Project Girlfriend Reloaded [update 070315]
Discussion in 'Project Logs' started by raxxo, 26 Oct 2006.
  1. raxxo
    raxxo What's a Dremel?
    24 Jan 2003
    this is a cutout from my post in "Modding" for you who have missed it...
    And today Ive started construction...
    Just getting started Im doing this in my quite small kitchen :p
    The pieces are starting to pile up :)
    And so Is the sawdust... I had a real blast cleaning up :wallbash:
    A small tribute...
    Now were getting somewhere, this is as you probably can see the basic structure... next up is sanding down the edges to make it all fit together...
    and then some routing to make the slots for the psu and drive-rack...
    Also I asked about a radialfan with about these dimensions...
    hope you like it :dremel:
  2. elliod
    elliod What's a Dremel?
    1 Oct 2006
    seem to be a good start hope you get it done.
    keep up the good work.
  3. raxxo
    24 Jan 2003
    Thanks elliod :)
    yeah, I'll get it done for sure... only thing is i work crazy days so I wount have any time working on it untill friday... I work 12½hrs each night 4 days in a row, then I'm off 4 nights in a row...
  4. raxxo
    24 Jan 2003
    so... a little update...
    FINALLY I've had time to get somewhere with this project... All parts have been corrected at my old school since the circular saw i borrowed did'nt seeme to cut at right angles, they're not exactly perfect at the moment but I'll fill in the gaps with some putty later on...
    some pics...
    more updates soon...
  5. Jipa
    5 Feb 2004
    Oh god I better not whine ever again about having to mod in my room! Damn using a circular saw in a kitchen is something new!
    The plan however looks good. I'd consider stealthing the front panel though. Atleast the CD and the floppy drives.. They don't look too nice IMO.
  6. itsjustacompaq
    itsjustacompaq Minimodder
    7 Sep 2006
    picky no worky
  7. ottzen
    ottzen What's a Dremel?
    28 Nov 2006
    Just to clear things up...I wasn't shouting bad words at you or something ;)
    Just a funny picture which happened to have a swearword in it, to which the mods reacted quickly and appropriately. Nice work!
    But I still can't see any pictures in your last post :(
    Is it just me?
    //ottzen
  8. gnidnu
    gnidnu Beware of the Tofu!
    9 May 2006
    I can't see em either. There is some sort of "trick" necessary to see them. I quoted his post, copied the links and opened them directly. After returning to this thread, i can see the images. Weird, ain't it? Maybe there is a problem with the size (800x600) or the server prevents hotlinking.
  9. widmod
    widmod Minimodder
    9 Oct 2006
    I can only see the pictures when I download them with the links from quoting
    should be a problem with the google host, because the pictures can't be seen in the browser window (with the direct pictures adress). :duh:
  10. raxxo
    24 Jan 2003
    hmm.... wierd... must be google somehow, I'll just upload them to some other place later on...
    yeah, im thinking of stealthing the drives somehow... probably I'll get a cd-front from coolermaster and blending it in with putty... the floppy aint going to be a floppy, It'll be a frontpanel with headphones, microphone and usb instead...
  11. raxxo
    24 Jan 2003
    and a new update...
    first I countersunk the screws...
    then I covered the screws with filler and sanded them down...
    this is what I got...
    first layer of spray...
    the spraypaint does'nt seem to good, but I'll just have to see after the next coat...
    also i fixed the pictures in the previous post :)
  12. rowin4kicks
    rowin4kicks a man walked into a bar ...
    5 Feb 2006
    have you tryed sealing the wood first, otherwise the wood will just keep absorbing the paint!
  13. Jipa
    5 Feb 2004
    Yeah you'll need some bondo and primer to make the screws invisible after the final paint.
    EDIT: btw for all the macgyvers out there, you can make filler from saw dust and wood glue :rock: if you don't need lots of it, that works fine. for larger surfaces that's not too good method, but hiding screws that works.
  14. gnidnu
    9 May 2006
    Thats true, you need to apply lots of filler and base coat before painting.
  15. raxxo
    24 Jan 2003
    a crap! did'nt think of that... but anyway, the second coat seemes to have done the trick... I'll post a pic of it later...
  16. DeKemp
    DeKemp BEER.
    21 Feb 2007
    Is the drawing made with Solidworks?
  17. raxxo
    24 Jan 2003
    DeKemp >> yes, thats Solid... I see you use it aswell :)
  18. DeKemp
    DeKemp BEER.
    21 Feb 2007
    Yups its a great program, and fairly easy to use.
  19. yellowbomb
    yellowbomb Minimodder
    12 May 2005
    Carpentry in the kitchen? Brave, brave man, and my hat off to you.
    Be interesting to see what ends up...
