After getting GITS SAC 2nd GIG ive gotten a second wind but ive run into problems and cant find the film anymore. Anyone have ideas for a paint job?
No body is gonna help you out if you dont show an proof of work. I see words and words and words but no pictures.
Well i posted loads of pics throughout And even put in a tutorial (ok part of a tutorial) But how am i supposed to get ideas without help?
Finial found Most of the bits for the fron pannel USB but now i need to find a drill bit. It will look something like this.
UPDATE 22-February 2006 FUDGE i forgot tripods T&Cs Anyway i made some progress. Imm working on the a 4 port hub to resemble the above. Heres the connecters There will be 4 of them and because i only have 1 spare header i will modify this hub and connect it using this header (minus the big connector) . Heares the first 2 cut and in the progress of trimming Ive just found a thired and when i get a 10mm drill bit and the forth i can start fixing all together. PS if anyone wants the XBOX COnnector ends pm me.
Well it seams i forgot to read tripods T&C's so theres another delay on the project but at least its going again.
GITS SAC NETWORK This is the discussion for project Blue Titanium and already i have a poll. What color do i use for WC fluid, leds, LCD bay fillers? [POLL IS VOID ]
LOL....Just saw the result from the poll. Guess I'm not the only tired of blue and green. By the way.....MEDIAN? Sure thats not MEDION. If thats the case, that might make you Danish.
Doh thats the dyslexia showing. yes its MEDIAN and no im not danish, Median are available from aldi in the uk. FYI its also know as TEVION
If reds the color what bay filler do i use? Im gunna use an Red MX lcd But im going to us a monitoring Bay (if i can find a uk seller) but ive got a proble which one do i use? Musketeer 3 (RF-5AD) Or a Musketeer 2 (LLC-U03) set to red. P.S. Where do you find those graphics card WC blocks that cover the GPU and ram?
Not realy an update but This current project is going slow due to perl issue but i have been working on the USB HUB (sorry no pics cus of this) (yes im learning to snowboard)and (sorry i hate cats) However my other projet pc A medion titanium has thrown up a plesent supprise 2 SATA's with raid. Project wetware is on hold cus titinum is ending up also in boring blue.
Currently all mods going slow( this plus blue titanium) due to snow bording. Is this a worthwhile excuse?
What do you mean as per the rules i always have pics, And so far this ones had pics. I have a little problem with ali today (and having to take family to hospital but i may have a pic of the second dvd fitted without the drive cover.)
