PROJECT: Green Dragon | major delay | Updated 10/2
Discussion in 'Project Logs' started by Acid Burn, 12 May 2004.
Should I Insert an engraved window in my front door?
Poll closed 7 Jun 2004.
  1. Yes! Yes! Yes!
    27 vote(s)
    61.4%
  2. No... just bondo the door smooth
    17 vote(s)
    38.6%
  1. milgo
    milgo What's a Dremel?
    12 Jan 2004
    Car body filler is quite good. Locite sell some plastic filler you can get in halfords, give that a bash :)
  2. DrPepper
    DrPepper What's a Dremel?
    26 Aug 2004
    Okey..No i did mean your dremel copy ;)
  3. Acid Burn
    Acid Burn ..look but don't touch..
    14 Mar 2004
    hehehe ok then :hehe: my bad :p
  4. theagent
    theagent What's a Dremel?
    4 Nov 2003
    more mod more mod!
  5. Acid Burn
    14 Mar 2004
    hehe the modding continues! today I have sanded and primed the front panel (hmm... i think it's called front bazel...) I'll post pics as soon as it's dry :thumb:
  6. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    It's bezel matey, look forward to seeing some piccies :D
  7. Acid Burn
    14 Mar 2004
    Front Primed
    this was a huge step for me... cuz now I can't go back (without sanding it down that is).
    here are the pics
    before:
    after:
    looks a bit more like one piece now ;)
  8. ¿þŘΩĐĮĢΫ?
    ¿þŘΩĐĮĢΫ? What's a Dremel?
    13 Jun 2004
    mmmmmmmmmmmmmmmmmmmmmmmmmmmmmmm
    very nice and smooth
  9. AL3X
    AL3X What's a Dremel?
    29 Aug 2003
    I 2nd that :thumb:
  10. phuzz
    phuzz This is a title
    28 May 2004
    And you're going to paint the front black and shiny like the rest right? mmmmm nice, the curve on the front now is really lush, keep it up!
    (edit, my spelling is crap)
  11. Acid Burn
    14 Mar 2004
    Holy cow and other animals!!
    I'm really not sattisfied with how the front door turned out!! I can clearly see where the bondo is because it seems like the bondo is a little bit lower than the plastic, making it look like the F'ing Grand canyon! :wallbash: I'm wondering if I maybe should sand down the primer and apply more bondo :sigh: But I don't know if I care enough.... I know it will stick out like a flashing neon sign in a respected neighborhood, when I apply the shiney black paint.... :duh:
  12. phuzz
    28 May 2004
    if it annoys you now, it'll annoy you every time you look at it in the future. Little bit more effort now will make it perfect.
    (coming from me, this is pretty wierd, I'm the king of, 'it'll do', but you know what I mean right?)
  13. Acid Burn
    14 Mar 2004
    Indeed Phuzz. I have decided to apply more bondo... although it's my first project there's no reason to be sloppy. and I think the case deserves it, since I have put quite a lot of work into it. I'll post pics of it now..
  14. Acid Burn
    14 Mar 2004
    Front door primed
    Yesterday I primed the front door, but as you can read above, it didn't go too well.. so I have decided to apply more bondo.
    Before:
    After:
    All together (everything except the door is wet sanded so, as you can see, much of the primer is gone)
  15. Acid Burn
    14 Mar 2004
    Dragon Door painted
    The last update didn't get too much response, I hope this will ;)
    Today I painted the dragon door. The gloss gloss turned out to be "ok" :D
  16. AL3X
    29 Aug 2003
    One word:
    Sweeeet :clap:
  17. ^R3CoN
    ^R3CoN What's a Dremel?
    14 May 2004
    Dude, that looks killer ! :)
    Keep it up ! :D
  18. Leeum
    16 Feb 2004
    Excellent work as always, lovin the shiny finish on the door :D
  19. phuzz
    28 May 2004
    Wow
    That door is probably the shiniest thing in the world. Well, ok, maybe I'm being a bit over the top today, but damn man, that is a really nice finish you've got there. Every time you look at that door, I hope you feeel proud of what you've achived, especially considering this is your first mod and you've not only designed and dremeled a sweet design, but the paint work is tops.
    ok, I better stop before your head explodes with pride, I'm really looking forward to seeing it all start to come together...or have you already started to use the case? ;)
  20. Acid Burn
    14 Mar 2004
    thanks a lot guys! I aaalmost exploded phuzz ;)
    I want to finish the case (without the front and doors) as soon as possible, cuz i want to start using it :) but I't will require some pinting to be done. I "finished" up the top last week or so, but it didn't turn out like I wanted. so I'll sand down one layer and apply one more coat od black gloss, and then the clear lacquer again. I think the problem was that when I used rubbing compound, I had sanded a bit too deep so I got through the clear coat.
    Tomorrow I'm going to "mod" my computer desk. mount two speakers upside down to the plate over my monitor that is :D I'll probably also paint the backside of the dragon door, since it will be visible through the jagged door.
