Scratch Build – In Progress [Project] Full ATX SFF Build
Discussion in 'Project Logs' started by conzy, 23 Jul 2008.
  1. conzy
    conzy SFF!
    4 May 2008
    Hi all, long time reader / lurker but don't post much, I have been working on building a small form factor case that supports full ATX mobos, full length GFX cards, full size HSFs like the Thermalright IFX-14 and possibly a WC setup in the future. This is not a 100% scratch build, but its a hell of a lot more than a case mod so I think it deserves the scratch build tag :)
    I started out by completely dismantling my old Lian Li PC7 Plus, I planned on using its I/O plate and mobo tray to save me some work and seen as its aluminium it will keep the weight down, I cut it down to size and folded some tabs too so I would have somewhere to attach the other structural pieces with rivets
    That was about 3 months ago then I had exams and that through a spanner in the works :D I really only got the ball rolling on this project last weekend, I drew up some plans for a design I had in mind and it has gone through several iterations since last weekend :p
    And here's a rough sketchup of what I was going for last weekend
    Stainless steel shell with the whole front made out of perforated stainless steel
    The new plan is to re-use some of the old Lian-Li to make a front panel like this:
    I bought two nice Stainless Steel Bulgin buttons on ebay and there will be some switches to control lighting and fans too, I may leave more space at the top and install a card reader there, As you can see I'm not using an Optical drive at all :)
    Heres a quick preview of the case so far, There is still a metric ass tonne of work to be done
    I'm planning on spraying the inside of the "hood" black to match the front panel, I might polish the perforated stainless steel to add some bling also
    The Psu is being mounted vertically in the front, I'm running a cable from the PSU to a "kettle" socket on the back so that wont be a problem, and I am going to mount 3 HDDs vertically along the side of the case
    Specs:
    Q6600 + Thermalright IFX-14 + 120*38mm Scythe
    Abit IP35 Pro
    Radeon 4870 512MB + Akasa Vortexx
    Corsair HX620 modular PSU
    4GB 1000mhz OCZ Platinium
    WD Caviar 640GB 2 platter drive + OCZ Core SSD in a few weeks
    Creative X-Fi
    I'm open to any tips / suggestions from the pros :) Thanks ;)
  2. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    looks pretty good :thumb:
  3. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    cool,looks very xps styles
  4. ednismod
    ednismod Minimodder
    15 Oct 2007
    hehe, it looks like xps alright but not that much. this mod is interesting, looks clean at first stage. keep up the good work.
  5. conzy
    conzy SFF!
    4 May 2008
    I had another few ideas
    I could make an external box that houses an Optical drive and a card reader that connects with a single multicore cable, That would be pretty cool
    Or make guides for the perforated sheet so that it can slide down a little to reveal the card reader?
    What do you guys think?
  6. DonT-FeaR
    DonT-FeaR I know what a fk'n Dremel is ok.:D
    23 Jul 2008
    looks very very nice i like it i should incorperate that slant at the front into me next mod thats just what its missing too is that ok?
    :rock::thumb::dremel:
  7. nagyizom
    nagyizom Minimodder
    2 Jun 2008
    Yes, I like it:p
  8. conzy
    conzy SFF!
    4 May 2008
    omg patent pending! :D j/k It would be cool to see it in another build :)
    Went on a bit of a shopping spree today, Bought perforated steel, New Dremel kit, Primer and Black spray paint, Stainless steel handle and sliders for the perforated sheet. Will post pics after some food!
    @ Oreon_237: I had the XPS 720 case in mind when I designed the case, I loved the slight hood and the perforated front but I wanted more of a hood :)
  9. conzy
    conzy SFF!
    4 May 2008
    Thanks mod :)
  10. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
  11. pizan
    pizan that's n00b-tastic
    25 Apr 2008
    just a question: Wheres the power supply going to go?
  12. conzy
    conzy SFF!
    4 May 2008
    Good question :) The PSU is being mounted vertically in the front of the case, With the ATX / molex connectors at the top and the 220v input at the bottom, I am re-routing the 220v input to the rear of the case so it will be like any other PC in that regard
    Thanks for the link 500mph
    new stuff \o/
    Time to get back to work! The handle won't be mounted until the mod is almost finished cause I will need to find the centre of gravity of the case
    *edit* I don't know what this crap is but it was cheap and i'm making the sliding rails for the perforated sheet from it
    like so :p
  13. HaoKi
    HaoKi Lleno de anguilas!
    10 Oct 2003
    Nice...:) Really looking forward to seeing more of this project... :D
  14. conzy
    conzy SFF!
    4 May 2008
    I was going to use an original panel from the PC7 Plus as the front panel and I foolishly assumed it would "just fit" seen as i have not changed the width of the original case... But, The panel is the same size as the shell so it will not fit inside it :/ So i just wasted an hour or so cutting and folding it...
    And after all that it doesn't fit and I cut my finger!
    So I have two options now, Get an original side panel from the PC7 Plus professionally folded, Or just get the fabricator to fold a new piece of Aluminium or Stainless steel, I suppose it doesn't really matter as the front panel will be painted black...
  15. conzy
    conzy SFF!
    4 May 2008
    Ok I decided to go back to the fabricator and get him to make me a piece for the front panel, Its going to be made from thick aluminium plate i think, It will be mounted to an internal frame i'm making from aluminium angle bar
    Should look something like this when its done
    If the finish isn't great or if it just doesn't look cool I might still paint it black
  16. BlackWhizz
    BlackWhizz What's a Dremel?
    17 Jul 2008
    Uhm... think i didnt see it, but where are you going to put your PSU?
  17. conzy
    conzy SFF!
    4 May 2008
    :D I answered that twice already! :)
    This should clear up some confusion
    The 120mm fan on the HX620 will face forwards and exhaust / intake air through the perforated sheet
  18. nikeunltd
    nikeunltd Epic destruction around machinary
    5 Apr 2008
    ouch!! you need some first aid!! and some really heavy duty fitted gloves...jk.
    looks interesting so far!
  19. notatoad
    notatoad pretty fing wonderful
    25 Jun 2004
    cool project. i built a case with almost exactly the same layout last summer, except that mine had a full-size optical drive in there too, mounted above the PSU vertically so it overlapped the ram slots, and mine was only 6.5" wide. my case never got finished though, i used it for a year with no side and top panel, and the angle iron frame was pretty ghetto. i don't think i ever took any pictures of it, but i'll have a look.
    a suggestion from my experience: in the current configuration, the PSU will be intaking from the front and exhausting hot air into the case. if you move the psu to either the top or bottom and have the exhaust shooting directly out of the case you will have better temps.
    airflow is very important in a case this size. here's a diagram of what i had, blue is intake fan, red is exhaust fan
    1 is a pair of 80mm over my i/o ports
    2 is a 92mm blowing over my hard drive and under my dvd drive, then hitting my ram and then my CPU
    3 is my PSU intake
    4 is an intake over my PCI cards that hits the intake of my graphics card (this was only planned, as i never got around to side panels
    5 is my PSU exhaust
    6 is the exhaust of my dual-slot cooler.
    good luck! SFF is awesome.
  20. conzy
    conzy SFF!
    4 May 2008
    Thanks for the tips :) Im trying to get away with using only 2 120mm case fans + the PSUs fan as an intake
