Scratch Build – In Progress Project: GALLUZZO-I < 2 Aug. update: Swithes >
Discussion in 'Project Logs' started by L1U, 1 Sep 2011.
  1. L1U
    L1U Minimodder
    1 Sep 2011
    update 23 - Sleeving and pass-trough (list of all updates)
    Hey guys! I'm back with some more slleving today!
    But first, come custom perspex parts to be used in the process :dremel:
    Drawning reference points and lines
    a little cutting
    measuring sleeved cables diameter: 3.00 mm
    drilled holes
    and sanded the edge: 320-600-800
    parts done for the 2x6pin connectors
    removing pins
    pass-trough
    first impresion mounted
    now working on the 8-pin EPS
    parts
    8-pin EPS result
    and finally 24-pin connector
    done for today!
    see you soon for more updates!!!
  2. Martininho
    Martininho What's a Dremel?
    8 Feb 2012
    Neat looking project. Guess ill have to start doing something soon too :( :rock:
  3. L1U
    L1U Minimodder
    1 Sep 2011
    update 24 - Light Switches (list of all updates)
    Hi guys, its'been a loooooooooooooooooooooooong time since my last update, I had a really hard time studying and some quite tough personal stuff going on too...
    BUT
    now I'm back (yay!)
    Today I spent some time building the little switches panel for the rear of the case, it will also work as a pass-trough for cables to the mobo
    the revoltek cold cathode's pcb naked
    panel installed after soldering the neon power cables to the switch
    enough for today, more updates very soon (I promise) :D
