Scratch Build – In Progress Project: GALLUZZO-I < 2 Aug. update: Swithes >
Discussion in 'Project Logs' started by L1U, 1 Sep 2011.
  1. peteski
    peteski long live the pc
    8 Jun 2011
    grate work l1u cant wait to see the finished case
    subscribed :rock:
  2. bguilleminot
    bguilleminot New Member
    11 Aug 2011
    Excellent work L1U, I will be following you ;)
  3. L1U
    L1U Member
    1 Sep 2011
    grazie!
    thank you, glad to hear you like it ! :D
    will take a while trough to get it finished
    thank you, i'll keep you updated!
    thanks mate!
  4. L1U
    L1U Member
    1 Sep 2011
    update 12 - mobo tray (part 2) (list of all updates)
    hi guys, this is a big one! Today i'll be installing the system tray, the fornt tray and the HDD enclosures, anong with all holes for cables and stuff! :D
    let's start with some holes, this is the one behind the power button
    then I started working on the mobo tray, drilling some guide holes, tapping some holes and that king of stuff.
    I'll be adding a detailed view of the holes down here, now some self-explaining images of the work I've done
    these are the different systems used for screws and standoffs to have everyting working as expected
    front 1
    front 2
    rear
    with that big chunk of work done, I started working to the front tray.
    re-drilling some holes and removing the protective film
    installing grill and fan
    close-up
    I bought a pair of HIMURO's with my own founds, these are intended primary for sound-dampening because I read in many reviews that the heat dispersion is not really outstanding with those... so it's not the point ;)
    the HIMURO's
    then I just remounted everything together, the side panels and the back panel, the HIMURO's etc...
    this is the result
    and obviously...
    ...the mess is behind :hehe:
    that's it with that big update! I hope you enjoyed it! :D
  5. peteski
    8 Jun 2011
    man sweet build so far i really like the whit acrylic
    + rep :rock:
  6. RedManc
    RedManc New Member
    30 Jul 2011
    looking really good, I might end up using that psu wire pass through idea
  7. L1U
    L1U Member
    1 Sep 2011
    thanks for +rep!
    really? got to see that ;)
  8. L1U
    L1U Member
    1 Sep 2011
    hey guys, I'm looking for an advice, someone knows where I can buy matte white ATX connectors and pins like these in europe?
    [​IMG][​IMG]
    I need 24/8/6/4 connectors
  9. peteski
    8 Jun 2011
  10. L1U
    L1U Member
    1 Sep 2011
    these are not la little transparent? I was looking for matte white (like bitfenix's extensions)
  11. peteski
    8 Jun 2011
    Sorry didn't relies :wallbash:
    :rock::rock:
  12. riekmaharg2
    riekmaharg2 has finished Blue Horizon
    22 Feb 2009
    This builds coming along very nicely :thumb:, cant wait to see how it will look when finished.
  13. L1U
    L1U Member
    1 Sep 2011
    thank you!
    I've beeh busy in the last days preparing a big update about the side windows, I may be able to post more about it in the weekend!!! :dremel:
  14. L1U
    L1U Member
    1 Sep 2011
    well well...
    guys, I realize it has been incredibly long since the last update and I really apologize to all of those among you that are following the build :sigh:
    sooooo.... just to let you know I'm still working hard to have that project done, I've prepared a little update video teaser in an absolute no-logical order about the upcoming updates! :D
    I hope you like it!
  15. L1U
    L1U Member
    1 Sep 2011
    hi guys, there will be more stuff coming soon so I decided to put some order in the thread before that moment... :idea:
    I added a list of all the updates in the first post and a link to that list in all of the update posts, so it will be more easy for you to follow the history of the project even without the "View Author's Posts" tool.
    If you have any other suggestion about the project or about making the thread more user-friendly I'll be glad to hear :thumb:
  16. jeckulz
    jeckulz New Member
    18 Jan 2011
    Coming on nicely.
  17. Canardwc
    Canardwc Gentel-Mod'R
    22 Sep 2011
    Looks pretty nice!!! how will you take for the side of the case? Aluminium?
    other stuff, why do you still use a floppy drive? Now, you can boot on esb key?
  18. L1U
    L1U Member
    1 Sep 2011
    thank you! :D
    the side will be transparent perspex and wood, and I have an idea for lightening the perspex itself with a couple of neons
    :idea::idea::idea::idea: i'll let you guys know if that works
    the floppy drive was just a test for the size of the rheobus and usb hub:
    the test
    the real stuff
  19. Device Unknown
    Device Unknown New Member
    13 Jul 2011
    What's with the pink house in the video? to each his own I guess lol
  20. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    Case looking good. Nice combination. How will the wood be finished? (painted, stained, varnished?)
