Scratch Build – In Progress Project: G5 Wannabe 30.12. 07. - lightning
Discussion in 'Project Logs' started by eXplode, 16 Dec 2007.
  1. eXplode
    eXplode sound freak
    1 Dec 2007
    @all Thx!
    @ francisl1420
    well, you are scratching from one side, and little bump is making on other side cos u are applying preassure on sharp tiny point. so u sand of the bump that creates.
    u can see the bump on this pic. click it to enlage so ull see better
    @cheapskate
    I like taking safest way even if its longer one. I took quickest way too many times that soon turned into longest on the long run :D
  2. Colossous
    Colossous Minimodder
    28 May 2007
    Fantastic work eXplode !! Were the screws you used there hardened ? It must have taken an age to score it through ? :thumb:
  3. eXplode
    eXplode sound freak
    1 Dec 2007
    Thx colossous. I really dunno about screws. Just regular screws that i had. They didnt loose sharpnes even after cutting. It actualy didnt take that long since there were 5 circles to cut. around 2 hrs from be4 scatching to finished cutting.
  4. Colossous
    28 May 2007
    Well great work and perseverence dude ! :D
  5. headala
    headala What's a Dremel?
    9 Oct 2005
    I like it, Subscribed!
  6. eXplode
    eXplode sound freak
    1 Dec 2007
    Hi all,
    here goes another update :p
    This is difference beetween shiny and opaque transparent coat...
    i choose shiny.
    I started to put computer inside..
    i made wooden block 4 reset button cos it was too far out..
    anti vibration fan mounting
    anti vibration disk cage mounting
    anti vibration psu dampers - mouse pad material used as in dvd cage
    lightening sign:
  7. eXplode
    eXplode sound freak
    1 Dec 2007
    The morning after :D :duh:
    much better now.
    and baby comes home :p
    lightning was too crapy, cos i didnt put enough leds. so ill show u lightning next time.
  8. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    is that an acrylic cover for your CPU cooler?
    but the case looks great.
  9. wbdog206
    wbdog206 not me
    15 Jan 2007
    looks really good.
  10. eXplode
    eXplode sound freak
    1 Dec 2007
    Clear coat fixed that "dirty look" of brushed alu wich u coud see on previous pics. And its semi reflecticve. Yes, thats acrylic mask on cpu cooler...
    OT: Who is that felix guy and why is everyone having him on their avatars? :worried:
  11. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    I've always wondered that too tbh, lol.
  12. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    its relix not felix! lol and dont ask or you will have him as your avatar aswell.
    o and nice project i like it.
    josh
  13. eXplode
    eXplode sound freak
    1 Dec 2007
    thx x06jsp!
    Hi Guys.
    The continuation....
    I like smoked glass look, so i wanted to give it to acrylic window on teh side panel, i sanded it with 1000 grit and it was fine. But problem is that it gets "dirty" look very easily. and fingers stay on it. so i decided to go over with opaque coat.
    then i wanted to get more blur, but how? we dont have fancy special finishes here :nono: :sigh: i tryed some pattern - mosquito net under plexy.
    and it was fine for a few days... then this hapened:
    Acrylic started to degrade :wallbash: It obiviusly didnt like clear coat.
    Anyone knows how to avoid this behaviour?
    I think i'll just make alu panel and give up on window idea.
    Happy hollydays!
  14. 500mph
    22 Jun 2007
    i remember reading somewhere about a liquid that would give acrylic the translucent look just by rubbing it on. i hope someone where knows what it is.
    also, did you change the logo color from green to red?
  15. eXplode
    eXplode sound freak
    1 Dec 2007
    That woud be great, but if it is "special" liquid just 4 this purpose, idont think we will have it here in croatia :/. I tryed looking shops 4 any kind of special finishes and no luck.
    And yes, i changed logo to red. Green didnt blend well with the room colours. I'll post that pictures later.
  16. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    That liquid would be acetone :) You can 'frost' you plexi with it, so it might work for your purpose. It doens't affect AC-Ryan acylic though, but it will affect most other brands.
  17. eXplode
    eXplode sound freak
    1 Dec 2007
    Great! Thats common liquid, I can buy it easily. Thx on info. I'll try it tomorow. :thumb:
  18. Cheapskate
    13 May 2007
    Was that extruded plexiglas? The cell cast stuff is more resistant to paints.
    You may have found a trick I've been looking for. I've been trying to age and stain plexi like the stuff I used on Hypnotoad, so the type of plexi and paint is something I would like to know.
    Acetone works good as a plexi glue, too.:D have fun! Read the safety stuff on the can. Acetone STINKS!!
  19. eXplode
    eXplode sound freak
    1 Dec 2007
    pic
    here is pic of acrylic and coat, but if u look it closely ull c that degradation is concentrated around edges, and it is consistant with finger paterns when u hold it in hands. im sure fingerprints are somhow conected to this. u better try on small piece 1st. gl.
  20. radodrill
    radodrill Resident EI
    14 Mar 2006
    Possibly you had some oils/grease/etc on your fingers while handling the acrylic; they do attach acrylic over time, and the paint probably didn't help either.
    I generally "frost" acrylic by wet-sanding with 200-400 grit sandpaper.
