Case Mod - In Progress Project: Green Turbine update 15-08-2008
Discussion in 'Project Logs' started by Realiks, 25 May 2008.
  1. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Awesome job! nice and smooth finish Realiks :thumb: Glad my video inspired an awesome mod. It's cool to see all of your stages posted too :)
  2. Realiks
    Realiks What's a Dremel?
    23 Feb 2008
    Thx I'm glad you like it :thumb:I'm planing to paint the case In a alienware Green color combinated with black paint. :) I'm not so professional as you guys are but hey I'm only 16 :D
  3. b1g-d0g
    b1g-d0g Multimodder
    30 Sep 2001
    Green & black my fav :D
  4. MoRBiD
    MoRBiD Minimodder
    27 Jun 2007
    Green and Black would look perfect on this.
    My wife wants me to make a Betty Boop inspired PC Case with the Turbine :|
    I guess she can wait for mine to be fixed up eh!
  5. perkins teh modder
    perkins teh modder What's a Dremel?
    8 Dec 2007
    i think ill be alright:cooldude:
  6. modgodtanvir
    modgodtanvir Prepare - for Mortal Bumbat!
    28 May 2007
    I'm guessing the turbine will be orange? So on that basis... I'd say a gloss black case with orange pinstriping. I'd have a look for orange case fans as well... I know AC Ryan do some, though I'd have to have to look for them in Europe...
  7. Realiks
    23 Feb 2008
    update Painting !
    !!!!!!!!!!!!!!!! The front was only painted once !!!!!!!!!!!!!!!!!!!
    The real alienware Green (cyborg green) wasn't really fot sale so I went for a look-a-like. Its looks nice as well with the black paint of my fan,.... I'm not much of a talker so here are the pictures. O before I forget I've changed the name to Green Turbine :D
    Foto's
    Flash
    No Flash
    Thats it :lol:
  8. b1g-d0g
    b1g-d0g Multimodder
    30 Sep 2001
    You going to spray some clearcoat on?
  9. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    yeah it will look mean with a shine!
  10. Farmboy UK
    Farmboy UK Hungry for knowledge
    19 Apr 2008
    Yum lime like! Keep us updated
  11. perkins teh modder
    8 Dec 2007
    it reminds me of an xbox 360 kinda
  12. mnpctech
    21 Apr 2003
    Cyborg green?!...thats just too cool! :naughty:
  13. Realiks
    23 Feb 2008
    Thanks for all the reactions guys. I dont know yet if I'm gonna spray a clearcoate on it, But I think so.
  14. E7130
    E7130 Shinju
    23 Apr 2007
    So you have moved onto the paint? Not to be a nitpick but is the filler as noticeable in person as it is in the pictures and the edge round the open seems more visiable on the lower left than anywhere else. Where you going to go back and sand to find your lows and highs?
  15. Realiks
    23 Feb 2008
    @E7130: I don't understand your question :duh: Do you mean that you can still see the grey of the Tube in the lower left corner? Well If it's that you mean I can tell you that its only the first layer of paint. So you won't be able to see the grey of the tube annymore. :thumb:
  16. E7130
    E7130 Shinju
    23 Apr 2007
    Well, I read it was the first layer, I just didn't know why you skipped the primer stage. Primer would have filled in a lot more than layers of paint. Paint doesn't hide imperfection well. I am not trying to get on you or anything because I think the project is looking good. I just look at painting cases like painting cars.
  17. Realiks
    23 Feb 2008
    I did put a primer on it but I just missed that spot :wallbash: as you can see its only in the lower left corner.
  18. mnpctech
    21 Apr 2003
    Do you have "filler" primer in Belgium Realiks? ...it's a thicker primer that helps cover surface imperfections... You can usually find it at Auto Body Supply shops
  19. nikeunltd
    nikeunltd Epic destruction around machinary
    5 Apr 2008
    what was the metal weight for??
  20. Realiks
    23 Feb 2008
    I don't know... I'll have a look when I'm in town. Thanks for the tip :thumb:
    What do you mean ? :blah:
