Scratch Build – In Progress Project Flipmode - 1 jan 2012 - Flipmode finisht -
Discussion in 'Project Logs' started by Paslis, 13 Jun 2011.
  1. RedManc
    RedManc What's a Dremel?
    30 Jul 2011
    plumbing goodness!
    nice work, although my jealousy for those fittings is disgraceful! ;)
  2. yassarikhan786
    yassarikhan786 Ultramodder(Not)
    10 Aug 2011
    Brilliant work mate. I love how clean everything is.
  3. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thank you RedManc. :)
    Thank you mate and im working on the backside now so more to come. :)
  4. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    Im loving that, top welding skills there mate and the door idea is awesome :thumb:
  5. quizz_kid
    quizz_kid Squid
    19 Jun 2011
    Looking really really good... Love the angle of the MB!!
  6. BOBDBONE
    BOBDBONE Owner at BS Mods
    4 Feb 2009
    Very impressive. You have some great skill.
    This is really shaping up to be a top notch build.
  7. craig - toyoracer
    craig - toyoracer Minimodder
    1 Mar 2011
    Thought I would pop in to say hello. :)
    Looking great with the board in there. :thumb:
    Going to be one of the cleanest builds ever.
  8. xSoMBrAx
    xSoMBrAx Minimodder
    18 May 2011
    Looking very good!
    Only thing I don't like are the "atom themed grills"
    Other than that, board placement is epic and also the skills to shape the whole case :)
  9. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thank you coolamasta. :)
    Thank you quizz_kid. :)
    Thank you BOBDRONE and im doing my best. :)
    Thank you craig and i trying to make it as clean as possible. :)
    Thank you xSoMBrAx. :)
  10. Paslis
    Paslis Minimodder
    13 Jun 2011
    Update 12.
    This weekend i painted and sleeved the casefans.Inside the case there are gonna be 12 fans,3x 140mm,6x 120mm and 3x 92mm.
    The picture below counts 9 fans but the other 3 are already at my work.
    First thing is to remove the fanblades.
    Now thats finisht its time to paint them.
    I'm very happy with the result of the paint.This morning i went back to my work to get the fanblades etc and drove back home to put them back together.I also sleeved the casefans and put a black connector on them and a black sticker on the backside.
    This is the result.
    140mm.
    120mm.
    92mm
    This was it for today.
  11. JULO
    JULO What's a Dremel?
    2 Jul 2010
    If I had to advise you on your bulid I'd say you should first think what you want the end effect to be. The impression to me is that you get the new toys and immidiately change your mind like 'Oh, this toy is cool, I'm gonna put it there' ;)
    But it's just my opinion.
    Apart from that, the case is just suberb as for me :clap:
  12. yassarikhan786
    10 Aug 2011
    Awesome job on the painting. I love that shade of blue, it looks really, really nice :).
  13. bguilleminot
    bguilleminot What's a Dremel?
    11 Aug 2011
    Spectacular work, can't wait to see it finished
  14. jeckulz
    jeckulz What's a Dremel?
    18 Jan 2011
    Love the colour, very much like alpenfohns blue.
    I approve.
  15. Paslis
    Paslis Minimodder
    13 Jun 2011
    Thank you for your opinion and to be honest im doing all the wire and hardware now inside the case so when the painting is finisht i can putt it all inside the case without any problems.
    Thank you for your compliment. :)
    Thank you yassarikhan im also very pleased with the end result. :)
    Thank you bguilleminot and the case will be finisht soon. :)
    Thank you jeckulz. :)
  16. Paslis
    Paslis Minimodder
    13 Jun 2011
    Update 13.
    Now that all the sleeving is ready its time to do some metalwork again.Today i made a cover for the fancontroller.
    This was how it looks.
    Lets get started.First i cutt some pieces of metal.
    Then is spotwelded the pieces together and fit the fancontroller.Then i cut another piece of metal and spotwelded it also.
    Then i cut 2 pieces of metal for the mounting holes and drilled the holes and spotwelded the pieces on the cover.
    The cover is ready for welding.
    Finish.
    This is how it looks inside the case.
    I also did some visual changes on the case.I made a new top cover and a new fanplate.
    Before.
    After.
    Before.
    After.
  17. Gaming_freak_10
    Gaming_freak_10 Minimodder
    5 Jun 2010
    Pictures links are dead..
  18. Paslis
    Paslis Minimodder
    13 Jun 2011
    Strange i see them.
  19. SuicideNeil
    SuicideNeil What's a Dremel?
    17 Aug 2009
    I can see them too- awesome welding on such thin metal :thumb:
  20. Gaming_freak_10
    5 Jun 2010
    okay apparently it was my stupid internet provider that basically did the links are dead thingy.. sorry bout that everyone!
