PROJECT: Green Dragon | major delay | Updated 10/2
Discussion in 'Project Logs' started by Acid Burn, 12 May 2004.
Should I Insert an engraved window in my front door?
Poll closed 7 Jun 2004.
  1. Yes! Yes! Yes!
    27 vote(s)
    61.4%
  2. No... just bondo the door smooth
    17 vote(s)
    38.6%
  1. Firehed
    15 Feb 2004
    It's possible but I don't think so. I'd try copying it to another drive first just in case though. Never heard of a disc being referred to as dynamic... maybe that's extra hotswap support or something.
  2. AL3X
    AL3X What's a Dremel?
    29 Aug 2003
    The same thing has happend to me several times, but it's usally fixed itself..
    Have you tried to reconnect the drive, re-boot your computer and checked all cables?
    Or maybe test it on another machine (that way you can backup all the files if it works)?
    If you do format or something like that there's a company in Norway called Ibas (if I'm not mistaken) that restores data. They're not cheap but they usally manages to restore all of the data. The Norwegian police uses them a lot :p
  3. Acid Burn
    Acid Burn ..look but don't touch..
    14 Mar 2004
    how does it fix itself?
    all the cables are correctly installed... and the jumpers are in place too... (I'm now 100% sure, but I'm close to 97% ;))
    Ibas is not an option :p it's waaaay too expencive... up to 10000 NOR KR is too much... especially since I can just download the movies and music again..
    I will probably hook the disk up on my dad's computer and take backup of the movies and music I want.. I just hope he has enough space :p
    BTW:
    I have frosted the sidewindow now..I tried a test setup with some 5mm leds... but the leds turned out produce too little light to light up the window.. It MUST have been the wiring because later I put all the leds in a molex contact and they all lit up just fine. I have also set up the water cooling as it will be when I'm finised, so you can see how it will turn out. right now. I'm too tires do post the pics so I'll do it tomorrow.. :thumb:
  4. P2D
    P2D 99.999% Pure Spam!
    26 Mar 2004
    well, i "WAS" going to say good work, but i honestly dont think it is..
    Its better than *GOOD!* its amazing! :rock: on!
    `P2D
  5. theagent
    theagent What's a Dremel?
    4 Nov 2003
    Acid, i had a problem where my computer wouldnt recognize my optical drives. i was pissed and confused and noone could help me, but for no apparent reason i reinstalled clone cd on my computer [ i think i figured i'd just run an image file ] and it did a check and found and fixed the problem [something in some system file was messing with it]. you may have the problem. i suggest you install clone cd.
  6. Acid Burn
    14 Mar 2004
    I'll try that theagent :) Prepare2die... you scared me :p
    The pic I took yesterday... this is how it's going to be..
    I decided to fill the system so I could run it for 24 hours to see if any of the blocks leak.. I filled the tank and turned on the pump... and.. Ewww!! the water tured orange when it passed throigh one of the blocks :duh:
    [​IMG]Guess I have to clean the system :hehe:
    Here's the frosted plexi..
  7. MrBurritoMan
    MrBurritoMan What's a Dremel?
    27 Jun 2004
    yes cleaning = good
    man i would have freaked out if i saw that. great job though. i wish that i watercooling skills were up to par. :grr:
  8. Acid Burn
    14 Mar 2004
    hehe watercooling requires no skills what so ever.. you just need a bit of common sense and a carpenter knife :p
  9. phuzz
    phuzz This is a title
    28 May 2004
    ew, that orange doesn't look good. Maybe you should give that block to piloux, might go just fine with his rust look ;)
    Don't know if it'll help, but you could try getting hold of a copy of partition magic, it might be able to 'see' your missing data. Just a small chance though...
  10. Acid Burn
    14 Mar 2004
    thanks for the tip :) I'll try that :thumb:
  11. SFOD-D LoneWolf
    SFOD-D LoneWolf What's a Dremel?? :p
    10 Apr 2004
    Nice, comming along really nicely...
    I'm also fitting the WC kit in my case ATM (DD TDX, M4 AMD chip, M4 Radeon)
    Although my water turned white rather than orange :blah: (damn WW :rolleyes: )
    Cheers,
    Mike
  12. Acid Burn
    14 Mar 2004
    hehe :D btw what's WW?
  13. Cinder
    Cinder What's a Dremel?
    18 Apr 2004
    Im guessing WaterWetter or White Water (block)
  14. Acid Burn
    14 Mar 2004
    Shopping trip
    I went shopping today :) luckily My old man payed because it cost 58€ :D
    I bought:
    *3 cans of black (glanz)
    *1 can of Black (mate)
    *3 cans of clear liquer
    *1 can og primer
    *1 soldering iron and "A-tool-that-remives-the-isolation-from-the-wires"
    :D
  15. Acid Burn
    14 Mar 2004
    :wallbash: <-- animations sais more than a 1k words...
  16. kitt
    kitt Michael Knight
    8 Aug 2004
    WOW that looks gooD.
    Love The frosted window with the dragon design! pure genius!
    Good Job!
  17. Acid Burn
    14 Mar 2004
    thanks kitt :D and welcome to the forum :thumb:
    Oufh! I have just cleaned the water tubes and blocks and rads and pump (the entire system :p). no more orange, that's for sure :D I have also sanded the top... I will continue painting it tomorrow.
    Here's a tip to everyone who's encountered the same problem as me:
    when your system is full of water, add a fair amount of vinegar in the tank and let it circulate... if you do not have the system full of water (like me) then take out all the blocks, rads etc, and fill them up with a nice vinegar and water mix. they get cleaner if you shake the blocks and let the vinegar mix run through the pipes a few times. then fill the block/pipe/rad/pump with clean water.. if it still looks like a mess or the water still get's dyed when running through, repeat the entire procedure.
    Tomorrow features:
    Bondoing and Painting
  18. activecactus
    activecactus What's a Dremel?
    30 May 2004
    I'll make sure I do that when I get mine set up.
    BTW. I still cant get that dragon out of my mind. When ever my kid says "red eyes black dragon"(He's a big yu-gi-oh fan)I think of your mod.
    :rock:
  19. Acid Burn
    14 Mar 2004
    hehe :D
    BTW. the vinegar is only for use to clean the system.. but I don't know if it will hurt the wc system if you always run vinegar in it.. :worried:
    think I have to go to bed soon If i want to get up before 2 o'clock tomorrow :p
  20. Miirk
    Miirk What's a Dremel?
    26 Jul 2004
    Great job on the watercooling, it looked really nice before it turned into that poopish color hehe..
    Always nice to see my fellow scandiavian modders kick some british arse! :D
