Project: Flyin Banana - Finished - Loads of Pictures
Discussion in 'Project Logs' started by coolmiester, 28 Feb 2005.
  1. coolmiester
    coolmiester Coolermaster Legend
    31 Dec 2002
    I know this colour won't be everyone’s cup of tea but i just love it........and it's even brighter in real life :p
    I've had most of the components for this one for a little while now but other commitments meant it all sat round for a while but eventually i made a start.
    This will be my new work machine and the Shiny Wavemaster will become the new game rig.
    Component list:
    Wavemaster Yellow
    Lan Party NF3 250GB M/Board
    AMD Athlon64 3200
    2x 512mb OCZ 3200 Platinum Cas 2
    Tagan 480watt
    74gig Raptor
    Cooling List:
    TDX CPU Block(nozzle 1)
    NV-68 GFX Block
    Laing DDC-12v Pump
    BIX Double Rad
    Floppy Bay Res
    Anyway, here goes...
    First off to strip the case down of everything that can be removed as there is a little bit of cutting to get a double Rad to fit.
    Got to remove the 2x 80mm fans from the front also which have to be de-riveted by simply drilling the top off the rivet with an oversized drill bit and the rivet should simply fall out the other side.
    Time to mask off the top and turn the case up side down, as some of the PSU cage needs to come out so the Rad will fit in.
    Cutting out this one section (red arrow) will not weaken the cage at all and will allow the double rad to mount far enough in
    More to follow 8)
  2. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    Hoo that's bright! You love Wavemasters, don't you? :D
  3. roachm
    roachm New Member
    16 Nov 2004
    If you paint the interior black it would look so sexy :D
  4. TMM
    TMM Modder
    12 Jan 2004
    I love the colour! :D
  5. Machine
    Machine New Member
    27 May 2004
    WaveMaster MAdness :rock: .
    a wavemaster in your hands is always a good project. :rock:
    me Subscribed :thumb:
  6. dj_2004
    dj_2004 New Member
    9 Oct 2004
    wow sweet color! i agree... paint the inside black
  7. Leeum
    Leeum New Member
    16 Feb 2004
    Can i just say, I love your taste of colours :D Will we be seeing any shiny stuff in there? :hehe:
  8. SJH
    SJH Active Member
    24 Dec 2003
    Wow I love that yellow, I can tell this is going to be a great mod ;)
  9. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    lmao paul!
    That's great...... Good luck with it. What an amazing colour!
    - S
  10. Dmc
    Dmc Member
    13 Jul 2004
    The mark of the red 'X' is all I can see
  11. coolmiester
    31 Dec 2002
    Server fell down.......back up now though :blush:
    OK…got all the top marked out with a dual grill ready for cutting
    I’m using a rusty old grill that will be sanded and painted black later
    /…and here it is cut and holes drilled ready for the double BIX to be fitted.
    As you can see…..i’m carrying the black and yellow theme through onto the mainboard which is a Lan Party nF3 250GB (no shiny bits on this one)
  12. antiHero
    antiHero ReliXmas time!
    19 Jan 2005
    like the color theme. really nice. keep it up. :dremel:
    supscriped
  13. guy
    guy New Member
    20 May 2004
    looks awesome with that mobo in it
  14. Peddro
    Peddro New Member
    21 Feb 2005
    Nice work...
    I don't like the color, but that is a question of taste :)
    mod on! :rock:
  15. blknoel
    blknoel New Member
    14 Jun 2004
    Somebody upthere already said it, but I think its true :)
    The interior would look wicked if painted black. Black and Yellow :) (mobo also :D )
  16. Sheiken
    Sheiken Wat?
    9 Jan 2005
    VERY NICE indeed! keep up your great modding :thumb:
  17. (X)TORNADO(X)
    (X)TORNADO(X) New Member
    26 Feb 2005
    Keep on working, you are having a nice broject.... :thumb: :thumb: :thumb:
  18. automagsrock
    automagsrock New Member
    18 Nov 2004
    Nice choice of case. Great color too. but I also agree with just about everyont is saying that a black interior would be awesome.
  19. Franklin
    Franklin New Member
    24 Oct 2004
    That's the first thing that I thought when I opened this thread :hehe: :hehe:
  20. coolmiester
    31 Dec 2002
    Did think about painting the inside but i quite like the bear new aluminium and nothing i could do to it would make it look better than what it does.....i need to get this case finished and up and running asap :)
    Anyway....sanded and painted the grill which has turned out pretty good even though i say so myself.
    5 coats of primer and 15 coats of gloss black and then wet sanded and polished with T Cut
    Took a long time....think it was worth it?
