Case Mod - In Progress Project: Green Turbine update 15-08-2008
Discussion in 'Project Logs' started by Realiks, 25 May 2008.
  1. Realiks
    Realiks What's a Dremel?
    23 Feb 2008
    A new casemod: is saw this video on youtube from mnpctech. YouTube - Computer Case Mod: Turbine Cooling Fan: Part 1 :clap: I love it so I'm making one myself. Its verry sober no window. Thats the way I like it.
    The case: aopen hx45
    The old hardware.
    Inside of the case
    The back: As you can see there is not i hole for a 120mm fan. That needs to be changed :dremel:
    Dang the stickers
    Case without front.
    leds, reset, speaker
    That is so close but the 120mm fan fits. :lol:
    Front intake fan
    That is another option
    Dang pop rivets
    hdd rack
    measure
    A round hole ? :idea: flowerpot
    before
    After
    That hase to be solved
    After 30min sanding,....
    Turbine? think, think, think,....
    :idea:
    I've got it
    Thats the part I need
    Failed the fan is dead :waah:
    Front intake fan
    Sanding
  2. Jipa
    5 Feb 2004
    So what's up with the fan? It was dead already before or it died in the modding process? I think you could still salvage the cone from it... Crazy glue rarely works properly :p
  3. Farmboy UK
    Farmboy UK Hungry for knowledge
    19 Apr 2008
    Shame about the fan but good luck with the case
  4. Realiks
    23 Feb 2008
    Thanks everybody. The fan died in the modding proces I dont know how. How do I get the cone of the fan. Its really strong glue.
  5. pksjaveed
    pksjaveed Nmodz: modding the world
    28 Apr 2008
    I would use a dremel to cutl around the edges between the fan and cone heck since the fan is already broke start cutting liitle chunks of the fan off
  6. Realiks
    23 Feb 2008
    hmmm maby I think I saw a movie where they put the glued item in a freezer for I night. I think I will try that first.:thumb:
  7. nikeunltd
    nikeunltd Epic destruction around machinary
    5 Apr 2008
    haha this is going to be a sick mod. im subscribing
  8. Realiks
    23 Feb 2008
    update
    dont have mutch time so only pictures for now.If you have a question go ahead and ask
    first layer !!!!!!!!!!!!!!!!!!!!!!!!!!!!!
  9. Cheapskate
    13 May 2007
    ...And another finger biter was born.:hehe:
  10. JAxen
    JAxen What's a Dremel?
    18 Nov 2005
    For our viewing pleasure :clap:
  11. perkins teh modder
    perkins teh modder What's a Dremel?
    8 Dec 2007
    wow, i was gonna do mnpctech's "turbine" mod but I've seen it been done like at least 5 times
    if i see any more projects get started up my imagination is gonna run dry :(
  12. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    mmm chicken!!!
    i like the turbine mods (got one downstairs that i cant find the case for so cant be bothered finishing!)
    ill keep an eye on this!
  13. Realiks
    23 Feb 2008
    you ain't gonna tell me that all the 5 mods you've seen are all the same. Every case is unique :thumb:
  14. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    if we didnt would you feel better?
  15. MoRBiD
    MoRBiD Minimodder
    27 Jun 2007
    i like it :D keep up the good work.
  16. Realiks
    23 Feb 2008
    update
    What color do you think the case should get ?
    A. Orange
    B. Alienware Green
    C. somthing else
    If you vote for C. what color ?
    Pictures
    After the first layer , I hade to sand the front pannel first, after that I could put on a second layer
    The mix ^^
    Second layer.
    third layer
    fourth layer
    Some little bugs :s
    thats it for today. more soon.
    Next week my digital camera will be fixed so I will be able to make better pictures
  17. b1g-d0g
    b1g-d0g Modder
    30 Sep 2001
    Nice job so far mate :)
  18. modgodtanvir
    modgodtanvir Prepare - for Mortal Bumbat!
    28 May 2007
    Top notch execution so far dude. Can't go wrong with the old turbine mod. Way to take apart an old beige breeze block like that and turn it into something rather more interesting!
  19. Realiks
    23 Feb 2008
    I've got some great news. My neigbour was so thrilled by my mod that he let my borrow his camera for a while.
    So here are some better pictures of the fifth layer. Its already sanded
    still one little bug in the left corner :s
  20. modgodtanvir
    28 May 2007
    Oooh looking smoooth. I'm guessing its a bit of sanding, then painting? Sounds like you have a nice neighbour.
