Case Mod - In Progress Project: Green Extreme
Discussion in 'Project Logs' started by dd123pp, 31 Aug 2008.
  1. dd123pp
    dd123pp Watercooler
    31 Aug 2008
    Also Have A Build Log Here -
    http://www.watercoolinguk.co.uk/forums/viewtopic.php?f=33&t=3128&st=0&sk=t&sd=a
    Specs
    Hardware
    Intel Quad Extreme QX9650 Watercooled
    3x Evga Nvidia 280GTX Watercooled
    Asus Striker 2 Extreme Watercooled
    3x 300GB VelociRaptor
    OCZ 4GB DDR3 PC3-14400C8 1800MHz Platinum (4x1GB) (OCZ3P18002GK)
    ThermalTake 1200 Watt PSU
    Creative Soundblaster X-Fi Titanium Fatal1ty Professional
    LiteOn LH-20A1S11C 20x SATA DVD Burner Dual Layer Retail
    Logitech Bluetooth Desktop Mx 5500 Revolution & Razor Pro Mouse Mat
    Windows Vista Utimate SP1
    Modded Lian Li V2000 (Painted Green Outside, Black Inside, And Rad Holes On Side Panels Cut, On Both Sides With Mesh, And Clear Arylic Window)
    2x AC Ryan 12" Dual CCFL Blue Kit
    Cooling
    Corsair Dominator Airflow Fan for the Ram Modded
    Loop One - All Feser Compression, With XPSC 1/2 Tubing
    Thermochill 120.3 Rad With Three Xilence Blue LED Fans
    DDC Ultra Pump With XPSC Top
    XPSC UV Blue Res
    Fesser One Acid Green Coolant
    XPSC Delta V3 CPU Waterblock
    AF Asus Striker 2 Extreme Mobo Waterblocks (2X Mosfets, 1X South Bridge, 1X North Bridge)
    Loop Two - All Feser Compression, With XPSC 1/2 Tubing
    XPSC UV Blue Res
    3X EK 280GTX Waterblocks With Back Plates
    Pictures Of Af Mobo Blocks
    NB Waterblock
    Mosfets Waterblocks
    SB Waterblock (Not my Mobo, Just aint got a picture of this block)
    Pictures Of Res
    Braided LED For The Res
    Picture Of Rads
    Picture Of Pumps, Also Braided
    Pictures Of Some Case Fans (Xilence Blue LED Fans)
    Picture Of Front IO Panel Braided
  2. dd123pp
    dd123pp Watercooler
    31 Aug 2008
    Case Modding Log
    Thanks To Marcus000 For The Modding Of The Case
    Panels Marked Out For Cutting
    Panels Cut & Case Stripped & Prep'd For Painting
    Full Case Etch Primed - Last Paint Sprayer Didn't Have The Time To Finish it, So It had To be Taken Elsewhere
    Case Painted Green Pearl Camera Didn't Take Colours Correct, Its This Colour!, This Was Done By A Professional Car Sprayer
    ehehehe Sponsored By Hair Care Products!
    Much Better Picture, Colours Look Like What It Meant TO!!
    Insides Sanded Down And Outsides Masked Up (We decided to have black inside after the green was painted, has it would look even better)
    1st Coat Of Primer Inside To Paint It Black
    2nd Coat Of Primer Inside To Paint It Black
    Decided To Paint Rads
    Need To Make A Rad, Has The Rads Are Too Low
    Installed Mesh On Panels
  3. dd123pp
    dd123pp Watercooler
    31 Aug 2008
    Building Log
    Mobo Heatsink Taken Off
    Received & Putting The EK280 Waterblock & Back Plate On The 280GTX
    God Knows Why I Got The Overclocked Version, Paid For The Normal Version, Plus Evga Step-Up Only Allows You To Step To The Normal Ones
    Massive GPU
  4. dd123pp
    dd123pp Watercooler
    31 Aug 2008
    guys do u think i should ditch the blue uv res? and get an single clear one for each loop or an internal non drive bay one, ie the ek ones
  5. bentleya
    bentleya Lian Li Snail :)
    2 Feb 2008
    looking good dave :D think you shound leave the res how there are :D
  6. b1g-d0g
    b1g-d0g Modder
    30 Sep 2001
    Love the colour reminds me of my old RS 2000 :)
  7. dd123pp
    dd123pp Watercooler
    31 Aug 2008
    cool, saves me some money, i hate waiting, need to wait for the delta v3 to come out and wait for some money to grow in my wallet
    just to to buy thrid 280gtx, 1200psu and sound card the the delta v3
  8. Jipa
    5 Feb 2004
    You, sir, officially got my attention with that color choice of yours! Looks nice, I like green.
  9. dd123pp
    dd123pp Watercooler
    31 Aug 2008
    Thanks mate!
  10. FrooP
    FrooP can I eat this?
    24 Oct 2007
    lookin goood
    are these anfitec coolers?
  11. bentleya
    2 Feb 2008
    ^^^ yes there are ^^^
  12. dd123pp
    dd123pp Watercooler
    31 Aug 2008
    Did have a problem with them, the threads are too close, I could use normal barbs and 7/16 tubing only just, and wanted 1/2 tubing really, has i brought lots of feser compressions fittings, so had to buy elbows for the nb & sb blocks, hope it dont affect the flow to0 much
  13. SergeantMajorLogan
    SergeantMajorLogan General
    31 Aug 2008
    Loving your work matey.......................... Up the WCUK Massive :thumb:
  14. subset7
    subset7 Spanking the Monkey
    31 Aug 2008
    Any news yet ? ;)
  15. 7755matt
    7755matt What's a Dremel?
    31 Aug 2008
    now that is one serious choice of colour, you wont lose it in a huirry!
  16. SergeantMajorLogan
    31 Aug 2008
    mad colour and lol@ anynews yet hahahahaha *dreams of wcuk taking over the world* ;)
  17. dbruguera
    dbruguera What's a Dremel?
    31 Aug 2008
    ahh this build as on wcuk right ?
  18. dbruguera
    31 Aug 2008
    didnt you change the colour on the bays in the end aswell ?
  19. subset7
    31 Aug 2008
    Think they were blue bay res's in the end,I may be wrong though.
  20. marcus000
    marcus000 Watercooling Mad
    7 Aug 2007
    Guessin you guys don't like Avatars huh? :p
