Project Goliath - It's got wheels, man.
Discussion in 'Project Logs' started by Starbuck3733T, 26 Sep 2005.
  1. Starbuck3733T
    Starbuck3733T Look out sugar, here it comes
    16 Sep 2002
    Well... the front panel is _almost_ done in sketchup. I failed to make a spot for the optical drive's tray to come through it! I'm going to try to figure out how to integrate one of those lian-li optical drive stealthing covers... it's a space issue. the LL covers are mighty thick.
  2. Starbuck3733T
    16 Sep 2002
    I've got wheels!
    I got the black anodized wheels last weekend but didn't get around to put them them on till now. They're a replacement for the stock feet that my ex-wife so nicely fowled up while I was moving out. Plus, when this thing is on a desk, it'll be a lot easier to move now.
    Why are the panels on you ask? well, it's a mild effort to keep dust out but mostly because it's going on a trip with me this weekend for a little mini-lan action. A lan rig it aint, but neither is the 2407FP! Anyway... once the new front panel is fabbed up it'll go to Knipex (i love you man!) to get painted... :)
    Rear bracket installed. it's just a bit of 3/8" aluminum with 2 holes to mount into the bottom of the SC5000's frame rails and 4 6-32NC thread holes for case screws to hold the foot on.
    Rear foot installed, held in place to bracket w\ 4 6-32NC (case) screws. Having a good set of taps is awesome. I had to enlarge the stock holes in the lian-li feet a bit to get the 6-32 through it, but I just reamed the holes out with a round file. easy fix.
    Both on.
    Wheels small. case BIG.
    Front panel sketchup file, properly dimensioned to actual size.
    The front IS NOT FINAL at the moment as I haven't decided how I want to handle the optical ejecting. I might have a few more tricks up my sleeve. the design might change a bit, but not by much. Its pretty much the same appearence wise as the current panel but with a few improvements and some changes (no more LED/fiber indicators, viewport for respack, better design overall for clearing the shape of the metal in the front of the case.
    a few screenies:
    Top:
    Bottom:
    Plexi/alu joint & cut out detail
    Thoughts? Comments?
  3. Dj Ovin
    Dj Ovin What's a Dremel?
    7 Nov 2005
    Very nice! i think it will be very cool.
    Go on!
  4. itsjustacompaq
    itsjustacompaq Minimodder
    7 Sep 2006
    i know its not what you're going for, but the panels look really cool after you stripped them. if you leave the sides and top just like that, it will be a great "patina mod". i just think its funny that during the process to get it looking great it already looks pretty cool.
    awesome mod anyway man, i love how that cpu block looks.
  5. modsquad
    modsquad Grease Monkey Undergraduate..
    27 Feb 2004
    I love those LL casters in black. I have used the very-same in my last two projects. They provide true form and function (IMHO)..
    Your machine is looking great!!
  6. Xlixen
    Xlixen What's a Dremel?
    16 Apr 2007
    This looks like it's going to be nice! Great Work!
  7. ComputerKing
    8 Sep 2006
    Well done , Nice work :thumb: good luck
  8. Starbuck3733T
    16 Sep 2002
    Thanks for the compliments on what's going on. got a few more things I need to do now that dutch has told me milling 1/2" plate down to 3mm thick (thinest part) is a bad idea, and the bit about the corners (I'll radius them, they don't need to be square) and increase the panel thickness to 3/4" to avoid warping... and then I shall repost (That and when I have the optical eject thing figured out.)
  9. Guest-23315
    Guest-23315 Guest
    Have fun...
  10. pedrofilho
    pedrofilho What's a Dremel?
    4 Apr 2007
    Very nice work.
    Keep going,
    Pedro Torres.
  11. C-Sniper
    C-Sniper Stop Trolling this space Ądmins!
    17 Jun 2007
    cool mod, keep it up.
  12. AFX
    AFX "Bling" Silver Mountain 2
    19 Sep 2006
    i just spent the last 2 hours reading this thread... simply amazing. Great work!!
  13. Starbuck3733T
    16 Sep 2002
    Goliath is getting shelved again while I move to Cincinnati for my new job as sysadmin w\ Proctor and Gamble in their research labs, but prior to moving I have acquired new guts for it! A new 650W Seasonic PSU, a Core2Duo E6750, an Asus P5N32E-SLI Plus, EVGA nvidia 8800GTX 768MB, 2GB of ram, a lite-on burner ([variable] you bought the loudest drive you could and recommended it to me anyway? :p) and a new 320GB drive. My aging P4 3.2GHz/2GB/X800XT setup has had some severe stability problems that are not heat related – so a full gut upgrade was in order. It’s also the first time I’ve done a full gut upgrade since… 2001! Yikes! It was time. I’m waiting on buying some sweet, sweet waterblocks to cool the new goodies (northbridge & southbridge blocks, voltage regulator blocks, 8800GTX block, and possible a new CPU block depending on how well Eddie/scopEDog’s block does in the new setup. And like I said before, the new job pays very well and there are some very talented folks in the areas of painting/bondo/modeling in Cincinnati and in Arsclan crew itself… so I hope to really finish this project. If I’m not TOO busy gaming on my new setup. Plus my new house has a full basement for use as a workshop and a backyard for overflow! It’s going to be great, and thanks very much for following the project. We’re on the upswing – I swear.
