Case Mod - In Progress Project: Gearbox 2.0 - mini P180 Back to Basics
Discussion in 'Project Logs' started by THEkorean, 2 Jun 2007.
  1. THEkorean
    THEkorean 42
    10 Jun 2005
    Hey guys, its me again thank you for continuing to show interest in my project, it means alot to me :D..
    But, I have some bad news, I need to get this thing show ready in a little less than 2 weeks and the motherboard cover is nowhere near completion so im putting it on the back burner, Its not a completely necessary mod, and in addition to that I'm frustrated in my search to find an adequate chemical bonding agent for aluminum. I will make some temporary mods to the mobo tray until i can come up with a third revision for the tray.
    So here is the work i HAVE gotten done:
    got new fittings for the VGA block (koolance swivel, 90 degree fittings)
    stubby EK fittings for small space between pump and radiator
    a 1'x1' aluminum sheet
    DISCLAIMER: the photos are dark, my camcorder does not have flash, I have to work in the dark since I only have 1 immobile lamp in my room :( sorry
    fitted new loop
    filled the loop
    here it is sitting inside the case
    trimmed the bottom of the PSU vibration dampener. It was causing clearance problems.
    here it is installed
    shortened SATA power wires (not sure if you can see, but the power connectors fit perfectly with no excess wire hanging out
    Today, i went around driving to different hardware stores to pick up various workshop necessities (masking tape, compass, rulers, drill bits, etc etc.) and began working on the rad grill, check it out:
    cool no?
    close up on the project logo, it will go on top of the case along with the grill
    took it to the scrollsaw and did this much before i broke 2 blades, i figured it was time to stop and try again tomorrow when I'm fresh.
    Anyways, thats it for now
    Until next time!
  2. Teyber
    Teyber ******
    18 Mar 2007
    ah great work :D
    Love the fan grill!
  3. THEkorean
    THEkorean 42
    10 Jun 2005
    woa.. cute/weird/disturbing
  4. Teyber
    Teyber ******
    18 Mar 2007
    edited.
    id love to see some pics of the complete fan grill sketched out.
    stealth looks amazing:clap::clap:
  5. Guest-23315
    Guest-23315 Guest
    Looks good.
  6. cheezeit
    cheezeit What's a Dremel?
    29 Aug 2007
    Wow, this is a really nice mod. Cant wait until the next update.
  7. THEkorean
    THEkorean 42
    10 Jun 2005
    Go the grill mostly finished today:
    There it is cut and mostly filed
    I put it on top of the fan holes and didnt like it at all
    So i sketched a 2nd layer on Plexi
    darkened with Sharpie marker
    Sneak preview
    clamped and cut
    filed with metal files:
    wasnt cutting it so i went to the dremel sanding drum
    did the corners with a smaller file
    finished with 150 grit sandpaper
    Theres still some more work that needs to be done on the grill, ill finish it tomorrow.
    Until next time!
  8. cheezeit
    29 Aug 2007
    I like this mod, keep up the modding!
  9. jfab199+
    jfab199+ What's a Dremel?
    28 Oct 2007
    great work so far, any thought on mounting the PSU on the outside, if I had the $ I would like to have the same case but I thought about how to mount it like that so there would be more room in the case for a bigger air cooler
  10. Cheapskate
    13 May 2007
    Everybody! -let's poke THEkorean with the stick 'til he gives us an update!:D
    -poke
  11. karbonKid
    karbonKid Minimodder
    5 Jul 2006
    *poke*
  12. MonkeyNutZ
    MonkeyNutZ Crysis Fiend
    5 Jun 2007
  13. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    Edit: I wasn't thinking straight, sorry for that ;)
  14. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    *poke*
  15. Dean MF
    Dean MF PC Freak!
    20 Apr 2007
    *poke*
  16. Cheapskate
    13 May 2007
    It's not working...
    Maybe if we poke him harder?
    *poke*
  17. Brett89
    Brett89 Minimodder
    15 Dec 2005
    *POKE*
  18. MoRBiD
    MoRBiD Minimodder
    27 Jun 2007
    P
    O
    K
    E
    :sigh:
  19. HeXeN
    HeXeN Straight from Hell
    14 May 2006
    * P O K E *
    a little update ? :(
  20. Thacrudd
    Thacrudd Where's the any key?!?
    27 Oct 2006
    C'mon guys not to hard, we don't want to injure him.
