PROJECT: Green Dragon | major delay | Updated 10/2
Discussion in 'Project Logs' started by Acid Burn, 12 May 2004.
Should I Insert an engraved window in my front door?
Poll closed 7 Jun 2004.
  1. Yes! Yes! Yes!
    27 vote(s)
    61.4%
  2. No... just bondo the door smooth
    17 vote(s)
    38.6%
  1. Acid Burn
    Acid Burn ..look but don't touch..
    14 Mar 2004
    Thanks all of you :)
    Jedateach; remember this is my first project... I had never touched a dremel before I started this project. And if I can do it, so can everyone else! it really isn't that hard, you just have to take your time and find out what technique
    you think is the best :)
    :dremel: Mod on my friend :dremel:
    (although I have answered the replies so far, I would love to get more commets on my work :thumb: )
  2. AutoExec
    AutoExec What's a Dremel?
    31 May 2004
    I second that..
    the first window I cut after toutching a dremel for the first time didnt turn out bad at all.. thought I would have more problems than I did..
    just pick up the dremel and get to work! you never know.. maybe there is an uber dremler inside you :D
  3. SFOD-D LoneWolf
    SFOD-D LoneWolf What's a Dremel?? :p
    10 Apr 2004
    Very nice, very clean, very professional, I give it a A+ :p
    With some good lighting it'll rock!!
    Cheers,
    Mike
  4. Tech-Daddy
    Tech-Daddy What's a Dremel?
    8 Oct 2003
    Excellent work there bro!
    When you cut the design, did you cut it from the other side of the window out, or did you dremel on the outside going into the case?
    Nice work on those thin bridges on the dragon. Very impressive!!!
    An inspiring cut.
    :thumb:
  5. Acid Burn
    14 Mar 2004
    Tihihi it isn't cleat yet, but when/if I mannage to get a black mirror finish on the paint I'm sure it will look great ;)
    I'm going to eluminate the sanded plexi with greeeeeeen leds :D (therefor green dragon).
  6. Acid Burn
    14 Mar 2004
    Thanks pal!
    I cut it from the inside out (which I shouldn't because I the dremel had slipped, the outside would get f****ed..). but it didn't slip, so it turned out ok :thumb:
  7. Acid Burn
    14 Mar 2004
    Hi y'all! Now I need help!! can someone tell me the difference between acryl and plexi (if any)??? I have finally found a place where they sell acryl/plexi/material-suitable-for-window, but it sais it is acryl... I have seen a lot of people inserting acryl as windows, but how is it compared to plexi?
    Please answer fast, because on wednesday I'm going to buy it.. (not sure if I should buy the entire 2m x 3m x 4mm plate, or just buy pieces :))
  8. kaZuo
    kaZuo What's a Dremel?
    9 Apr 2002
    acryl = material
    plexi = brand
    same stuff but original plexiglass is a bit more expensive
  9. Acid Burn
    14 Mar 2004
    wow! that was fast! thanks!
    <I'm feeling like a large noob> does plexi sell acryl aswell? </I'm feeling like a large noob> :p
  10. kaZuo
    9 Apr 2002
    as i said, it's the same stuff. you probably didn't see my edit before your post.
  11. Acid Burn
    14 Mar 2004
    ahh thanks pal! :D
  12. hughwi
    hughwi Minimodder
    23 Dec 2003
    i have just read your log and i have to say that both the side panel window and the front door look awesome!
  13. ATi Loyalist
    ATi Loyalist Who throws a shoe?!
    9 Nov 2003
  14. Acid Burn
    14 Mar 2004
    LOL! Nice! damn! I didn't know anyone hade made one before :waah:
  15. AutoExec
    31 May 2004
    hehe.. one thing I have found out is that whatever you do with a computer case, somebode has most likely done it before...
    that especially goes for the chieftech dragon tower :D
  16. Acid Burn
    14 Mar 2004
    hehe I think you're right... yesterday I found This :grr:
  17. Rody
    Rody What's a Dremel?
    23 Oct 2003
    Nice work on the cut out! Although it looks like some paint chipped off around your design?
  18. toss
    toss What's a Dremel?
    6 Jun 2004
    Pretty nice cutting man good work now get some lights and show us the baby
  19. AutoExec
    31 May 2004
    I think he is going to spraypaint the whole thing, so no worries there :thumb:
  20. Acid Burn
    14 Mar 2004
    I am... I haven't even started spraying :p to morrow I'm going to buy acryl, and buy some primer...
