Case Mod - In Progress Project: Green Turbine update 15-08-2008
Discussion in 'Project Logs' started by Realiks, 25 May 2008.
  1. Realiks
    Realiks What's a Dremel?
    23 Feb 2008
    update
    I've made 2 holes in the bottom of the case for some ccfl's. To create a green glow underneath. I'm not 100% happy about the result. Comments ?
  2. Realiks
    23 Feb 2008
    Update 12
    Well I’m done with school for this year. 2 months of modding time ^^ Maybe you can remember the front panel of the case. It wasn’t really nice, so I repainted it today. First I needed to do some sanding to get the little imperfections out of the filler. First I sanded it with some P180 sanding paper. To make it even better I’ve sanded it with a P1000 sanding paper. The results are rather nice in my opinion.
    Here you can see the front panel after 20 minutes of sanding. Most of the paint is gone now.
    You can’t really see much deference after the P1000 sanding paper. But when you go over the surface with your hand you can really feel some deference. I’ve put the side panel on my painting table ^^ ready for a new layer of paint.
    It looks very nice. Also look at the nice shine it has. I’ve already put a final coat on it.
    On the kitchen table ^^
    So that’s it hope you’ve enjoyed watching/reading my post. I’ve really took my time to write this update. Most of the times I just put the pictures online with no text.
    Until next time.
  3. Oreon_237
    Oreon_237 CHEA BRO!
    11 Dec 2007
    That front panel looks really good with the new lick of paint! lol the ccfl's under the case are really old school.
    Do you know how to play the harmonica?
  4. MrWizard
    MrWizard What's a Dremel?
    5 Feb 2008
    The front panel came out really really well. :thumb:
    As for the CCFL's down bottom...It fits your mod nicely, especially since you opted out of cutting a window. Adds a bit of flash to the case.
  5. Realiks
    23 Feb 2008
    Thanks all. The colour of the last picture isn’t really natural. I will try to get a better camera before my final update.
  6. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    Excellent. I like those feet too! :thumb:
  7. mnpctech
    21 Apr 2003
    Any new updates Realiks?
  8. Realiks
    23 Feb 2008
    lol
    I have to disappoint you my computer is dead :blah: The grafics card was fried :lol: The new parts will arrive tomorrow I hope. Update will be here soon.
    sneak preview
  9. lost_modder
    lost_modder What's a Dremel?
    5 Dec 2006
    glad to see your case already had a removable side panel. the cases i have like that are the one piece cover so i usually cut the side to make it removable. those square indents at the bottom of the front always bother me and always get filled. just as you did! I'm itching to get the stuff together now and turbine mod one of mine! great work
  10. pksjaveed
    pksjaveed Nmodz: modding the world
    28 Apr 2008
    wow really nice and clean especially like the cathodes
  11. Realiks
    23 Feb 2008
    My project is almost finished now. Time for an update. I’ve build in all the hardware en did some little improvements.
    I needed to drill some holes for my 120mm turbine fan as you can see on the picture.
    Mainboard in place
    The dvd/cd-rom drives needed to be painted as well.
    Made my own round ide cable ^^
    It’s the blue one :p
    As you can see on the first picture you can still see the CCFL’s on the bottom of the case. So A sanded a little plexi plate and glued it against my sidepannel.
    My new graphics card and some fan’s arrived.
    As you can see on the Turbine mod from mnpctech the have mounted a fan behind the turbine fan. I also did this. But its verrrrrrrrry noisy.
    In the dark ^^ Better pictures will be online in the next couple of days.
  12. rambo
    rambo What's a Dremel?
    14 Mar 2007
    who dude this mod is going to be so cool i like the turbine fan disigne realy nice job.
  13. nikeunltd
    nikeunltd Epic destruction around machinary
    5 Apr 2008
    omg this looks so awesome
  14. Realiks
    23 Feb 2008
    Thx all ^^
  15. IanJackson
    IanJackson Photographer & Modder
    22 Mar 2007
    looks really good!! u gunna add a window of some sort?
  16. Realiks
    23 Feb 2008
    Not a window ^^ I'm planing something else :p
  17. skullen
    skullen Minimodder
    31 Oct 2007
    Looking good Realiks :thumb:
  18. mnpctech
    21 Apr 2003
    Lookin Good!
    Undervolt the fans with a resistor or fan controller.
  19. Realiks
    23 Feb 2008
    @ mnpctech: Thx I'v put them on 5Volt ^^ now
  20. themcman1
    themcman1 is now 110% win
    1 Jan 2008
    Looking good! The fan at the front looks really nice with the case.
