Case Mod - In Progress Project: Green Turbine update 15-08-2008
Discussion in 'Project Logs' started by Realiks, 25 May 2008.
  1. Jipa
    5 Feb 2004
    Ummh you MIGHT be able to mask the front panel and paint the inside of the tube black? Dunno, that might work and give a bit of contrast for the green to also the bottom section of the front panel.. This way you could also sand it down a bit, use more primer and get perfect finish to the tube w/o doing the whole front panel again? :idea:
    Looks nice, I'm not a fan of turbine mods (I sorta did one when I was 14 or so to my first case mod), but you sure made it nicely.
  2. Realiks
    Realiks What's a Dremel?
    23 Feb 2008
    Yes Jipa that's a good idea. Next week I have my final examination for this schoolyear so not much time to mod. But I think I will use your idea, just paint the inside of the tube black. Since I need to sand a big part of the green paint off anyway.
    Thanks for the idea. :)
  3. Jipa
    5 Feb 2004
    I'm an expert in going around the problems :D You wouldn't believe how many "whoops"s and "well I can do it this way and none will know"s I had with my last build. That's what follows when you're tired and busy trying to get the case done in time.
  4. Nolimited
    Nolimited What's a Dremel?
    12 May 2008
    nice would you paint the top of the turbine in green or black
  5. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Hes refering to this, http://i31.tinypic.com/209rarn.jpg
    what looks like a Lian Li V-series castor wheel
  6. Realiks
    23 Feb 2008
    Aah Its just a example of my casefeet I'm making in school. :p They are done by the way. I'll post an update If I have time :worried:
  7. Realiks
    23 Feb 2008
    update
    *First side pannel painted
    *Top pannel painted
    *Case feet
    *Second try on the turbine fan
    The case is starting to look verry nice. :D
    Sanding the sidepannel
    A little dent :blah:
    First layer of paint
    Turbine Fan
    Yes I know you can still see the wood :s I've forgot to use a primer ^^ :wallbash:
    Sidepannel done
    Top pannel
    Casefeet
    The front looks a bit yellow, Its only painted once because a need to sand it again, I will wait to paint it a second, third time. :thumb:
  8. JBLPL
    JBLPL What's a Dremel?
    5 Mar 2008
    Will U correct this?
  9. Realiks
    23 Feb 2008
    of course a will :dremel:
  10. Farmboy UK
    Farmboy UK Hungry for knowledge
    19 Apr 2008
    Looking nice, reminds me i need to buy some feet
  11. Dira
    Dira What's a Dremel?
    1 Sep 2005
    Nice work done. Hope the fan can handle the extra weight :)
  12. Realiks
    23 Feb 2008
    Update:
    Modding time :dremel: I've sanded the turbine fan again and I've put a primer on it. :thumb: I've also put a final coat on the top pannel. Last but not least I made a little pannel for the back outtake fan. Look @ update 1 you will know what I mean.
    Turbine fan
    Top pannel
    Back pannel
    dang :wallbash: problems again. the sidepannel won't close annymore I'll have to fix that. :D
  13. badje
    badje boni
    30 Oct 2006
    can't you put that plate on the inside of the case?
    that'll save you a single mm, or maybe 2.
    Or maybe try to countersunk the bolts a bit.
    Gl with it. mod on.
  14. Realiks
    23 Feb 2008
    I'll try to drill 2 holes so that the screws fit. The plate is only 1mm thick so that would not chause to much problems.
  15. Realiks
    23 Feb 2008
    I need some good ideas for my sidepannels. The collor is nice but there is missing somthing. any ideas ???,
  16. konvoj
    konvoj What's a Dremel?
    10 Jun 2008
    just cut some piece of metal (alu tin), give it some nice shape,polish it and glue it to the sidepanels..it could look cool.:dremel:
  17. Realiks
    23 Feb 2008
    1 good idea. But which shape did you hade in your mind.
  18. Thacrudd
    Thacrudd Where's the any key?!?
    27 Oct 2006
    That color man....wow. I can totally dig it. Put a good layer of clearcoat on and polish it.
  19. konvoj
    10 Jun 2008
    my idea was something like this,to show the "velocity look" of turbine.
    or you could use more pieces of alu in various shapes. one of my idea is this:
    polished alu could be very nice on that green sidepanel,i think.:clap:
  20. Realiks
    23 Feb 2008
    hitman logo ?
