Case Mod - In Progress Project: Green Turbine update 15-08-2008
Discussion in 'Project Logs' started by Realiks, 25 May 2008.
  1. Realiks
    Realiks What's a Dremel?
    23 Feb 2008
    I'm making a prototype of the logo in cardboard. Pictures will come.
  2. Darkraven
    Darkraven What's a Dremel?
    23 Dec 2006
    It's a nice logo. Can you tell me what the bottom wording means? Looks Latin and I only speak southern/hillbilly.
    Nice work on the turbine fan.
  3. badje
    badje boni
    30 Oct 2006
  4. mnpctech
    mnpctech bit-tech sponsor
    21 Apr 2003
    I love that car's cockpit. Sounds like an interesting idea Realiks.
  5. Realiks
    23 Feb 2008
    Hi all
    So my idea to make the Spyker logo will be continued as soon as I find everything a need.
    To get the background of the logo ( The little rim ) I’m going to need a little baby bicycle rim. Then make a hole in my sidepannel and put the rim in there. Then I’m going to make a round aluminum plate to get a wider surface to put the letters on. If that works the propeller isn’t going to be very hard to. Since there will be a sort of window in my sidepannel I will paint the inside of the case black.
    Something like this only more spokes
  6. mnpctech
    21 Apr 2003
    Thats a good idea Realiks, maybe you can find a good used rim on Ebay?
  7. Realiks
    23 Feb 2008
