Scratch Build – In Progress Project "Fury" :) New Update (30-11-2011)! ,2nd November
Discussion in 'Project Logs' started by fangame, 2 Nov 2010.
  1. Waynio
    Waynio Relaxing
    20 Aug 2009
    :jawdrop: Fantastic mod :dremel::clap::thumb:. +rep if I can :D
  2. fangame
    fangame Newbie in Modding...
    1 Nov 2010
    Hello,
    I put my project on pause until July because the final exam of high school start the 16th june, and I must revise... :grr:
  3. fangame
    1 Nov 2010
    Hey! it's been a long time! :waah:
    But now that the exam is complete,
    I will be able to restart construction of the Fury project...
    Just for information, it's been a month and ten days that the system works
    So about fifty open/close cycle, and everything works perfectly.... :rock:
    I'm so happy:thumb::D
    Shael likes this.
  4. Shael
    Shael What's a Dremel?
    19 Jan 2011
    OMG :jawdrop: :jawdrop: i cannot belive i missed this log b4 :doh:
    truly and epic scratch build, your metal working skills, attention to detail and implementation of the cusotm fan by controller and especially the top air fins controlled by the internal temps is just insane :rock:
    Rep for this amazing worklog Fangame. And there is nothing "newbie" about your modding skilzz or this case wel done :clap:
  5. Waynio
    Waynio Relaxing
    20 Aug 2009
    :clap::rock::dremel::thumb:
  6. fangame
    1 Nov 2010
    Thanks! :):lol:
    So I have just sell my configuration in socket 775 today:)
    I think buying this setup for my MOD and I would like to have your opinion on:
    Motherboard: EVGA P67 Cheesecake
    CPU: Intel Core i5 2500K
    GPU: ATI 5870
    RAM: 8Go DDR3 Gskill 1600Mhz cas 9
    HDD: Samsung Sinpoint F3 1To
    SSD: Crucial M4 64Go
    So, if you have any opinions on it ...
    Thank you in advance!:)
  7. djzic
    djzic Bokehlicious!
    8 Nov 2010
    powerful stuff! But instead of the M4 SSD, go for an OCZ Vertex 3, and get a GTX 560 Ti ;)
  8. Cheapskate
    13 May 2007
    I agree with the :clap: and the :thumb: and the :rock:. This is a very well thought out and constructed chassis.
  9. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Me too! :clap: :thumb: :rock:
  10. fangame
    1 Nov 2010
    Ok, Thanks for your tips on the SSD! :D
    Just, what do you prefer in the Vertex 3,
    I never had a SSD so I do not know their positive or negative point ... :(
    And for the graphic card, I had got the 5870, last december for christmas, and I bought it on Ebay for 150€ , I think it's a nice price/quality rapport... :)
    :blush: Thanks for the compliment! Hihi:)
  11. Mataten
    Mataten What's a Dremel?
    5 Feb 2011
    Impressive design, impressive metal work and excellent performance in overall.
  12. praneetn7
    praneetn7 What's a Dremel?
    13 May 2011
    Alienware have nothing on you!
    I just wish I could do something as awesome as this!
    Top work :)
  13. fangame
    1 Nov 2010
    Thanks! ;)
    As expected the photos of the work made this weekend,
    To begin, I installed a CCFL on the top:
    Normally, there must be another CCFL in other side of the fan,
    except that his wire is too short
    And I must use a wire with silicone sheath
    due to the high voltage running through the wire.:duh:
    So I have to go buy this wire... :yawn:
    So I painted two pieces, the side cover which is placed next to the door, and a cover placed on the front:
    Then I glued the plate:
    PS: Sorry for the dust on the photo, I have not look this when i take the shot... :)
    Then I painted the top grid:
    Once the grid dry, I marked the holes emplacement of the fins rack.
    And finally, I pasted the grid this morning... :)
    Pictures soon! :D
  14. fangame
    1 Nov 2010
    New update, photo of the top grid and painting of PCI bracket. :)
    Here is the pasted grid the other day:
    And now the pictures with the system of fins:
    And then, I had recovered PCI brackets on an old PC case:
    So I have first scratched with sandpaper,
    Then I have set a first layer:
    And finally a black satin paint layer:
    Here, they are installed in the case:
    Finally a small photo of 6 "32 screws that a person has send me.
    They will be used to replace the 3mm screws I have used to fix my HDD...
  15. fangame
    1 Nov 2010
    Hello!
    I have come back to my holidays yesterday and I continue the work tomorrow, picture soon! :dremel::D
  16. The boy 4rm oz
    10 Apr 2008
    I look forward to seeing some updates :thumb:.
  17. fangame
    1 Nov 2010
    It's nice to follow my project! :)
    Here is the work I did earlier this afternoon,:)
    So, I don't know if you have seen this but my CD and my Rheobus was not so horizontal,
    It was because a bracket of the support is shorter than the other...
    So today I removed the rivet, then I inserted two washers between the plate and the support and it gave me support right :D
    The washers may not be beautiful but they are hidden
    so not too many problems ...
    Otherwise, I made another mistake, in a rush, I welded the mounting brackets of the lateral door "fury",
    forgetting to cut the lateral/front cover,:duh:
    So, I cut the surplus in my door to get a good square:
    And I bought a piece of sheet metal to rebuild my cover... :(
  18. fangame
    1 Nov 2010
    Hey! New Update ...
    First, I want to thank Stefan of the newly Swedish company Djungelapa for its support,
    The company dedicated to PC modding manufactures and sells rigid or flexible sleeve, black screws or fan grids...
    I invite you to visit their site very well done and well stocked! :)
    http://www.djungelapa.se/
    I wait impatiemment the package,
    with which I will sleeving all my power supply and
    I also want make all the SATA and Molex cable at the good size...
    I have chose principally black sleeve that I complete with white and red sleeve
    to recall the colors of the new motherboard and air cooling system! :)
    I will post pictures of the products when I received the package!
    Again thank you to Djungelapa! :) :)
  19. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    hehe i see that a good friend of mine has helped you with your nice project :), nice chose of colors, you wont regret the awsome quality of sleeve that he sells? did you btw ask for regular sleeve or the Fabric-look sleeve???
  20. awok3N
    awok3N Who dares wins.
    18 Jul 2011
    dem fins! looks cool mate
