Case Mod - Complete ⭐ Project Firewater sponsored by Thermaltake, Asrock, Seagate and AMD
Discussion in 'Project Logs' started by samarlian, 9 Feb 2020.
  1. samarlian
    samarlian Minimodder
    8 Aug 2018
    Hi all
    Project: Firewater
    Wanted to do something a little different so decided to build a Thermaltake Level 20 fire surround case.The firesurround will be custom made from mdf and wall mounted fire set back in the surround.
    System Specs
    • 1 x AMD Threadripper 2990WX
    • 1 x ASROCK Fatal1ty X399 Professional Gaming motherboard
    • 1 x Seagate FireCuda 510 2TB M.2 NVMe
    • 1 x Seagate IronWolf Pro 4TB SATA HDD
    • 4 x Custom cables from To the wire Mods
    • 1 X Thermaltake Pacific W6 CPU Water Block (AMD Ryzen Threadripper TR4)
    • 4 x Thermaltake Toughram RGB Memory DDR4 3600MHz 16GB (8GB x 2)
    • 1 x Thermaltake Toughpower PF1 ARGB 1200W Platinium
    • 1 x GTX1080 with Thermaltake Pacific V-GTX 10 Series Founders Edition Transparent
    • 2 x Thermaltake Pacific PR15-D5 Reservoir/Pump Combo
    • 2 x Thermaltake Pacific CL480 Radiator
    • 30 x Thermaltake Pacific C-PRO G1/4 PETG Tube 16mm OD Compression – Black
    • 16 x Thermaltake Pacific G1/4 90 Degree Adapter - Black
    • 27 x Thermaltake Riing Trio 12 RGB Radiator Fan TT Premium Edition
    • 4 x Thermaltake Pacific G1/4 Female to Male 10mm extender - Black
    • 2 x Thermaltake V-Tubler PETG Tube 5/8” (16mm) OD 1000mm 4 Pack
    • 4 x Thermaltake V-Tubler PETG Tube 5/8” (16mm) OD 500mm 4 Pack
    • 1 x Thermaltake P1000 Pastel Coolant - Yellow "Formulated to Impress"
    • 1 x Thermaltake P1000 Pastel Coolant - Red "Formulated to Impress"
    • 2 x Thermaltake Pacific Lumi Plus LED Strip 3Pack
    • 1 x Thermaltake Level 20 RGB Gaming Mouse
    • 1 x Thermaltake Level 20 RGB keyboard
    • 1 x Thermaltake E1 RGB Gaming Headset Stand
    • 1 x Thermaltake Level 20 RGB Extended Gaming Mouse Pad
    My design
  2. samarlian
    8 Aug 2018
    Thanks for the support Thermaltake , Asrock and AMD
    Here is some of the pc parts
    [​IMG] [​IMG]
    The_Crapman likes this.
  3. samarlian
    8 Aug 2018
    Here is the start of my project , need to fit motherboard to measure up for the pass through fittings and cables.
    [​IMG]#
  4. samarlian
    8 Aug 2018
  5. samarlian
    8 Aug 2018
    Working on project Firewater today , gpu bracket, cut pass through holes and fit the silk flame fans.
    [​IMG] [​IMG] [​IMG]
  6. samarlian
    8 Aug 2018
    Time to test the silk flames, then next week drill holes for 24 pin , cpu and gpu.
    Lambda, Cheapskate and MLyons like this.
  7. samarlian
    8 Aug 2018
    Started building the fire half this weekend
  8. The_Crapman
    5 Dec 2011
    The fire effect lighting is great. Really looks hot.
    samarlian likes this.
  9. samarlian
    8 Aug 2018
    Now for the fire back plate which will mount the pc
  10. samarlian
    8 Aug 2018
    thanks
  11. samarlian
    8 Aug 2018
    Now for the mantle ie top
  12. samarlian
    8 Aug 2018
    Now for the hard part cut the holes for 120mm fans and quad rads which will be mounted in the pillars.
  13. samarlian
    8 Aug 2018
    Extraction fans on the top of the mantle piece.
  14. samarlian
    8 Aug 2018
    Managed to get more work done filling in screw holes and get the rest of the parts and materials i needed before lock down.
    [​IMG] [​IMG]
  15. samarlian
    8 Aug 2018
    Case painted and rebuilt the surround has a few more adjustments and then ready to prime.
  16. samarlian
    8 Aug 2018
    More prep work done this weekend primed ready to paint.
  17. samarlian
    8 Aug 2018
    Well Project Firewater is starting to take shape, need to make a custom gpu back plate and a window for the Seagate 4tb Iron Wolf hard drive. In the rear of the pc I need to make a custom holder for a Thermaltake 1200w psu and fix the rads and all fans.
    [​IMG] [​IMG]
  18. samarlian
    8 Aug 2018
    The Thermaltake and stock back plate is to thick for the Asrock Fatal1ty X399 Professional Gaming Motherboard so decided to make a custom one.
  19. samarlian
    8 Aug 2018
    Fans fitted, radiator mounts cut and painted. Quad rads fitted and usb hubs. Tomorrow make a holder for the psu and do some cable management. It's all starting to come together.
    [​IMG] [​IMG]
  20. samarlian
    8 Aug 2018
    Toughpower PF1 ARGB 1200w power supply fitted cable management done , now to fit some fan controllers and tomorrow bend some PETG stay tubed.
    Sam__ and Goatee like this.
