Project: GEARED UP. More tinkering! 10/3.
Discussion in 'Project Logs' started by grumblemarc, 20 Mar 2005.
  1. grumblemarc
    grumblemarc New Member
    12 Dec 2004
    Good and bad news.
    Got a hold of a 6800GT that my Cool-Matic was just waiting to meet. :D
    Problem was that once mounted to the vid card the block wouldn't allow the card to work and the rig would not boot. I spent the better part of a day and a half monkeying around with the setup and also managed to fry a stick of RAM when I sprung a small leak that I didn't get to in time. :wallbash: :wallbash: :wallbash: No big deal there since I just got a wad of cash for a spare box I wasn't using (talk about timing). I think I'll go for 2 1 gig sticks. Photoshop CS2 is a RAM hog. As for the GPU block I don't know what I'm doing wrong but I'll figure it out...later.
    The good news was that while I was disassembling and reassembling things I managed to drop the CPU temps by 10 degrees celcuis. I think that I reseated it about 20 times. So that seems to have done the trick.
    I did get the Aquadrive LT installed but I haven't added it to the loop as of yet. It helped load for the noisy drive and the temps but I got tired of handling distilled water treated with Innovatek Protect. It has the consistency of antifreeze so the HDD blocks remain dry.
    I have plans for a lot of plexi for the interior as seems to be the norm for case mods nowadays. I found a place that does lasercutting for a pretty cheap price. After which I'll try my hand at polishing up those aluminum rings. I'd say I'm about 75% complete with this build.
    More later.
  2. grumblemarc
    12 Dec 2004
    Well. A little over a month with no updates. Anybody miss me?
    Probably not.
    Anyways. I finally got off my duff and started polishing those
    aluminum gears. It was NOT fun let me tell you. I polished the
    first of them by hand until my fingers almost fell off. THEN I got
    smart and wrapped my polishing cloth around a sanding block
    and just leaned into it. It cut the work down to 20 minutes
    per gear from 45.
    The before pic.
    And After. Check it out.
    Looks pretty good if I do say so myself. And I do say so.
    I didn't go for the ultra mirror finish like Coolermeister did with
    his case but I came pretty close.
    There'll be more pics since I still have 8 more gear rings to
    polish up. When I get to those I'll try to get more in progress
    pics since you guys seem to thrive on those.
    AND....
    Not that I'm into all the "Oooh! Look what I bought!" stuff but
    since I'm slacking with the lack of pics I think I need to make up for
    it somehow.
    First off is the Hiper PSU I picked up (newly available in the US!). It's NIIIIIIICE! Shiny black and all. The whole things modular with
    the exception of the motherboard connection. I won't load up a
    bunch of pics here since this thing has been reviewed on other
    sites more than enough.
    Second is the Deck keyboard I've been typing this post on. I must
    say that it is something else. It is much smaller than I thought it
    would be but I've got no complaints. It frees up a lot of space.
    The feel of the keys cannot be described. VERY responsive.
    Overall a very rugged unit. Now when they come out with the
    10-key pad I'm snatching up one of those as well. *And as of this
    writing they are! Ask ye shall receive.
    Lastly I'm on my backup Gigabyte board since I fried the first 2 RAM
    sockets due to my spillage last month. It will be the last 754
    board I buy. And to put in it I got 2x1gig sticks of Mushkin to
    replace the ones I ruined. No pics since thet're in the rig
    running. Maybe next time.
    Until Later
  3. crazybee
    crazybee Black & Yellow
    8 Apr 2003
    loving the polish job on your gears, how you get the Alu so polished? wouldnt mind doing that on some bits when i get some alu to cut and do some with myself
    sorry to hear about the leaks :( I'm kinda getting ready to do some W/C myself and scared silly about leaks, at the moment only planning to cool CPU and maybe northbrigde
  4. MrBurritoMan
    MrBurritoMan New Member
    27 Jun 2004
    mmmmmmm blue black and shiny objects, man such a nice mod. keeping an eye on this.
  5. grumblemarc
    12 Dec 2004
    Thanks. Don't worry too much about leakage. It was my own fault. Didn't make sure a connection was as secure as I thought it was.
    to get the shine I used various grits of sandpaper 200-600 then went to a polishing compound called Maas. I applied the compound to the surface of the aluminum and polished away. That took a long time to get results. I soon found that wrapping the polishing cloth around a sanding block quickened the polishing process greatly. I layed the gears on a piece of scrap wood and just leaned into it.
  6. iMaGiNe
    iMaGiNe New Member
    24 Jul 2005
    Vey nice!!! Good Job :thumb:
    Just wondered about those Hiper R's... how loud are the PSU fans?
  7. grumblemarc
    12 Dec 2004
    Haven't installed it yet but I'll be swapping out the fans this weekend anyway. The black PSU's don't have LED fans in them. The blue ones do however. Go figure.
  8. kaotic504
    kaotic504 New Member
    20 Jul 2004
    i always did like this project. great work!
  9. grumblemarc
    12 Dec 2004
    Decided to move to the other side of the case and finish the polishing job on the rings on that side.
    This time I have a better step-by-step of the process.
    Let's start with the obligatory "Before" shot.
    This is pretty much raw aluminum. It's pretty soft relatively speaking so It doesn't take as much effort to polish as I thought.
    The tools and materials I used are as follows;
    Orbital palm sander
    Sandpaper-400 grit, 220 grit, 120 grit.
    Sanding block
    Maas polishing cream
    Polishing cloths
    Large file
    Starting with 120 grit on the sander we end up with...
    this at the halfway point.
    I used this grit as the metal is lightly gouged up and this knocks the "edge" off. I moved on to the 220 grit and wound up with...
    Not a good pic I must admit but maybe you can see the transistion as the paper transitions to a finer grade.
    Here is the whole ring done after 220 grit.
    I couldn't find any sandpaper to fit on the sander in a finer grade so I have to move on to this.
    Sanding block and 400 grit paper.
    The ring after a bit of elbow grease was applied to it.
    At this stage it is very smooth but you can stil see the swirl marks all throught the piece. On the previous rings I moved on to 600 then 800 grit paper at this point but I was extra thorough this time so I felt the extra grit wasn't necessary. My arms and shoulders were in agreement with me so it was on to the polishing.
    Here I simply took a polishing cloth and wrapped it right around the sanding block I was just using.
    I applied the polishing cream to the ring thusly.
    And after just one go of the sanding block wrapped in polishing cloth we can already see the reflectivity of the new surface of the metal.
    A note that while I was polishing I could feel the surface getting smoother as the Maas was doing it's thing. You couldn't see it because of all the black mess but you knew. After a while the black mess went away and you could start to see things in the surface of the metal.
    I went about 4 rounds with the polishing before I was satisfied with the results.
    Not quite the mirror finish it could be but I'm more than happy with it.
    Finishing up I took the rings back to the empty space that they now call home.
    I have the rings mounted to the panel with some 6/32 socket head screws and acorn nuts. The mesh is sandwiched between the 2 rings
    Here it is mounted back on the side panel. Whaddya think?
    Before they were mounted I took a large file to the edges of the rings to smooth things out.
    Well that's that. I TILL have the 6 gears to do on the top of the case. When I I do I'll take a bunch of "money" shots. Chris over at Custom Watercuts has been waiting for these to get finished for quite some time. He says that he's gonna feature the case on his site as soon as I get pics to him.
    Until next time.
  10. Starbuck3733T
    Starbuck3733T Look out sugar, here it comes
    16 Sep 2002
    Hawt damn. haven't seen this log for a while (shame on me for not sub'ing). I'm glad to see you're still working away on it.
  11. RadeX
    RadeX New Member
    1 Sep 2004
    cool, nice job there man :)
  12. MrMan
    MrMan New Member
    5 Jun 2005
    i'm in love..... thats just simply stunning mate i love it great ideas
  13. grumblemarc
    12 Dec 2004
    Thanks guys. Glad to know the hard work is appreciated.
  14. g0th
    g0th New Member
    12 Apr 2005
    You can probably use that electric discharge plate thing from the PSU's 12V supply rail - it would almost certainly be rectifiying the input to DC.
    Can you provide a good closeup pic of the components on the PCB?
  15. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    I like it very much!
    Nice ideas, contrary to some others I like how you put the power supply wires in the clear tubes (without any covering so you see red-yellow-black)
  16. grumblemarc
    12 Dec 2004
    I'll see if I can dig it up. I did some rearranging in the house and now I cannot find anything.
    Glad you agree.
  17. Pete_Venkman
    Pete_Venkman New Member
    20 Jul 2005
    NICE work on the polished rings, very impressive.
  18. grumblemarc
    12 Dec 2004
    Okay. Not had a lot of time to do much work on this case. But I will share what little I have done so far.
    Knowing that I needed more lighting inside the case but not wanting those hard to place cathode tubes I came across this handy little 120mm dual cathode fan from Logisys .
    [​IMG] [​IMG]
    Since the clear fan didn't fit the scheme of the case so far I simply simply transplanted the dual cathodes to my 120mm aluminum framed Evercool fan mounted in the door already.
    Side.
    Interior.
    And night shots.
    See? Nothing spectacular but I must say it throws light evenly throughout the interior of the case.
    I've also started work on this phase of the case...
    The cladding of the case doors.
    To that end I purchased 2 spare door panels from Performance-PCs,
    Stripped the hardware off of them,
    masked off the panel and jigsawed out the shape. My assistant inspects the final product.
    Pardon for the lack of in progress pics.
    You'll notice that I haven't cut out the logo on the panel. That's because my plans have deviated just a bit. The design now calls for more watercutting parts to be added. I'll fill you in on that a little later as time permits.
  19. Pitbull
    Pitbull New Member
    20 Mar 2005
    Damnnn,, gj job:) Still getting better
  20. Krikkit
    21 Jan 2003
    Damn nice case, and I like your assistant too :p
