Project "Green Lantern" MAJOR UPDATE, 2 MONTHS WORTH OF WORK UPLOADED
Discussion in 'Project Logs' started by splinter_cell, 17 Jun 2004.
  1. splinter_cell
    splinter_cell What's a Dremel?
    8 Sep 2003
    Case before, completely unmodified. it will recieve a piano black coat of paint, windows on side and top, and a few new blowholes
    [​IMG] [​IMG] [​IMG] [​IMG] [​IMG]
    this thing will be recieving a new window on the side and top. 3 new blowholes will be cut (its goonna fly) all lights are gonna be green, except for the uv cathode for the mobo.
    anyway, heres the window. [​IMG]
    the purple is from the uv cathode, actually its a noce green glow coming out in real life
  2. WaZzUp115
    WaZzUp115 What's a Dremel?
    12 Feb 2004
    do a cool ninja pose pls :naughty:
    great looking window.. though i think it would look cooler if you focused on only one color inside the case. since now it looks like a rainbow or something.. thats nice in a way.. but if it would be all green it would be hell a lot cooler imo. :thumb:
    also make a cool window on the top in the same cool style. and maybe a window on the other side as well :D go dremel go! :dremel:
  3. toss
    toss What's a Dremel?
    6 Jun 2004
    Mmm i like the window man looking good
  4. guy
    guy What's a Dremel?
    20 May 2004
    that lighting looks really cool, nice clean cut outs too...
  5. juzzwuzz
    juzzwuzz What's a Dremel?
    4 Jan 2004
    :jawdrop: :rock: :jawdrop:
    Awesome effects, cool design.
    Well Done
  6. Acid Burn
    Acid Burn ..look but don't touch..
    14 Mar 2004
    very coool indeed!! what are those two green lights on the side of your front panel?
  7. TekMonkey
    TekMonkey I enjoy cheese.
    6 Dec 2002
    What are your plans for the paint job? Surely your not leaving it beige! :jawdrop: ;)
  8. R@Mo
    R@Mo What's a Dremel?
    14 May 2004
    Amazing work so far! :rock: I love the clean cutouts and the inside lighting.
    Definately should paint it though. How about black? A nice metallic blue would look cool too. If you decide to paint, invest in some Duplicolor automotive paint. Best stuff ever. :thumb:
  9. splinter_cell
    8 Sep 2003
    thanks all, the paintjob id going to be a piano black, i hope i can get that kind of gloss. the two green lights at the front arent really lights. they are holes that i drilled for something a while ago. they are going to be filled and painted over.
    i think i might do the top window, but im also putting in 2 blowholes on top, i dont know if a window would look good with them. i have an idea tho. as far as a right side window its not gonna happen, thats where all my wires are hidden :thumb:
  10. Alienhead
    Alienhead What's a Dremel?
    14 Jun 2004
    Nice decision on the window, much better than the standard design. Is it spposed to be in the shape of the letter "y"? Maybe a "G" & "L" for Green Lantern.
  11. splinter_cell
    8 Sep 2003
    there is no significance to the window, it just looked cool. also anybody got any ideas as to where i should put a side blowhole. you are welocme to photochop my images
  12. hercule
    hercule What's a Dremel?
    19 May 2004
    hey, thats a pretty sweet looking window! Great design, i like it :thumb:
    The case is gonna look pretty sweet in a gloss black. And I think a side blowhole would ruin the overall effect a bit, but if you really need one, probably put it under that grey lock thingie.
    keep on modding
  13. gLoopy
    gLoopy What's a Dremel?
    17 Jun 2004
    Nice ray of colors.
    Thumbs up, :thumb:
  14. splinter_cell
    8 Sep 2003
    hokay, i have been working on this but i havent updated on this site in a long time. hopefully the pictures will explain everything.
    lets start with to top blowholes.
    then i sleeved teh powersupply cables.
    [​IMG] [​IMG]
    not sure of the image limit per post so ill stop at 6 on each
  15. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
    you can go waay beyond six if i remember correctly. Cool window but what's odd is that hte pictures look as if the window was added with paint.
  16. splinter_cell
    8 Sep 2003
    i then lit the front grille up, i have several pics of this, but here is the best
    and the top window.
    note the 2 green fans, not one green one blue anymore
    lastly on this post is the painted front bezel. njoy.
    [​IMG] [​IMG]
    also note the painted cdrom tray. (teh floppy drive is also no longer there as you will soon see.
  17. splinter_cell
    8 Sep 2003
    lighted molexes(i have to fix em tho)
    now i know i originally said i would paint it piano black, but this looked really cool.
    the right side
    the top
    profile shot
    and the other side is in the next post, cause this is six pix :D
  18. Tulatin
    16 Oct 2003
    there is no limit of six pix
  19. splinter_cell
    8 Sep 2003
    and heres the side panel, with a new window design that didnt eat sandpaper for lunch.
    and the new window in the dark. i like this pic the most.
    the window looks kinda like a side profile of a robot head. me likey
    thats what i have done since the last update. stuff left to do.
    brush bottom panel
    brush cdrom housing like the sidepanels.
    light top window
    cut window in cdrom.
    i would also like to rename this, anysuggestions
    thats all. im icing my arms now, they are sore from sanding. :grr:
    thanks for the info tullatin, i wasnt sure how many imgs per post, some forums limit some dont. so i did six. i wasnt reading between my posts, i needed to get all this up. :clap:
  20. Quintessence
    Quintessence What's a Dremel?
    31 Aug 2004
    :rock: looks schweet so far dude, not sure about the black front panel tho...kinda throws the whole thing off IMO
