Scratch Build – In Progress Project Glacial by Dia2777 - 05/06 Top fans hole, take a look!
Discussion in 'Project Logs' started by dia2777, 11 Mar 2008.
  1. dia2777
    dia2777 What's a Dremel?
    11 Mar 2008
    Dear compmodder, stainless steel is near two times harder than alu, but after the cut you need only a bit of sandpaper to have a shiny metal, it's hard but it give you satisfaction, trust in me!
    Last night was a modding night, now I want to arrive to the end of this stage of work, I want to do a little more, but firt I need to finish this stage, so here are the updated pics :
    The last pic is the Zalman fan controller, want to take a closer look at the holes for locking it in place (and the dvd) ?
    Here you have :
    Now I must put in place the front fans, but without the screws, I donìt want some screws in the front of my Glacial! After lot of thinking, I decide to use two scrap pieces of blue UV reactive plexy :
    I've decided to have two identical pieces, so I've done the 4 fixing holes, then I've bolt all together, and afer a little use of the sandpaper here is the result :
    Not so amazing, I know.
    But go on with the big center hole :
    A little bit of polish compound :
    Final result!
    Now I must do a recessed hole to hide the screw head :
    Eye candy pic :
    I'm quite satisfied, now to lock the whole assemply in place I use some silicone (may someone suggest me the right english word?)
    If you take a closer look, the hole in the plexy is a little bit smaller then the necessary.
    It's not an error, guy!
    It's done to give a special glow to the fan contour, stay tuned for the next update where I will try to show you what I mean!
    In the meantime, happy modding from Italy!
  2. thing
    thing What's a Dremel?
    9 Feb 2008
    nice work on the grills
  3. MrWizard
    MrWizard What's a Dremel?
    5 Feb 2008
    Silicone is the right word ;)
    Awesome work man, you just keep dropping my jaw :)jawdrop:) on this one. I'm anxious for more!
  4. The boy 4rm oz
    10 Apr 2008
    Your plexi work is as good as your metal work lol. Keep up the fantastic work.
  5. welder tamarra
    welder tamarra What's a Dremel?
    4 May 2008
    Dia is a master of dremel...
    Let's go Dia!!
    :clap::clap::clap::clap:
  6. yeknom
    yeknom What's a Dremel?
    23 Apr 2008
    Ugh, the more I look at those snowflakes, the more I want to steal your dremel skills. Good work, and nice thinking with the plexi.
  7. dia2777
    11 Mar 2008
    Last night i sleep for 7 hours, so no more update...
    BUT, I have an insane idea to go on...
    So, guys, tnx a lot for the comments, but stay tuned for the next update!
  8. CobraMods
    CobraMods Gettin there slowly
    28 Mar 2008
    dai i wish i had your dremel skills bud. great work!!!
  9. nikeunltd
    nikeunltd Epic destruction around machinary
    5 Apr 2008
    ROGER THAT! OVER
  10. dia2777
    11 Mar 2008
    Tnx a lot for the comments, sorry but I had little free time, but I've done something to the Glacial.
    It's time to finish the front panel, putting in place the letters :)
    I've used an easy method, I sick all the letter to a plexy board from the backside with some silicone, but with a rather nice effect :
    Look from the inside :
    To archieve this particular effect ou have to put in place the silicone, then every 5 m,inutes or so pull the letters apart and replace. The silicone will do this great effect :)
    Not it's time to rebuild all and we're ready to put some cable and some tubing :
    A little speed cut to the front panel to make some space for the dvd burner :
    Now I can do the side panels, follow me, guys, and you'll see some little ideas from my mind!
  11. The boy 4rm oz
    10 Apr 2008
    That looks very cool. Great work. can't wait for the sides.
  12. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    Nice work glacial, loving your case, especially the custom motherboard i/o thing...
    WOW
  13. karolis
    karolis Code Monkey
    10 Mar 2008
    beautiful. the name really fits the case. plain metal looks so cold and nice.
    Great work!
  14. nikeunltd
    5 Apr 2008
    haha nice job on the letters
  15. compmodder
    compmodder What's a Dremel?
    23 Dec 2006
    thanks for the advice...i'll probably try playin around with a scrap piece when i find one before usin it in anythin.
    Absolutely lovin the fan grills, and the design of the snowflake goes very nicely with the fan.
    Keep up the good work:clap::thumb:
  16. dia2777
    11 Mar 2008
    I'm trying out some ideas, asap I found THE perfect idea I'll post more update...
    Does anyone know Cameron Diaz? Think about it...
  17. The boy 4rm oz
    10 Apr 2008
    Hmmm. Cameron Diaz, I know of her. Damn I'm stumped lol.
  18. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    Man, that's flippin' sweet. That lettering is absolutely inspiring!
  19. Soulman84
    Soulman84 tryin' learnin' some moddin'
    4 Sep 2007
    Cameron Diaz.. i think I'd prefer Penelope Cruz (Dia knows what I'm talking about ;))
  20. steelkane
    steelkane It's Not Just A Box
    11 May 2008
    I really like the way u made everything come together, your planning, Skills & Creativity make this ONE BAD-ASS PROJECT, I'm hooked till the end. Thanks for shearing.
