Scratch Build – In Progress Project: GALLUZZO-I < 2 Aug. update: Swithes >
Discussion in 'Project Logs' started by L1U, 1 Sep 2011.
  1. L1U
    L1U Minimodder
    1 Sep 2011
    update 6 - the 3½ drives slot (list of all updates)
    like the update title said, today's i'm dealing with the 3½ drives slot. I plan to use 2 slots in there: one for the fan controller and the other for the usb/audio interface.
    enough talknig, let's get some modding action in there :dremel:
    first: cutting the wood top panel
    guidelines for the steel backplate
    and dremel power
    putting the panel back in place before drilling the mounting screw holes
    screws in place with the bolt fitted in the wood itself
    some super-glue to hold the bolt in place (will be helpful when mounting things from the inside of the case)
    dremeling the side-supports from a chunk of 1mm steel
    the bending
    the result
    fast test with a spare floppy-drive
    view from behind
    acrylic cover cutting
    and finalyy in place (note that the butterbly bolts are momentary, will be replaced with something better)
    the case up-to-date
    that's it, i think i'm not going to update soon the case (at least not this week) i got some exams coming and i really have to focus on those :wallbash:
  2. L1U
    L1U Minimodder
    1 Sep 2011
    update 7 - the case feet and cover-support (list of all updates)
    the exam went pretty well, so i have some time today for another woodworking update!
    cut out some more silver fir pieces
    L-joints to fix them to the bottom of the case
    in place already!
    preparing for the rear joint
    there it is (these will fix the feet to the back of the case)
    view of the bottom of the case, with a little front panel added
    all mounted
    cut some wood bar in 45° angles
    pretty good joint result
    added a couple of hinges for the top.grill and filter
    up to date!
  3. L1U
    L1U Minimodder
    1 Sep 2011
    update 8 - the intake grill and dust filter (list of all updates)
    I started with a sheet of 1.5mm german silver kindly offered by Picchiani e Barlacchi (many thanks :clap:), in which i dremeled the hole for the grill and the dust filter
    sorry for the bad pictures quality, dad took the camera today and i had to manage with my phone's camera that is not really good
    then i cut the alu grill
    first impression
    then i cut and bent some other metal parts
    a nice and thick piece of white foam (approx 6-8 mm)
    white adhesive sheet to cover the metal support
    the result
    the result after fixing everything with rivets
    the back of the filter
    in place, flipped view of the bottom of the case
    and the view from inside the case trough the fan holes (only the foam is visible)
  4. craig - toyoracer
    craig - toyoracer Minimodder
    1 Mar 2011
    L1U case is getting some style with those ribs added. Good job on the base and filter. Keep having fun :)
  5. L1U
    L1U Minimodder
    1 Sep 2011
    thank you! the ribs are the support for the final cover (that will be metal covered with white adhesive tape)
  6. riekmaharg2
    riekmaharg2 has completed the PowerCore scratch build
    22 Feb 2009
    Nice mesh panel :thumb:
  7. Herodj95
    Herodj95 What's a Dremel?
    9 Sep 2011
    Very good job! I like the desing of this case!
    PS: i'm italian too :D
  8. L1U
    L1U Minimodder
    1 Sep 2011
    thanks riekmaharg2! I'll use the same system for the exhaust grill :D
    piacere di conoscerti Herodj95, io sono di Firenze! :clap:
  9. Herodj95
    9 Sep 2011
    io invece sono del sud italia... vengo da catanzaro :)
  10. L1U
    L1U Minimodder
    1 Sep 2011
    update 9 - case fans and front panel (list of all updates)
    today I'll be installing the 5 case fans, 3 intake and 2 exhaust, the front usb and audio panel and the fan controller.
    let's start with the fans, I purchased some Bitfenix SPECTRE fans from caseking with my own founds
    I started pulling away the ugly rear sticker and replacing it with white adhesive tape
    then I went to the top wood frame and painted it white
    Then I disassembled the base of the case and the steel sheet
    mounted fans and grills
    I used 2 Y splitters to power all the base fans with a single 3-pin cable, I should not have any power issues as long as the total amperage of the fans is less then 3 A
    fans in place, view from the bottom of the case
    sliding the fan grill in place
    view from the inside of the case
    then I went to the top exhaust panel, mounted it very straightforward with no difference from the bottom panel
    again, I used a Y splitter to power the fans together
    in place, view from the back (top of the case)
    the adapter coming out from the panel
    I purchased also a fan controller and an audio/usb panel with my own founds
    the top panel in place with the 2 front panels mounted too
    the panel open
    the top
    the bottom
    more details
    full view of the case with the side panels off (I'll have to work on them soon enough)
    that's it!
    I hope you enjoyed the update!
  11. Herodj95
    9 Sep 2011
    fantastic! :D :clap:
  12. AnG3L
    AnG3L Ultimate Modder
    19 Mar 2009
    Really nice mod my friend keep up the good work!! :)
  13. MiNiMaL_FuSS
    MiNiMaL_FuSS ƬӇЄƦЄ ƁЄ ƇƠƜƧ ӇЄƦЄ.
    24 Dec 2003
    use of a gentleman's saw = uber win.
    Not seen one since I was a school boy, well done sir.
  14. L1U
    L1U Minimodder
    1 Sep 2011
    thanks again herodj95!
    Thank you AnG3L I will!
    haha, I used a gentleman's saw because I don't have a circular saw, the cut isn't actually very very precise :p
    Unfortunately, I can only work with the tools I have, hoping I'll be able to do better with my next mods :thumb:
  15. L1U
    L1U Minimodder
    1 Sep 2011
    update 10 - top grill and fans test (list of all updates)
    out of a bigger slate I did cut the structure of the grill
    cut the grill
    drilled holes for rivets
    parts ready to be assembled
    putting the white adhesive on the structure and fixing everything with rivets
    detail of the joint (the rivets excess has been cut before mounting everything on the case)
    and finally in place
    for the testing i made a little video with some annotations
    sorry fot the terribad video quality... but you get the idea :D
  16. RedManc
    RedManc What's a Dremel?
    30 Jul 2011
    Im liking this more and more the top and bottom panels are nice cant wait to see the next few updates
  17. L1U
    L1U Minimodder
    1 Sep 2011
    you are served my friend, I had some time this afternoon so I kept going with dremel and drill :D this is what came out
    update 11 - the front panel and power button (list of all updates)
    the front panel will be german silver (got it from my sponsor Picchiani e Barlacchi) covered with white adhesive tape as the rest of the external structure
    started bending and dremeling to an appropriate size the metal
    hold it in place for the guide holes
    drilled a hole for the power button (I didn't have a 16mm drill so I used a smaller one and used a round file to enlarge it to the appropriate size)
    detail of the hole (don't bother the scratches they'll be covered)
    the power button coming out from behind
    and there it is, held in place by 10 little screws, perfectly matching the rest of the case!
    that's it for today (I swear :p) hope you enjoyed the update!
  18. Herodj95
    9 Sep 2011
    Gooooooood! :clap:
  19. Travel'Ed
    Travel'Ed What's a Dremel?
    2 Mar 2011
    Hi,
    i like sthe wood structure, with white painted metal.
    look great, go on :thumb:
  20. mat0tam
    mat0tam Mr I Dont Know What I Want
    1 Sep 2011
    Gorgeous, glad i subscribed to this :)
