i want to ask something, im from malaysia. where did you buy the arcylic and other stuff?. in singapore or malaysia?
Thanks ! Messy wires just dont seem to cut it anymore do they hm nor motherboards for that matter seeing more and more mods incorporate covers of some sort.
heres a large update just before christmas. Ive put the finishing touches on both motherboard covers,done some psu modding, and now im all set to go full swing with most of the electronics. Some motherboard cover goodness: 40mm Fans installed on the top piece.Test psu in the background.. Now where most of the work had to be done.The pci cover.A row of jackplugs fills up the previously empty space. Now the addition of 3 modular connector type sockets, which will feed power and stuff to the 7 jack plugs. First a triangular hole was created.Then the mounting of the sockets on a seperate plate that mounts into the hole. (a laser cut piece as i couldnt get the right size hole for the sockets). The small rectangular slot will be for the jack plugs to feed from and into the jacks. Remember the space on top of the plate where you could see the red graphics card? It was for this : The halycon word logo will be lit from underneath, but as of now im not sure what colour LEDs to use.Most probably red or blue. A few pictures of the completed covers:
On to the psu, which was a antec 550w, with a beautiful 3 year warranty.previously. After i was done with it, heres the unit with the addition of a junction box, and missing quite a few wires.The junction box takes power from the 2 molex lines that were from the psu.Theyll be used to power less impt hardware like the rheobus, cdrom and such. Hardisk, PCI-E connector, AUX and atx cables have been left as is. Other unnecessary wires were cut away. After the unit was mounted into the casing, .The atx cable was routed through black wire loom, and into a hole in casing.All part of the stealthing process. All the tape used for identifying the pins. Heres what happens after it goes through the hole : And after some sleeving of the remaining cables Will be back in the next update to show how all that wiring arrangement will fit with the motherboard tray when its in place..For now Merry Christmas to all
When you say you got rid of the unnecessary wires, did you just desolder them from the PSU? I'm doing a little project with a test power supply and I'm just wondering if it's safe to desolder wires from the power supply itself. I'm loving that junction box - the connectors remind me of the modular connectors for the Hiper Type-R power supplies.
thank you very much I did;nt desolder the wires, wouldnt have dared really. I was afraid other wires might come along with whatever I removed.Antecs wiring inside is a little messy..I suppose if you got some skills and a good iron you;ll be able to do it with no problems. But what I did was cut off the wires i did'nt want, and sleeve the ends with heatshrink to prevent any shorts.Then just tuck them away in the psu.
This mod of yours is so clean! I like it dude May I ask you the name of the (4 pins) plugs you used as molex substitutes?
well im not sure what they;re called actually.I kinda just picked them up because they looked good. But according to the hyper type psu website, they refer to them as "aviation type heavy duty enamel modular connectors". Seriously dont think what I have are of that quality though..
well a antec was what i had to work with..besides, and i wanted the position of the plugs to be as such The hyper psu was way more expensive too..
True, true. All of the antec psu's I've owned had **** volt's. Hope yours is better. Going to paint it or cover it at all? Grey is ugly
Very appreciative of the nice comments so far.thanks guys Yea hope mine doesnt crap out on me alright..Painting wont be necessary, once its mounted properly in the case you cant even see the psu mostly..
