel?
    4 May 2007
    Thank-you very much, the previous picture puts it into perspective, and gives me a better idea of it's size.
    It is good to see the reasoning behind asterisk-type symbol.
    The whole project looks decidedly at home in it's surroundings.
    Hugo.B
  3. derbaum
    derbaum What's a Dremel?
    11 Apr 2004
    the golden faces are a bit 2 much in my opinion but the small stripes in the woods just look kickass. independet from personal questions of taste a great case.
  4. Pfaffen
    18 Mar 2007
    Hugo.B,
    You are quite welcome and thank you. The over all dimensions are 10in sq by 16in high.
  5. Pfaffen
    18 Mar 2007
    derbaum,
    Thank you very much, your case is also extremely impressive. I've watched its progress intently.
  6. Pfaffen
    18 Mar 2007
    s_q_u_e_e,
    Thank you very much. It is a bitter sweet ending. I like to be finished, but now I find myself day-dreaming about my next mod. I'm toying with a 8-12in waterfall, or a theme mod. Not sure what yet.
  7. Fused
    Fused Minimodder
    19 Jun 2007
    A waterfall? now that seems interesting I would definately like to see where that idea takes you.
    Overall a well stealthed case youve got here, it fits in perfectly. And that is one huge screen (completely dwarfs my 26" tv :( )
    Good case well done :thumb:
  8. greensabbath
    greensabbath Got Wood?
    19 Apr 2005
    Hey Pfaffen, this turned out very nicely. I especially like the gold in the slots. What happened to the corner joints though, especially the ones on top? They look a bit loose.
  9. Pfaffen
    18 Mar 2007
    GreenSabbath,
    Thank you very much. The gold in the slots turned out better than I thought they would. They actually, make the case have some depth and character.
    WRT to the corners, those did not turn out the way I wanted. :grr: The half lap joints with a mortice and tenon, just did not like all the abuse I put them through. Since I haven't used any glue in the process, making the joints fit exactly has been a challenge. I need them to be tight enough to hold everything together, yet loose enough to be able to pull the pieces apart.
    The mortice for the stiles in the top rails are just not deep enough to sit properly, I'll have to go back and re-work those...
    Anyway, great eye and I love the progress on Nakamura. :thumb:
  10. greensabbath
    19 Apr 2005
    Thanks Pfaffen,
    I think one way to fix it (and I definitely think it'd be worth to fix) is to (tell me of this is not possible) use glue on the top panel and just glue those half laps together and then just shorten the tenons a little bit so the top doesn't stick out (if that's actually the problem, it can be hard to tell with pictures).
  11. DeltaFX
    DeltaFX What's a Dremel?
    4 Aug 2006
    You could paint in dark red too. That would give a warmer color to the gold.
  12. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    I really like how the final case looks. Looks very nice in the cabinet as well!
  13. MoRBiD
    MoRBiD Minimodder
    27 Jun 2007
    looks good well done . how much did the gold flake cost ya ?
  14. ComputerKing
    8 Sep 2006
    good job but I don't like it I'm not gold fan :( sorry buddy but your work is awsome :D well done and take care
  15. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    looks good but I don't like the star-thing on the side
  16. Pfaffen
    18 Mar 2007
    Not very much. The pages of gold leaf were about $10US and it had 25 pages, that covered the front, side and top. Also a little to experiment with. Had never worked with it before. The flakes were about $8US. It was kind of cool to buy a bag of gold...
    Take care
  17. Pfaffen
    18 Mar 2007
    DeltaFX,
    I tried that, but just did not like the way it came out. It made the gold look more copperish...
  18. Pfaffen
    18 Mar 2007
    That is a good idea, but I kind of like the challenge to build it without glue. :wallbash:
    I see so many works that rely more on glue than they do with skill and planning for the cuts. I may try angling the tenons and fit the mortice to better recieve them. The issue, however, is leaving enough wood to remain strong.
    Will keep everyone posted.
  19. greensabbath
    19 Apr 2005
    I feel the same way (since Yuugou and Sangaku use no glue too). I'm looking forward to see how you solve it. Good luck.
  20. Cheapskate
    13 May 2007
    Would it be possible to make boots to cover the seams? (I always cover my mistakes, rather than fixing them!)
    In case I haven't said it already- Looks great, Dude!
