Scratch Build – In Progress Project Flipmode - 1 jan 2012 - Flipmode finisht -
Discussion in 'Project Logs' started by Paslis, 13 Jun 2011.
  1. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thank you very much Andersen1337 and how much it costs for building one i dont know yet. :D
    Thank you. :)
  2. Korvus
    Korvus May contain traces of sanity.
    14 Apr 2011
    Love the metalwork here, fantastic job with the welds and fabrication :D
    Like the concept too :lol:
    Look forwards to seeing the results!
  3. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thank you very much Tech_Jakl. :)
  4. Paslis
    Paslis Minimodder
    13 Jun 2011
    Update 9 - 10 Oct 2011 -
    The last 2 weeks of my holidays me and my wife were repainting the house inside and out.Also new floors and re newing some things.5 weeks ago i was almost finisht and i fell down and broke me a rib so again no modding.Now im recovered and its time to do some modding again.
    First i took apart the lamptron fc8 fancontroller.Then i drilled the holes for the buttons and leds and mount it inside the case and this is how it looks.
    Now this is finisht i can go further with making a bracket for the lcd screen.The screen i had was broken so i had to buy a new one.
    The dimensions of this lcd screen were bigger so i had to make the hole bigger in the mobo plate.
    Now this is finisht i can make the bracket.The screen has a plate on the backside with 4 holes in it.These holes im using for the bracket to mount the screen on.
    Im using 2mm alu for the plate and 4x 10mm stainless steel standoffs with a lenght of 30mm.
    First i drilled the holes in the standoffs and tapped them with m5.
    The i cut me a piece of alu and drilled the mounting holes for the screen and for the standoffs.
    Then i mount the bracket on the screen.
    And this is how it looks inside the case.
    Im happy im back to modding again so more updates to come. :D
    Marcos_Viegas and David like this.
  5. RedManc
    RedManc What's a Dremel?
    30 Jul 2011
    Welcome back to modding! I love the orientation of the motherboard tray,
    Its much more showwy offfy than the norm :) and as for the screen well that is a nice idea also :)
  6. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thank you RedManc. :D
  7. Blarte
    Blarte Moderate Modder
    15 Jul 2008
    I am not one to blow smoke up folks ar5es, but I like this log/ build lots
    I especially like the tilt inspired door, mobo tray angle and the integral cut fan holes
  8. bulldogjeff
    2 Mar 2010
    Dave, your amazing way with words never ceases to impress me..:D
  9. jeckulz
    jeckulz What's a Dremel?
    18 Jan 2011
    Glad to see you back on the job here mate.
    Keep the good stuff coming!!!
  10. Nitrixflare
    Nitrixflare Building and engineering enthusiast
    31 Dec 2010
    Awesome as always. I just doubt the fan grill cutouts though.
  11. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thank you Blarte.
    Thank you jeckulz and im glad to be back.
    Thank you Nitrixflare.
  12. Paslis
    Paslis Minimodder
    13 Jun 2011
    Update 10. -15oct 2011-
    Today i made the intake..The piece im using is the piece i cut away from the mobo tray.
    Its this piece.
    First i cut both side pieces and i used 2mm alu.
    Then spotwelded them on the plate.
    Welded.
    Finisht.
    Then i drilled the holes for the 120mm casefand and countersunk the holes.
    And this is how it lookes for now.
    This was it for today but im back tomorrow with a fresh update.
    yassarikhan786 likes this.
  13. Archer
    Archer Talga Vassternich - Deserve Victory
    10 Jan 2011
    Whoa, epic welding skills! :thumb: Overall its looking great too, subbed
  14. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thank you Archer. :D
  15. Blarte
    15 Jul 2008
    To quote Bob Hoskins from an old advert.."its good to talk" lol
  16. Hannes
    Hannes Design | Art | Performance
    24 Apr 2010
    This build is fantastic. You're clearly a really creative mind.
  17. GuilleAcoustic
    GuilleAcoustic Ook ? Ook !
    26 Nov 2010
    Oh my nom nom nom ... I spend so MUCH time on this forum and I only see this now ! How could I have missed that thread ? You're an artist, so perfectly built :thumb:
  18. yassarikhan786
    yassarikhan786 Ultramodder(Not)
    10 Aug 2011
    Very beautiful work mate. I'm definitely following this, I really want to see the end result :).
  19. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thank you Hannes.
    Thank you GuilleAcoustic and im glad you see it now. :D
    Thank you yassarikhan and you will see the end result. :D
  20. Paslis
    Paslis Minimodder
    13 Jun 2011
    Update 11. 31Oct 2011
    I was trying to put all the cables below the mobo but the space was to little to putt all of them below so i had to make some extra holes for the cables.
    The extra holes are made and i putt in the holes for the fillports.
    Then i putt the case together again and went home to fit the hardware in.
    Then i start with the plumbing and this is how it looks at this moment.
    Im still busy whit sleeving and fitting the hardware so more to come.
