Scratch Build – In Progress Project : GTR -X CANCELED X- sorry :'(
Discussion in 'Project Logs' started by Dark~3nergy, 20 May 2007.
  1. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    Hi all and wellcome to my first worklog !
    I have done a lot of modding before
    but I have never posted any worklog or pictures of my work.
    INTRO
    It’s called GTR (from the Ford Mustang GTR)
    It will be constructed in 4 phases,
    and it will of course be water-cooled (two loops)
    It will be 63.8cm x 55cm x 22cm and made of MDF board and plexiglass.
    BUT, sadly I don’t have to much money so it will take a wail before
    beeing finished. :waah:
    FIRST PHASE
    This will be the upper part
    Where the mobo, the pumps, radiators, reservoir… will be.
    SECOND PHASE
    This will be the lower part of the case,
    Where the psu and the hdd will be.
    THIRD PHASE
    Will be when I paint the whole case
    in orange, white and black.
    FOURTH PHASE
    Get all the hardware and assemble it.
    For the hardware :
    -evga 680i mobo
    -intel core 2 duo quad
    -two evga 8800 gtx in sli
    -4gig corsair dominator ram
    -one 1T hdd
    for the water cooling :
    -three 120 mm radiators
    -one 2x80 mm radiator
    -two laing pump ddc 1+ pump
    -two aquacomputer aquatube
    current status :
    phase 1 : ~85%
    PHASE 2 : 100%
    overall : ~80%
    Picture :
  2. Dark~3nergy
    14 Jan 2007
    THE DESIGN
    So let’s start with some sketches :
    The overall look of the case
    Here you can see the back and where the reservoir will be situated, I will use 4 xlr connectors for the two 8800 gtx and 6 rca connectors for the buttons, the fans and two white ccfl .
    The tube for the reservoir will be on the outside of the case, in the front I will put a lcd display.
    and with a 22 inches lcd screen just for size comparision
    Comments and questions are wellcome !!
    The first update will come tomorrow.
    cya
  3. NysoO
    NysoO Handcrafted
    2 Nov 2006
    Looks really nice.
    If you'll make the case as nice as the sketch, i'll be very impressed :)
  4. Jipa
    5 Feb 2004
    I like the sloped front panel, that's the optimal location for VFD if the case is on the floor... Good luck with your project!
  5. vortex46
    vortex46 What's a Dremel?
    30 Dec 2006
    nice sketch and nice mod :rock: :clap:
  6. Dj Ovin
    Dj Ovin What's a Dremel?
    7 Nov 2005
    Looks very promising! Like the sketches, very cool design on the case, and fine solutions aswell.
    Just a question: Dvd-ROM?
    Good luck!
  7. derbaum
    derbaum What's a Dremel?
    11 Apr 2004
    dvd drv ? totaly overrated ^^
    the sketches are kickass .such a n1 clean mod. definitly what i wanna see!
  8. Dark~3nergy
    14 Jan 2007
    Thanx for the comment!
    @ dj ovin : I prefeer to have the dvdrom on my desk(and i didn't get it in the design :worried: ) so it will be external (in the same theme as the case).
    I couldn’t wait so here is the first update :
    Update 1
    Yesterday I went down to the town and i bought some mdf board for the front.
    I glued them togather because the retailer didn’t have the right thickness !(ps sorry for the bad quality of the pictures,they were taken with my cellphone)
    It was THE perfect day for modding, a sunny saturday.
    when the glue dried I started to mill the ''U'' on the front .
    Then I started to mill the fan hole,but just when I finished my mill broke .
    After that I cut down the edge whit my new jigsaw, perfect !
    Then it was time to eat so I toke a pause. After that I found my father’s camera and decided to use it .
    Back to the garage I started with the other side, every thing started good but the blade went down 3 mm :wallbash: !!!!!!!
    I will have to bondo that .
    Then I started with the switch . I drilled a 20 mm hole on one side and a 30 mm hole on the other . PS I made a wrong measurement on the fan hole as you can see but I will fix that later
    Now I have two identical holes for the switches !!!!
    Put one of the bulgin switch to see if it fits .
    Yeah , it’s perfect
    Here you can see how it’s ends up, that’s all for today.
    Next update will probably be in 4 days .
    Cya !!
  9. Guest-23315
    Guest-23315 Guest
    Very nice design ideas and CAD work there..
    Nice hole work aswell..
    I think you deserve some stars :D
  10. Dj Ovin
    7 Nov 2005
    oh, i see! Maybe the best, too cool design without it.
  11. Noobkiller
    Noobkiller What's a Dremel?
    11 Jun 2006
    Awsome! I'll bewatching this one ;)
    (Subscribed)
  12. arkadur
    arkadur What's a Dremel?
    3 May 2005
    man, you got some serious design skils..
    waiting (in impatience ) for the next update..
  13. Dark~3nergy
    14 Jan 2007
    update 2
    Hi all and thanx again for all the nice comments !
    It's time for the next update, I said that it should be in 3 days
    but I had time left this lunch so I worked a little .
    UPDATE 2
    I don't have so many pictures of the work, just the result.
    I started to make the bottom panel, I cut an opening for the cables and the rest with my jigsaw, it ended up realy good.
    Then I cut the hole for the window.
    I put all the part together ,it starts to take shape, and now I'm happy !
    Comments are wellcome.
    cya !
  14. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    This is looking awesome so far dude! If you can pull this off, it'll be one of the best looking mods I've seen. :D
  15. exitus
    exitus What's a Dremel?
    25 Apr 2007
    really cool! what would be VERY cool would be a "made in switzerland"-logo, just like on my knife set :D
  16. derbaum
    11 Apr 2004
    normally i hate mdf cases but this one turns out really well.
  17. Mr. Oizo
    Mr. Oizo That yellow furry animal-thingy
    18 Mar 2007
    Good luck with this mod! The design is looking really cool. If the result looks the same, then your case is a MEGA CASE! :thumb:
  18. Dira
    Dira What's a Dremel?
    1 Sep 2005
    Very nice :) Only 1 thing! You should have some filters for the front fans to keep dust out of this beauty. GL & Keep posting!
  19. elbarto241
    elbarto241 What's a Dremel?
    12 Sep 2006
    filers = less airflow. depending on the filter you use. You might wanna consider not even using it unless you have carpet or pets. I have ceramic tile flooring all the house =D not as dusty as carpet :thumb:
  20. Handon
    Handon What's a Dremel?
    10 Feb 2007
    That just looks so awesome... keep on modding !!!!!!
