PROJECT: Green Dragon | major delay | Updated 10/2
Discussion in 'Project Logs' started by Acid Burn, 12 May 2004.
Should I Insert an engraved window in my front door?
Poll closed 7 Jun 2004.
  1. Yes! Yes! Yes!
    27 vote(s)
    61.4%
  2. No... just bondo the door smooth
    17 vote(s)
    38.6%
  1. SFOD-D LoneWolf
    SFOD-D LoneWolf What's a Dremel?? :p
    10 Apr 2004
    I'm back again, to stay I hope.
    Good to see you're project kicking, keep it up.
    POST 700!!
    POST 700 IN THIS TOPIC!!
    Cheers,
    Mike
  2. Acid Burn
    Acid Burn ..look but don't touch..
    14 Mar 2004
    hehe congratulation! 700 in both my log and 700 total post for you :D
  3. SFOD-D LoneWolf
    10 Apr 2004
    Thanks!
    Now get back to work...hehehe
    Cheers,
    Mike
  4. Acid Burn
    14 Mar 2004
    LEDs arrived
    some days ago the LEDs from frozen cpu arrived. i got about 28 i think. 13 dark green and 15 yellow-green... but since i now have enough dark green LEDs, I won't give them any more trouble. Totally, now i got 23 dark greens, and 34 yellow-green.
    (the bag to the left sais "gul" which means yeallow in norwegian)
    I have done some small stuff lately, like drilling a hole for the water pump cord. and painted the dragon door, drilled a hole for the cables for the leds in the front, and continued painting the front.
    i decided this would be the best place for the water pump cord to exit the case.
    some parts of the back will be repainted.
  5. SFOD-D LoneWolf
    10 Apr 2004
    It's the attention to detail that make it so nice.
    Keep it up
    Cheers,
    Mike
  6. DJFatben
    DJFatben What's a Dremel?
    5 Nov 2004
    Something you might want to try for that large panel that you're going to use as backlight for the dragon... bond some aluminum foil to the edges of the plexi (the thin ones). It reflects the light back very well and will make the effective backlight show up much much better. I didn't see anybody else post that tip here and if you didn't know about it you'll see a huge difference. it helps a lot if the edges are sanded down first to be smooth. Very nice work on all your etchings/cuttings/paintings so far. Keep it up
  7. Acid Burn
    14 Mar 2004
    thanks for the tip DJfatben. I'll try that :)
  8. Jock
    Jock Banned
    12 Dec 2004
    BUMP!
    Just spent the last 2 hours reading this log.
    Nice work man... Let's see the end product :thumb:
  9. Acid Burn
    14 Mar 2004
    hehe I am still amazed that anyone would spend over 5 minutes, reading my log :D thank you for reading it.
    I have pollished the aqua computer water tank bracket. it isn't chrome, but i dodn't want it to be either.
    2 weeks ago i broke my water pump. i think i have stepped on it or something. the intake and the shaft (??) had snapped off so i had to order new parts for the pump from germany. they will hopefully arrive soon.
    I have also done some experimenting with the water dye. i have reason to believe it sucks. i have now left in in a bottle for 1 week and it has turned orange. it still lights up green under uv light, but it is more blurry than before.
    this pic is taken right after i mixed the dye with the water.
    I have also ordered a new psu from the US. it should be sendt with express, so i hope it will turn up soon.
  10. Acid Burn
    14 Mar 2004
    Crazy bling psu!
    Hi all. this project has been taking waaaay to much time now, because i have lost the motivation to continue quite a few times. But I have now bought a new psu i think will fit the theme of the case. It's the Ultra Modular X-connect Uv Green psu. it is real pimperish and i think it will add a couple of points to the bling scale. I have to kill the rumor about the 20 pin atx cable to be very stiff, and little flexible. This is NOT true! it is very flexible! I thought it would be hard do bent the way i want it to be, but it isn't. it is 500w so it will easily supply the power needed for my system. If i don't get the ATi X800 Pro for christmas, I will buy it muself :p
    Ok too much talk, and too few pictures :p
    i'm still waiting for the shaft for the pump. so I won't be able to assemble the case before after christmas break.
    I'm getting there
  11. KAMIKAZE-FREAK
    KAMIKAZE-FREAK What's a Dremel?
    30 May 2004
    Nice PSU :D
    hurry up with mounting it :D
  12. Jock
    Jock Banned
    12 Dec 2004
    Yep.... more pics plz :clap:
  13. Hazchem
    Hazchem Minimodder
    3 Dec 2004
    That is a tasty psu! slightly TOO modded for my liking though. maybe you could De-Mod it, actually scratch that before I get ripped apart by any self respecting Bit-Tech-ers. I think the etchings you did are awesome, and I hope you are pleased with the final outcome. (like there's any reason for you not to be)
  14. Leeum
    Leeum What's a Dremel?
    16 Feb 2004
    oooo shiny :D Make sure you polish those fingerprints off when it's installed ;) :thumb:
  15. SFOD-D LoneWolf
    10 Apr 2004
    That's one sweet PSU, I love it.
    I think that It'll fit nicely into you're case, lot's of greeeeeeeeen :p
    Cheers,
    Mike
  16. Northy
    Northy What's a Dremel?
    21 Aug 2004
    Nice work there.. :thumb:
    If you bought the psu in norway, where did you by if from?
  17. SFOD-D LoneWolf
    10 Apr 2004
    He bought it in the US.
    Cheers,
    Mike
  18. theagent
    theagent What's a Dremel?
    4 Nov 2003
    awesome dude! keep it up, you're nearly there!
  19. Isuo
    Isuo What's a Dremel?
    13 Oct 2004
    Coming up nicely. Keep updating!
  20. Jock
    Jock Banned
    12 Dec 2004
    Glad you're still adding to this thread.
    Keep up the good work :clap:
