Scratch Build – In Progress Project "Fury" :) New Update (30-11-2011)! ,2nd November
Discussion in 'Project Logs' started by fangame, 2 Nov 2010.
  1. fangame
    fangame Newbie in Modding...
    1 Nov 2010
    Indeed, I found a case with one color is missing something.
    I really think that adding another color permits to create a contrast on the case.
    I find this nice! :)
    And in my mod the white of the fans really slice with black of the structure.
    :thumb:I take this post to thank those who have voted for me on the Mod of the Month!:thumb:
    :clap:
    PS: @ H4B4N0S
    are you french?? ;)
  2. MarcosLFV
    MarcosLFV What's a Dremel?
    7 Mar 2011
    Great work!
    Congratulations for the nominee!
  3. fangame
    1 Nov 2010
    New update with this time, the support of the fins.
    I started with a square tubes and then welding the pieces to assemble into a rectangle:
    The deport is from 8mm to give way to the axes of rotation of the fins:
    Here is a glimpse into the structure:
    To facilitate the installation of the fins,
    I do the support removable, so I created an axis of rotation to the rear
    order to do maintenance without removing the assembly. :)
    The axis of rotation being a screw so that it is removable, so I created the rings in tower machine.
    Here is the bar once drilled and put the proper diameter:
    Then I threaded the rings 4mm in order to insert the screws.
    Hop, a small photo of the two rings:
    Then I inserted the two rings on each rear extremity of the support,
    and then I soldered the whole thing:
    And a shot of grinder for finishing:
    Then comes the most delicate part, drilling the holes necessary to the axes of rotation,
    the holes should be placed at millimeter if I want the final system works perfectly. :)
    Then comes the cutting of the rotation axis in a solid round bar (diameter 5mm)
    After he had only to weld all the axes on the frame.
    Taking care that they surpass all the same length.
    Here is the result after grinding the welds:
    Then I drilled holes for the axis of rotation frame diameter 4mm,
    Normally the screw goes completely in the structure but for now,
    I have not done the bore to accommodate the screw. :)
    Finally, the stops at the front of the chassis structure:
    And here is a big part of over ... :):)
  4. The boy 4rm oz
    10 Apr 2008
    Fantastic work so far. The project is looking very good. Keep it up :thumb:.
  5. fangame
    1 Nov 2010
    Thank you for your compliment! :thumb:
    I normally working on the projet this weekend... :)
  6. H4B4N0S
    H4B4N0S What's a Dremel?
    5 Mar 2011
    Oui je suis français:cooldude:
    Really good , im waiting for next part !
  7. rchiileea
    rchiileea Minimodder
    11 Jan 2008
    this is a nice concept that is being made into a reality, I am following this too...
  8. fangame
    1 Nov 2010
    Thanks for your compliments, It's really nice! :rock:
    @ H4B4N0S:
    Ok! ;)
    Thanks too!
    A small update with the front panel as I call (I do not know if that is his real name???)
    Anyway ....
    Here's what it will feature:
    • 1 Power Button 22mm
    • 1 Reset Button 19mm
    • 4 USB 2.0 Ports
    • 1 Headphone jack
    • 1 microphone jack
    • 1 HDD activity LED
    • And after, maybe two USB 3.0 ports :)
    Here is a photo of the parts:
    Here is a detail of the 2port USB + Audio jacks, for the history, I have not find this on the net
    and I do not know where I can buy this part, so I asked to my high school and the computer scientist that has removed me on a PC :)
    So thank you to him in passing ...
    So I began by installing the USB ports offered by Aquatuning
    because they are centered on the plate so the location was easy to determine.
    To the square of course, I drilled two holes 7 to the drill press and then I finish with a lime.
    It was not very easy to make perfect rectangles, but I did my best ... :D
    And the result is, I think, not too bad although there is still some tweaking to achieve!
    A trial with the USB ports to check if everything goes well:
    Then to place the two other ports and Vandalism buttons
    I created a cardboard pattern to preview the final result ;)
    Once I check everything, so I traced and cut the other two rectangular recess:
    Then with a drill of 10mm for LED and two GreenLee of 20.5 and 22.5mm,
    I drilled holes for the remaining buttons:
    And here's a quick view on the case:)
    Then as you could see, the headphone jacks had not brackets,
    I have done so but for fear of making a short-circuit if I touch the PCB with the brackets,
    I created a rubber gasket to isolate:
    (The shifted holes are not a mistake because they are also shifted on the PCB;))
    And here they are mounted on the PCB:
    Finally, the result on the box :)
    Also, I think replacing the screws on both USB ports by BTR black screws as the screws on the audios brackets...
    What do you think??, Knowing that it will be the same screws that will adorn the cover and the Rheobus.
    Here is a picture with the screws installed:
    And one last question, if the turn of the USB ports in iron touch the plate of my case, is that bad??
    Thank you for your clarification! :):) :clap:
  9. Tonton Buddy
    Tonton Buddy What's a Dremel?
    8 Mar 2011
    Yop!!
    Use full CHC black screw!! ;)
    Did you think to use TF screw?
  10. extreme moder
    extreme moder What's a Dremel?
    9 Mar 2011
    Our .... this was very good layout of buttons and USB ports :jawdrop:
    Congrats :thumb:
  11. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    What do you mean, if the USB metal part of the socket touches the metal case? If so then don't worry its fine as its all 'ground' anyway :thumb:
  12. H4B4N0S
    5 Mar 2011
    Yeah yeah, but what colour do you chose for next part? Do you sleeve your wires?
    Est ce que tu va gainer?
  13. fangame
    1 Nov 2010
    Tonton Buddy:
    Yes, I think change all the silver screws, and I probably would replace by black countersunk screws to keep the facade smooth. :)
    extreme moder:
    Thanks! :thumb:
    coolamasta:
    This is exactly what I wanted to know!
    Thank you for your advice, they will be very useful to me. ;) :)
    H4B4N0S:
    As the digital renderings, the case will be black with a few pieces of polished aluminum.
    And some cables will be sleeved! :) (USB, Power/Reset Button,...)
    I post the update with fins this week! ;)
  14. Tonton Buddy
    8 Mar 2011
    Yeah good!! ;)
    The look is really improved with these screws, check my work...
    Here is my workblog on bit-tech : Click ... mais tu dois certainement le connaitre vu que tu traines sur HFR... ;)
  15. fangame
    1 Nov 2010
    Tonton Buddy:
    Yeah, teh screws make really good!
    It's very pretty. ;)
    I follow your Mod on HFR, it looks really fantastic!
    Impatient to see the end!:thumb:
    And now, the new update:
    As promised, (although a little late :)) here the making of fins:
    For those who followed from the beginning, I had already spoken, they will be in aluminum 2mm thick and their final width will be 210mm.
    Here the plates before cutting:
    The first step was the careful tracing of each of the 10 fins, according to SolidWorks plans.
    It's imperative that each is very well drawn, so that each of the fins is identical ...
    Once the tracing is complete, I marked the location of the two rotation axis:
    And then I drilled with the drill press to avoid skidding, the hole is 5.5mm, because the rotation axis are make in a rod 5mm
    and there will be 5 tenth of "game" to have no extra effort to the servo-motor.
    Then for cutting shapes, I assembled the fins into two groups of 5 attached by two bolts. :)
    The first cut was the front part of the fin:
    Then I then finished the back of the fins and their brackets:
    In the end there were almost as many waste as fins:
    I then bring the wings into a single group to be able to make all finishes exactly.
    Where you can seen, the right bracket is not identical in both groups:
    For finishes, I first made with a grinder and then with a lime,:) and here's the result:
    The next step is folding the first bracket, not quite 90°, because the form of the fins is a "V":
    Then I folded the second bracket, and finally I fold the center of the fins to give the "V".
    Below, some fins complete:
    And now here are the pictures of fins mounted on their rack: :):)
    And the photos in the box:
    And now an exclusive test with red neon! ;)
    He just have to polish them and make the connection rack drive... :)
    Don't hesitate to tell me what you think! :)
    yassarikhan786, Jimbob94 and Waynio like this.
  16. Waynio
    Waynio Relaxing
    20 Aug 2009
    Beautiful to see this bit done DIY style & done perfectly btw, you'll love it all the more with it being DIY +rep awesome update fangame :thumb:.
  17. microsoftPerson
    microsoftPerson What's a Dremel?
    27 Dec 2010
    This is a very cool design/project. Nice precision work.
  18. Angel OD
    Angel OD Pump Killer
    16 Sep 2007
    So much work for ONE feature! ... I FRIKKIN love it! :rock:
  19. nagyizom
    nagyizom Minimodder
    2 Jun 2008
    Wow, lovley This' ll be a lovely case!
  20. djzic
    djzic Bokehlicious!
    8 Nov 2010
