Modding Project: FireFox (planning stage)
Discussion in 'Modding' started by Pballer98c, 13 Jun 2005.
  1. Pballer98c
    Pballer98c Minimodder
    2 Jan 2005
    General:
    This case will be all black. Replace cd rom and floppy with black ones (or paint them). Replace case screws with thumb screws
    Sides:
    Bright orange acrylic windows on each side with “FireFox” then “http://www.getfirefox.com” in small font underneath it.
    Back:
    Orange tail
    Front:
    Ears of a fox
    Top:
    Orange acrylic window over the power supply to expose the components. “FireFox” will be imprinted in the window. The FireFox logo will then be attached to the rest of the top, and “FIREFOX” will be placed over it.
    Inside:
    100” orange sleeved. Orange cathodes to light up the panels. Paint the silver metal a orange and black scheme.
    what do you all think? thanks!
  2. moddenmania
    moddenmania What's a Dremel?
    18 Sep 2004
    Sounds good can't wait to se the final result
  3. Arkuden
    Arkuden mow?
    9 Jul 2004
    should be neat to see. what kind of case are you going to use?
  4. Pballer98c
    2 Jan 2005
