Scratch Build – In Progress Project : Future Schlock by AnG3L (15/October Let the bench Saga begin!!)
Discussion in 'Project Logs' started by AnG3L, 9 Jun 2010.
Simple paint or aluminum engraving
Poll closed 4 Jul 2010.
  1. Simple powder coating
    9 vote(s)
    27.3%
  2. Aluminum engraving with circle based designs and then powder coating
    24 vote(s)
    72.7%
  1. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Thanks man!! ;) Really appreciate it!
  2. ModaRobby
    ModaRobby What's a Dremel?
    5 Aug 2009
    If you don't mind me asking (and I would love an answer from everyone) how much does laser/CNC cutting usually run?
  3. AnG3L
    19 Mar 2009
    If you mean how much it costs it depends from a million reasons, the guy on the factory explained me but it was all messed up. Its had to do with the quantity, how thick , soft, hard the material is,(hard material - more time - more money etc) and many other reasons. If you send a dxf file (auto cad) with the drawings and the material you want to cut they will calculate the time and materials needed and they will tell you a price. Usually is like 160-200 dollars per hour. CNC is cheaper though but is totally different than laser. Costs less and works mostly with acrylic and wood or soft materials.
  4. AnG3L
    19 Mar 2009
    I would prefer waterjet though is some cases but is way more slower and more expensive in my country.
  5. ModaRobby
    5 Aug 2009
    How much stuff can get cut in one hour? I would consider doing it if I could give them one huge sheet of aluminum and just get all my individual pieces from that. CNC is basically a gigantic router right?
    I'll just have to call around to a few places after I move north.
  6. douglatins
    douglatins What's a Dremel?
    28 Nov 2009
    Laser cutting = $$$
  7. AnG3L
    19 Mar 2009
    If you consider that buying a good case worths like 300 dollars and more, then its not expensive,
    because I payed less and my case will be bigger, wider and... nicer!!!
    It really worth it, if you have the patience and passion and some knowledge you can make your own case and you are going to pay less.
    I knew nothing about corel draw, I learned everything by myself and.. voila! I am building my own
    case which I really love! ! ! :) :rock:
  8. ModaRobby
    5 Aug 2009
    Well I will have to check that out. I expect great things from this thread.
  9. AnG3L
    19 Mar 2009
    Thanks man I ll try to do my best as each time! Monday is the beginning! :)
  10. Mikeyfly300
    Mikeyfly300 Modder and lapping specialest
    25 Jan 2010
    Another masterpiece from AnG3L :jawdrop: I will be camping big time for this
  11. AnG3L
    19 Mar 2009
    Thank you Mickey my brother, much appreciated!! :)
  12. AnG3L
    19 Mar 2009
    Stainless steel????? Anyone ^ ^ ?
  13. Cheapskate
    13 May 2007
    Polishing stainless can be done, it just takes a long time to get everything sanded down. The sandpaper will wear out faster too.
    You should know my routine by now. Start with 150 grit, and work your way down to 600. A chrome polish should be able to handle the rest. Make sure the sanding strokes run in the same direction.
    They also make felt disc buffing kits that fit into a drill. They usually come with coarse, medium, fine, and polish compound and a disc for each. If you're going to be buffing a lot of stuff, you might want to look into that option.
    -Like what I'm seeing so far.:D
  14. nhojnomis
    nhojnomis What's a Dremel?
    24 Jul 2009
    Isn't La carotte d l'o the godfather regarding polishing steel with his epic Windrider thread? He probably knows everything you need.
    Looking forward to another shiny beauty.
  15. AnG3L
    19 Mar 2009
    Cheaps my friend, thanks for all the info, I ve watched some videos and also studied some websites about that matter and indeed this is the way! My problem though is the interior designs and their edges of the fangrills. I found some dremel bits that probably are made for that purpose but I am not sure if its going to work. I will start working on the back side of the switch housing thingie to see how that works and let you know in the progress! Thanks Cheaps, its not your fault though :lol: :lol: :thumb:
    OMG I forgot about that! He is my friend but I completely forgot about him :wallbash:
    Thanks buddy! :D
  16. Bad_cancer
    Bad_cancer Mauritius? 2nd speck east of africa
    7 Apr 2009
    Someone steeped up the fabrication techniques. Gone are the dremel cut holes and the recycled hardware.
    Angel has evolved! :p
    Nice work dude!
  17. AnG3L
    19 Mar 2009
    LoL @ crazy comment! Thanks mate! ;)
  18. DeadP1xels
    30 Nov 2009
    I've been away for the weekend but i must say you have made some great progress to this im really looking forward to how this is going to unfold!
    Love the cage and grills!
  19. AnG3L
    19 Mar 2009
    Thank you my dear friend, an update is coming soon enough so stay tuned! :)
  20. Editor22
    Editor22 E22 | Hex-Gear
    3 Jan 2009
    Wow this is just pure win angel! I loved your designs in past projects so its great to see you holding to your roots even though you've evolved onto bigger machinery :)
    mod on mate
