Project:Halcyon in Black-12/06/2007 Credits.
Discussion in 'Project Logs' started by Excalib12e, 27 Oct 2006.
  1. Excalib12e
    Excalib12e What's a Dremel?
    19 Oct 2002
    small update :
    First of all, I got the hard disk meter wired up and working finally..
    Ive decided to house the circuitry inside the casing instead of on the rear.
    The hdd meter circuit is in the black box, the lead with the jack plug is for power, it will plug into the PCI cover plate. The other lead connects to the LED meter by a vga plug. That way I can remove everything easily, which has become a goal in this project. The last lead connects to the hdd header on the mobo.
    Here it is in testing :
    Ive salvaged a old pci back plate from a graphics card and intend to use that to mount the vga plug from the meter. Dont have pictures at the moment though
    Finally, a video of the working meter :eek:
    http://www.youtube.com/watch?v=gn-0GpQUMYk
  2. Sphering
    Sphering What's a Dremel?
    31 Oct 2006
    Great work, Looks stunning. Is it possible to delay the action somehow? Goes very fast from bottom to top, so it is a bit difficult to enjoy the the great work you put into this HDD meter.
  3. Excalib12e
    19 Oct 2002
    Hi, unfortunately im not very good at electronics :idea: So I have no idea how to slow the action down..
  4. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    Put in a capacitor
  5. Excalib12e
    19 Oct 2002
  6. Sloth
    Sloth #yolo #swag
    29 Nov 2006
    Didn't look and see it was a meter like that until after posting, thought it was analog, lol, in that case I have no clue, sorry
  7. cedricb
    cedricb What's a Dremel?
    5 Dec 2006
    very nice mod
  8. Excalib12e
    19 Oct 2002
    thanks cedricb..
    No problem :D Il just have to live with the speed the meter runs at, not that it really bothers me though :)
  9. Excalib12e
    19 Oct 2002
    ok this is a more than overdue update, apologies to the slow going project, but i predict il be able to finish it in about 3 more weeks or so :D
    If everyone remembers the small window next to the large one on the side panel, I had intentions of just leaving it as is so one could view that section of the case. But it didn;t look too right, so after some planning, I decided to mount a plate , together with the USB n audio ports fron the casing front.
    This plate had to be be laser cut, because i wanted this :
    A biohazrd logo
    After mounting the ports like so (will cover on where these will plug to in the next update. think sound card modding.)
    Now to get to work on backlighting that biohazard cut out.
    First, red acrylic.cut to size, sanded, and glued to a piece of white acrylic.
    Red and white together would give me some sort of orange when light was passed through, or so i assumed.
    For the lighting part, i drilled 2 holes on either end of a spare project box cover i had lying around
    After ripping the bare 10cm cathode out of its casing, it found its new home here .fits perfectly
    On its own the lighting produced wouldnt be even, so a piece of tin foil was used to line the cover, and the result is much better.
    The whole assembly was glued together.Acrylic behind the logo , and cathode behind the acrylic
  10. Excalib12e
    19 Oct 2002
    now for the money shot, when the cathode was lit up .
    Its orange all right..
    After proper mounting it should look something like this :
    Thats it for now, finishing up on some other areas and will be back pretty soon.
  11. Duste
    Duste Sierra my delta, bravo!
    1 Oct 2006
    Now that is NICE!
  12. WiK1d
    WiK1d What's a Dremel?
    16 May 2006
    That is freaking awesome!! Man this casemod is so cool :D So neat. I lurve it...
  13. Gnemelf
    Gnemelf Minimodder
    9 Aug 2003
    looks good mang I really like it!
  14. wbdog206
    wbdog206 not me
    15 Jan 2007
    Very good looking mod.
  15. malccy72
    malccy72 Minimodder
    9 Jan 2005
    Very tidy. Good work.
  16. marauder16
    marauder16 What's a Dremel?
    30 Sep 2006
    that Bio-hazard plate is awesome, great idea :rock:
  17. Evenge
    Evenge Minimodder
    16 Sep 2006
    Nice work! :thumb:
  18. Excalib12e
    19 Oct 2002
    a big thank you to all the great comments :)
  19. exo²
    exo² What's a Dremel?
    22 Dec 2006
    i like wath yoiu dit with the cabels
    nice mod
    keep going
  20. Yutani
    Yutani What's a Dremel?
    13 Jan 2007
    Looking really good, keep up the nice work. That mobo cover is absolutly fantastic!
