Scratch Build – In Progress Project : GTR -X CANCELED X- sorry :'(
Discussion in 'Project Logs' started by Dark~3nergy, 20 May 2007.
  1. Dark~3nergy
    Dark~3nergy what was dat sandvich ?
    14 Jan 2007
    thanks !
    I was going to post an update this evening.
    but it's not soo big, because i've only got time to do bondo/sanding and some other small things.
    cya :)
  2. Angleus
    Angleus What's a Dremel?
    28 Nov 2007
    WOO! :D
  3. ou7blaze
    ou7blaze sensational.
    5 May 2003
    This is shaping to be one very good looking mod.
    I like the simple design (well I think it is..).
    I actually think it would look great completely white, with the white cathode.
  4. La carotte d l'o
    La carotte d l'o What's a Dremel?
    27 Nov 2007
    I think that yellow with black stripes would be better than white, white mustang doesn't look fast enough. :) Actually i think that mustang should be blak or blue, but those colors are too basic for modding.
    I used an old rpm meter for my project as a hdd-led, maybe that would in fit this mod too?
    http://allthemods.com/img/07/2403.jpg
    This looks so nice so far, i would be glad to have it. Nice to see that someone uses wooden materials to make something different than usual boxes. :thumb:
  5. Dark~3nergy
    14 Jan 2007
    HI all ,
    sry for the delay but last week was realy busy.
    @ mnpctech : Thanks :blush:
    @ brinkz0r : I'm gonna do that tomorrow, if I have enough time.
    @ La carotte d l'o : maybe but I don't know where I could put it and I am an absolute newbie with these electronic stuff,
    but now it's update time :dremel: !!!
    UPDATE 15
    I'm realy sorry for the quality of the photos, I don't know why but they turned out realy bad :sigh: .
    so, last saturday I bought a new tool and I recieved an aquaero and some fittings,
    It's realy good and now it goes a lot faster to sand :)
    The first thing I did was to glue the two parts together but I dont have a photo to show that.
    then I drilled 2 holes for the cables:
    after some cutting and sanding,
    then I started to fix the front with some bondo but it's not finished yet:
    then I cut an opening in the top piece and sanded it down to the size of the aquaero:
    but it was a litle bit too wide so I'll have to fix that.
    I put it in place to see how it looks
    I still have a lot to do on that part.
    then I put the fittings in place:
    and I drilled a hole for one of the xlr to the two 80mm fans:
    and here's some shots of the rear :
    that's all for today ! probably more tomorrow.
    comment and question are wellcome, cya !
  6. Kylevdm
    Kylevdm The Mod Zoo Podcast Host
    4 Oct 2007
    nice like the xlr idea
    *writes in notebook of knowledge and laughs*
    anyway a merry Christmas to you and everyone
  7. dan-ere-07
    dan-ere-07 What's a Dremel?
    29 Mar 2007
    what are these fittings
    because i would like to use something like that in my case
    and are they the same on the back?
  8. Dark~3nergy
    14 Jan 2007
    they are the same on both side but I don't know what they are called in english.
  9. theAlien
    theAlien I know what a Dremel is....
    20 Aug 2007
    they are called :
    10/8mm Compression Bulkhead
    Alan
  10. dan-ere-07
    29 Mar 2007
  11. Dark~3nergy
    14 Jan 2007
    update 16
    HI update time !!!
    first I had a litle side project:
    I upgraded my current computer because it was realy slow(AMD athlon x2) , to a q6600. And now it's realy fast :lol: !
    I changed the mobo from an asus crosshair to the evga 680i from the gtr but I'll put this hardware back to the gtr when I've painted it.
    And I also put the aquaero in this one to test it, and I really like it.
    anyway here's some pictures :
    nice waterblock :D
    anyway, here's the update !
    UPDATE 16
    today I made the bottom side panel,
    I used a 50x25 cm plexi sheet and cutted it to the right dimmention:
    then I drilled some hole an cutted the 45° cut at the top and I placed it on the case to see how it looks.
    but I didn't drill all the holes.
    I also "test" painted the inside in white and I'm really happy with the result :D
    that's all for today, maybe more tomorrow.
    comments are, as usual, wellcome :) !
  12. Cheapskate
    13 May 2007
    The white with the shadow box lighting is very effective. I like it.
  13. Kylevdm
    4 Oct 2007
    nice cant wait for the paint job to be finished
  14. 500mph
    500mph The Right man in the Wrong place
    22 Jun 2007
    wow, with nothing else in it it looks so barren, but yet, it looks good. i cant wait to the the full loop in there
  15. Macros_the_Black
    Macros_the_Black Yup.. I'm a f-ing reptile
    7 Jul 2007
    Sweet luminosity Batman, that lighting is absolutely brilliant!! B)
    This kind of lighting would be perfect for a mod idea I have had for a while, thanx a bunch for showing me the light and giving me inspiration!! :thumb:
  16. Thacrudd
    Thacrudd Where's the any key?!?
    27 Oct 2006
    Looks very clean and sturdy. I am totally infatuated with the compression fittings and the whole res chamber mounting wall thing. It truly is looking to be a top-notch mod!
  17. Teyber
    Teyber ******
    18 Mar 2007
    those photo's look very professional! Those last two pictures are mind boggling...
    great work!
  18. brinkz0r
    brinkz0r Minimodder
    15 Dec 2006
    I'm really happy with the result too :D
  19. x06jsp
    x06jsp da ginger monkey!!!!
    2 Apr 2007
    looking good there mate:thumb:
  20. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    I can only agree with the others: it looks great!
