Case Mod - In Progress [Project] :::Flow::: (SNiiPE's V2110) - 22, August - Video, finishing off :)
Discussion in 'Project Logs' started by SNiiPE_DoGG, 14 Apr 2009.
  1. retrogamer1990
    retrogamer1990 What does 'Stock' Mean?
    12 Jan 2009
    I still think it says floj....but those fan controllers are niccccce! :D
  2. The boy 4rm oz
    10 Apr 2008
    Very nice rad, I am using the 120mm version myself, sadly mine wasn't in as good condition as yours when I got it (had a few scratches) and it came in a plain brown cardboard box but it works brilliantly.
  3. Floyd
    Floyd Wire Twister
    4 Dec 2008
    So you had those blue wires and then you sleeved them?
  4. SNiiPE_DoGG
    SNiiPE_DoGG Engineering The Extreme
    14 Apr 2009
    Actually no, the PSU is just the regular wires sleeved because logistically the way that I am doing the visible blue wires, having them run all the way to the PSU just doesnt make sense. I finished half of the Blue 24-pin wires last night so tonight I will have a clear and obvious documentation of how I did them :)
  5. Floyd
    Floyd Wire Twister
    4 Dec 2008
    Ok I guess ill wait for pictures because that didnt make a lick of sense.
  6. SNiiPE_DoGG
    14 Apr 2009
    Hehe, yeah I guess it only makes sense to me because there is a major item that goes on the motherboard tray that I have not shown pics of yet.... Basically I am using a fancy 24-pin extension section for the visible portion of the wiring ;)
  7. Floyd
    Floyd Wire Twister
    4 Dec 2008
    Oh ok. I got ya.
    So you have:
    PSU[sleeved wires][blue wires]
    Ill have to see how you execute it because honestly it doesnt sound good to me to do half one way and half the other.
    Im waiting on more pins now but all of my wires are going inside my PSU to be soldered and heatshrunk then exit the case and go to its respective place. I love my Corsair PSU but the cables are way too long for my case. Ill be happy once they are all the right length.
  8. SNiiPE_DoGG
    14 Apr 2009
    here ya go Floyd you impatient little bugger :p :lol:
    I guess I have kind of hyped this wiring solution up a bit.... I hope you guys like it :)
    probably more pics of stuff tonight, well see what I decide to do with myself....
    Javerh likes this.
  9. disturbed13
    disturbed13 What's a Dremel?
    28 Nov 2008
    that looks NICE!!!!!
    i wish i could do something like that
  10. The boy 4rm oz
    10 Apr 2008
  11. Javerh
    Javerh Topiary Golem
    5 Sep 2006
    Now I'm jealous!
  12. Bad_cancer
    Bad_cancer Mauritius? 2nd speck east of africa
    7 Apr 2009
    holy mother of ******! that is so cool! awesome!
  13. SNiiPE_DoGG
    14 Apr 2009
    Hey, its not all that difficult if you set yourself to it!
    This was all hand made from a piece of 1/4" thick delrin using a drill press - I used solidworks to figure out the hole spacing, hashed out the cut area with the sharp ends of my digital calipers and used the hand center punch to finalize the hole locations. I then used my drill press to make the holes with the aid of some clamps and a piece of 90degree alu extrusion as the X-axis guide to keep the holes in a perfect straight line. Lastly I sanded with 100 then 320 and primed once and painted 4 coats of satin black krylon spray paint - sun dried for 24 hours.
    Cheers 4rm :thumb:
    thanks Javerh :D
    :thumb: thanks Bad cancer, I'm glad you like it - I like it too :D
    and one last pic while I go off for a break and then sleep...
    stonedsurd likes this.
  14. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    WOW. looks awesome.:jawdrop:
    saw it on XS (cant get on bit-tech at school) and i thought to myself, that is the single coolest thing ive seen all week
  15. stonedsurd
    11 Mar 2009
    Jesus, that's siiiiiick
    Dude, don't go dominating MDPC now. Leave some space for us aspiring little fellers?
  16. logan'srun
    logan'srun following the footsteps of giants
    22 Apr 2008
    wow, that pic of the extender is pure AWESOMENESS! You should expect this idea to be copied/borrowed by the general population very soon.
    Any pics of what the backside of that looks like??
  17. Floyd
    Floyd Wire Twister
    4 Dec 2008
    Looks good. Im going to try to bring my wires straight off the short edge of the 24 pin and not loop it off like most people do on the long side. Its mainly because of the way the torture rack is and the way im thinking of making my wire runs.
    I finally got my extra pins in so I started discharging the PSU this morning and it should be good in about 9 hours or so when im off work.
    Are you still using those silver rings to hold your wires? Im going low tech for now and just using tiny black zip ties in Mil-spec fashion every 4" or so. It looks ok for now but im still looking for ways to hold it up to the bottom of the mobo tray without it looking silly and out of place.
  18. Gundam-X
    Gundam-X Who is Dremel?
    24 May 2009
    Loving it so far ;)
  19. blackflag
    blackflag I Kill Dremels
    16 Oct 2003
    Nice work on the ATX wires. I was actually planning on doing the same thing with my next build off in the not-too-distant future, just in black. Beat me to it...:D
  20. Rocket_Knight64
    Rocket_Knight64 Minimodder
    12 Feb 2009
    I dont like to comment on unfinished mods unless I have something more to add then "0MG t3h 4usum", but...
    0MG t3h 4usum!!!
    I cannot wait to see the end product in all its glory. More so to see how a 140.3 rad performs along with your 'parallel Crossfire WC bridge'. Also any idea on what HDD's you are going to go for? Dont think Intel would be too cool funding an AMD build so an OCZ vertex for a boot drive maybe?
