Project:FileAnywhere - COMPLETE
Discussion in 'Project Logs' started by ouija, 9 Jan 2003.
  1. Visualaid
    Visualaid What's a Dremel?
    15 Apr 2003
    if they come with em i'm all set thanks for info :).
  2. ToM
    ToM mmmm, blud
    14 Aug 2001
    maplin bawx :clap: :clap:
  3. ouija
    ouija Trust me, I am doctor!
    10 Nov 2002
    Indeed tommeh... spamtastic :lol:
  4. Wolfe
    Wolfe What's a Dremel?
    7 Sep 2003
    Hmmmm. If it's file anywhere, does that mean you can access it over the web, from anywhere? :)
    You could modify one of the fans so only 2 of the leds were HD indicators. Personally, can't stand a computer without a Hd Monitor, but thats just me.
    *Edit* I mean that the other two would be on all the time. It would kind of kill the "Big Bright Blinky Fan" effect.
  5. ouija
    10 Nov 2002
    Not a bad idea, but there is no need for a HDD activity LED. It doesn't get accessed too often since most people at our LANs have all the relative updates anyway.
    The name is because it's a fileserver and uses pcAnywhere instead of a monitor/keyboard/mouse.
  6. [- pio -]
    [- pio -] What's a Dremel?
    2 Feb 2004
    I would really like to see a full frontal shot. ;)
    Great case BTW!! Nice to see someone else who can appreciate the beauty of simplicity!!! It would be easier to make up an opininon on the vandal switch if you posted an image of the whole thing..
    Anyways, I'm just babbling. /slaps self ( :duh: )
    MOD ON :D :rock: :thumb:
  7. ouija
    10 Nov 2002
    You can see the switch in this pic:
  8. [- pio -]
    2 Feb 2004
    Yup. Black is good IMO! :thumb: (you've probably made up your mind anyway :rolleyes: )
    Yet again: Great mod!
  9. Fraggster
    Fraggster What's a Dremel?
    30 Dec 2003
    :waah: i want on, i hacked up an old AT case for my file server- works great to raise up my monitor
  10. 3N1GM4
    3N1GM4 What's a Dremel?
    23 Jun 2003
    those white led fans look damn good... and the box looks damn good too... keep it up..! :thumb:
  11. fuzzygoblin
    fuzzygoblin What's a Dremel?
    19 Oct 2003
    Nice to see one of your mods completed(im going through them all from your sig) i like this one its clean small neat tidy.
    well done i like it (and zapwizard likes it too :p )
  12. Acid Burn
    Acid Burn ..look but don't touch..
    14 Mar 2004
    oh! great work! how many wats is that PSU? where did you get that mobo?
  13. Kolmik
    Kolmik What's a Dremel?
    21 May 2004
    Interesting setup. :rock:
  14. madhatter
    madhatter What's a Dremel?
    16 Sep 2003
    this is looking very good! i'm most impressed. do keep us updated!
  15. philyoung
    philyoung What's a Dremel?
    2 Aug 2004
    I think the project is complete!?
    Phil
  16. ouija
    10 Nov 2002
    You are absolutely correct, the project was finished a while ago. However, the IBM Deathstar has failed on me since then. Need to find a new drive and re-install the O/S. No more mods though, it's all finished. My current project is the PS2 box.
  17. ChegsJAR
    ChegsJAR What's a Dremel?
    7 Sep 2003
    hey ouija
    I'm looking at doing something like this.
    I see you have the 80mm fan over the epia board?
    Is there enough room is is it a very close fit
  18. ouija
    10 Nov 2002
    Yes, about 2mm clearance above the heatsinks. The RAM will obscure the fan, so you need to place the hole very precicely. Also, with the board I used, you can only use one of the RAM sockets because of the position of the 80mm fan.
  19. bazorama
    bazorama What's a Dremel?
    24 Dec 2004
    i have the same shape fan grill on the side fan of my case lookin to replace it thou with a better one matchin my window design :)
