Project: Gizmowerkz
Discussion in 'Project Logs' started by Fandu, 22 Jul 2004.
  1. ¿þŘΩĐĮĢΫ?
    ¿þŘΩĐĮĢΫ? What's a Dremel?
    13 Jun 2004
    looks shiny, i like it (say it alot but it's true)
  2. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    Damn, thats a lovely colour
  3. Fandu
    Fandu What's a Dremel?
    3 Mar 2004
    Still to do:
    -cut design in let side panel
    -paint design on right panel
    -add spinner to turbine fan
  4. r3men4nt
    r3men4nt What's a Dremel?
    12 Nov 2003
    OMG you suck! :D Im doing the asme kind of thing to my case cept im susing a midsize chenming and im putting a 120mm duct and an 80mm duct in the front. You also have the same mobo and heatsink as i do!
  5. Dimazz
    Dimazz What's a Dremel?
    8 Feb 2004
    WOW!!!!! Very very very NICE!!! I REALLY like how this case is lookin!!! Keep it up dude!!! :dremel: :dremel: :dremel: :dremel: :dremel: :dremel: :dremel: :rock: :rock: :rock: :jawdrop: :jawdrop: :jawdrop: :clap: :clap: :clap:
  6. bootupbuddha
    bootupbuddha grunge modder
    3 Feb 2004
    Very, Very clean!
  7. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    Very Good Paint Job!! Keep up the great work.
    MS
  8. ArmyAnt
    ArmyAnt What's a Dremel?
    6 May 2004
    Gotta say, thats some amazing bondo work!
  9. Atarax
    Atarax What's a Dremel?
    13 Jul 2004
    i like the color but i think that you need to put some more time into repainting the bezels they look splotchy.
  10. Fandu
    3 Mar 2004
    eh? I think those are camera effects your seeing. The bezel color is very even and the finish is pretty shiny (hence the camera effects) :rock:
  11. Death Reaper
    Death Reaper What's a Dremel?
    27 Jul 2004
    That's not a mod! That's a work of art! Beautiful!
    Regards,
  12. TomboyMS
    TomboyMS What's a Dremel?
    6 May 2004
    Looking really good. I love the way the bezel and fan duct came out. Nice color too. :rock:
  13. timbudtwo
    timbudtwo What's a Dremel?
    14 Apr 2004
    when i saw this picture
    I said holy crap, that looks REEELLLY nice!
    And, it does look reeeeelly nice. Great job and keep up the good work!
  14. phuzz
    phuzz This is a title
    28 May 2004
    Wow, really nice. What kind of painting did you use for the pannels? They look really shiny,
    mmmm, shiny
    Also, what kind of fan is that on your heatshink, it doesn't look big enough to have a motor in it.
    And if you wanted to neaten up your fan cables a bit, just twizel them with your fingers so they twist up. Looks a lot nicer imho, and keeps them out of the way of the fans...
  15. Fandu
    3 Mar 2004
    Well I followed the painting scheme that I talked about a little earlier. basically though, 2 coats of primer, 3 coats of paint (or until I'm happy with it) and then 3 more of clear coat. I used progressivly finer sand paper from 400 grit up to 1500 grit.
    The fan is a YSTech TMD (Tip Magnetic Drive) unit. The center spindle looks so small because there's no motor there :eeek: There are mangets located around the outside of the fan blades and the motor coils are located in the outer 4 corners of the fan.
    As for the cables, I think I might sleve them, but I haven't decided yet.
    Thanks for the good comments guys. :rock:
  16. Aa-chan
    Aa-chan AA-CHAN
    8 Jul 2004
    The colour is brilliant and the finish is excellent :) . I don't know why, but I can imagine a mirror effect on the insides. Good work though :) .
