Scratch Build – In Progress [Project] Full ATX SFF Build
Discussion in 'Project Logs' started by conzy, 23 Jul 2008.
  1. conzy
    conzy SFF!
    4 May 2008
    So rude to ask a modder his dimensions! :p
    Heres a drawing
    375mm X 205mm X 344mm So Total volume of 26 litres :) The Lian Li PC7 Plus was 50 litres, so Im happy with the reduction in size, almost half! and It still fits a full ATX board with a full length card, It will even fit a 4870X2 with some re-arranging of components...
    I'm 100% sure I'm going with all perforated sheet front now, It will be a lot better for airflow and layout, I dont want to sacrafice airflow and optimal layout for a 7 euro card reader :p
    I put the shell on this morning before work and it fits great! More photos and a big update tonight hopefully
  2. Jack_Pepsi
    Jack_Pepsi Clan BeeR Founder
    24 Apr 2006
    Freakin' great stuff!
    I was wondering what your dimensions are as I wanted to compare them to my PC-A05B which is slightly bigger (y'bugger!) 490 x 210mm x 381mm - so you officially beat the smallest ATX case on the market. Kudos!
  3. conzy
    conzy SFF!
    4 May 2008
    I just looked up the PC-A05B, Its awesome! Its almost exactly what I was planning on building originally, a mini PC7 plus, They also had to relocate the power jack :) I like where they fit the PSU in, any trouble fitting your 3850?
    I have a Viewsonic VX2025wm too btw, <3 it :D
  4. Jack_Pepsi
    24 Apr 2006
    Freakin' is!
    None whatsoever, fits in as smooth as butter rubbed on my girlfriends.... a-hem!
    We rule! It's a great monitor, got it thanks to Bit-Tech's 20" monitor round up a few years ago.
  5. conzy
    conzy SFF!
    4 May 2008
    Ok small update: New PSU position, My original plan wont work, I assumed the 4870 PCI express power cables would stick out the side like Nvidia cards but they stick out the back and hit the PSU... I could raise the PSU up but it would block most of the airflow to the the CPU... So this seems like the best option unless someone else has any ideas? :)
  6. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    is there room to mount the psu like it is mounted in a LIan Li A05? under the GPU..
    the simple answer is to soilder extension wires direct to the GPU so you can make teh connect else where in the case.. lol!
  7. Jack_Pepsi
    24 Apr 2006
    Or have the PSU's fan as an front intake?
  8. conzy
    conzy SFF!
    4 May 2008
    I like my warranty :D
    That was the original plan, but the PSU will intake the air and just exhaust it into the roof of the case and block the IFX-14s access to fresh air, If I mount it as pictured above it can draw air through the front perforated sheet and there is still room for the IFX-14 to draw air from the front.
    Thats the plan anyway...
  9. Jack_Pepsi
    24 Apr 2006
    Arh that makes more sense, any progress since your last update?
  10. conzy
    conzy SFF!
    4 May 2008
    nope :(
    Well lots of progress but its all in my mind :) I have tomorrow off so I should get a lot done ;)
  11. Jack_Pepsi
    24 Apr 2006
    A modder never stops!
    Schweeet, enjoy!
  12. connec
    connec What's a Dremel?
    15 May 2008
    I assume the PSU won't fit in below the GFX?
    You could always just get and nVidia card xD
  13. conzy
    conzy SFF!
    4 May 2008
    lol! But I love ma 4870!
    Been pretty busy over the last few days so no work done, I did build the PC in an old ATX case so I can continue work on the SFF case and have the guts up and running
  14. Burnout21
    9 Sep 2005
    thats a bad idea as it forces people to become lazy and the mod will stop progressing! lol
  15. BlackWhizz
    BlackWhizz What's a Dremel?
    17 Jul 2008
    About the front panel, and your card reader. Isnt it much nicer to mount it in a MacPro style?
    Like this:
    Fear my paint skillz! :p
  16. Jack_Pepsi
    24 Apr 2006
    If he was going to go MacPro style, wouldn't he have it vertically?
  17. BlackWhizz
    17 Jul 2008
    Thats his choice. I was just making an idea about how he could fix it.
  18. AFX
    AFX "Bling" Silver Mountain 2
    19 Sep 2006
    HA I would have never thought SFF and a thermalright IFX would be in the same Project log. way to go!
  19. conzy
    conzy SFF!
    4 May 2008
    If I was going MacPro style, wouldn't I be a homosexual? :D
  20. Jack_Pepsi
    24 Apr 2006
    Pretentious for want of a better word..
