Scratch Build – In Progress Project : GTR -X CANCELED X- sorry :'(
Discussion in 'Project Logs' started by Dark~3nergy, 20 May 2007.
  1. Axiom UK
    Axiom UK Next Level of Modification
    11 Sep 2007
    this is such a good project how will you paint it as i belive that you would feel that it is made from wood and is it heavy?
  2. ComputerKing
    8 Sep 2006
    What the Hell :rock: :rock: :jawdrop:, I hate you because you missed all that on me :wallbash: you kidding me! :eeek: Your wood work is more than perfect! It's incredible! I don't know how to explain! I'ts a very nice work, I love that water Gear :hip:
    Keep It up :rock: , I'm really thankful that you uploaded them to me to watch them and get WOW :eeek:
  3. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    thanks man ! i'm gonna upload more on potobucket tomorow :D
  4. C-Sniper
    C-Sniper Stop Trolling this space Ądmins!
    17 Jun 2007
    FINALLY AN UPDATE!!!
    I was looking at the pictures and it looked to me as if your SB WB the hose could interfere with the PCI-E slot.
    Just a heads up on what i saw.
    Looks awesome though. keep the updates rolling.
  5. Dark~3nergy
    14 Jan 2007
    small update
    HI !
    Thanks for all the possitive comments :D !
    @ Axiom UK : I don't realy want it to look like wood, I prefeer car paint like this but in orange.
    @ C-Sniper : The tubes from the sb wb won't intersect with the GPUs, I've already checked that.
    UPDATE 10
    Today I screw the top part to the case,
    I'll let the photos talk for them selfs.
    I'm sorry it was a very small update but it's still something.
    But that's all for today !
    cya
  6. legoman666
    legoman666 Beat to fit, paint to match.
    24 Aug 2003
    I don't want to be nitpicky, but you should really bondo those imperfections on the top of the case in the ridges. Looks like where the mill bit (or router bit) slipped. And some of your fan holes aren't quite round, sand the inside of em good. but besides those small things, looks great! damn nice sketch-up work.
  7. Dark~3nergy
    14 Jan 2007
    Update 11
    Hi all.
    UPDATE 11
    Today I assebled the second side panel to the case,
    First I rebuild the panel because I made some wrong mesurments on the first, I used my router.
    then I drilled some holes for the window:
    The corner went round and I don't know if I should let them be that way or if I should make them square:
    Then I fastend some of thoes things on the back side in the corners :
    After that I put the side window in place to see how it fits :
    I still have to do the 45° cut in the upper right corner.
    then I screwed the panel to the case :
    After that I applied some bondo to hide the screws :
    The screws are 7mm to long, I'll have to cut them.
    I repaired the U thing at the back of the case:
    That's all for today :D
    Comments and questions are wellcome
    see ya !
  8. Kylevdm
    Kylevdm The Mod Zoo Podcast Host
    4 Oct 2007
    is looking great can't wait for the end product :p
  9. C-Sniper
    17 Jun 2007
    yay! an update!
    Looks good keep it up and don't let it die!
  10. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    I just can't help thinking this case is going to get ruined by a mere chip on the wood. :/ Have you thought about fibreglassing it?
  11. Supra55
    Supra55 What's a Dremel?
    10 Oct 2006
    Fiberglass or no this is one sweet mod.
  12. DragonONE
    DragonONE What's a Dremel?
    27 Jun 2007
    I do agree with Supra55 - it is indeed one sweet mod..
    but one thing popped into my mind? How do you access the hardware? Thru the side panel, as in unscrewing the window? :) Oh -talking about window - have you considered countersinking the attachment thingy on the inside? - might not be so easy now, having bondo'ed the screws... :D
    Never the less - cool design and very nice work. I'm looking forward to next update. ;)
  13. C:\Joshy
    C:\Joshy How much cake can you eat in a min?
    30 Aug 2007
    Looking great.
    just one qu: what are the holes for under the reservoir. [sorry if you have said already.
    Keep up the good work
  14. Dark~3nergy
    14 Jan 2007
    UPDATE 12 !!!
    Hi again and thanks for all the comments !! :D
    @ DragonONE : I just have to unscrew the screw to access it, the attachment things can't be seen from the outside so there's no need to countersinking them.
    @ Duste : sry but i don't realy understand what u mean with "mere chip on the wood" ? and I don't think I'll need to fiberglass it.
    @ C:\Joshy : the holes are for RCA connetors, I ordered them for 2 weeks ago but haven't recieved anything :grr:
    UPDATE 12
    Today I have started the Phase 2 and paused the Phase 1for some days, I'll restart working on it when I'll recieve some stuffs ( RCA, XLR, ... ).
    So, I went to a local store to buy some MDF (a lot) to start on the seconde phase :
    To do this :
    I just put it together to see how it looks :
    Then I made the bottom and the upper part :
    after that I made the 45° cut on the front :
    just a pic to show how the rca looks like (I had one from one of my previous mod) :
    Than I put it together with some duck tape and put it under the rest of the case :
    I made the last side panel for the upper case :
    That's all for to day, but I'll be working on it on saturday for a big update !!
    cya ;)
  15. DSquareD
    DSquareD What's a Dremel?
    24 Nov 2005
    isnt that system gonna get really hot inside the wood?
    isnt it bad for ventillation?
  16. weasal
    weasal What's a Dremel?
    22 Jul 2007
    the material shouldnt effect the ventilation its more whether he has enough intakes and exhaust for the system and judging by the look of his sketchup it shouldnt have 2 many problems.
  17. Nikko
    Nikko What's a Dremel?
    14 Sep 2006
    Damn IT! I like it so much! Can i ask you DªrK~3n3rG¥ ...could i use your design for my case...its just impressive! My uncle have big factory for furnutyre and it will be not a problem to make it for me ;) Could i ?
  18. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    very nice
    :thumb:
  19. Kylevdm
    4 Oct 2007
    i just about this mod today (been on holiday and my exams are in 11 days ahhh) but whats happened ???
  20. Dark~3nergy
    14 Jan 2007
    I'm back
    Hi all,
    I'm sorry I was on vacation (again) but now I'm back,
    I made some progress but it was not enough to show it.
    I'll work on it tomorow afternoon and post an update.
    Nikko: I'll have to think about it, then I'll PM you.
    thanks all.
    cya !
