Project:Halcyon in Black-12/06/2007 Credits.
Discussion in 'Project Logs' started by Excalib12e, 27 Oct 2006.
  1. jokkos
    jokkos too busy to mod *sigh*
    10 May 2005
    that thermal plug thing is a very good idea. I have to remember that one.
  2. Excalib12e
    Excalib12e What's a Dremel?
    19 Oct 2002
    All thanks to the jack socket and the barb happening to be next to each other on my messy table. :D
    Only issue is the goop wont cure properly if the barb is filled completely at once..I had to do it in 2 parts, and even then there were air spaces. But its all watertight now..
  3. Dreamslacker
    Dreamslacker Minimodder
    13 Sep 2006
    Should be fine actually.
    When the contractors did up the tempered glass panels at my new branch, they just pumped a big load of silicone into the "guide rails" (basically just U-shaped aluminium brackets) and let the outside cure. If you prod it, you can tell the insides are not cured but it holds the big chunk of glass in place nicely.
  4. Bbq.of.DooM
    Bbq.of.DooM Custom User Title
    12 Feb 2005
    Pro tip: Wash the mobo with rubbing alcohol (it evaporates faster), let it sit for a few days, and it should work again. Unless it was running when it leaked.
  5. Andres
    Andres What's a Dremel?
    28 Jan 2007
    I couldn't follow which material you used for the front, could you name it please, I like it.
  6. Excalib12e
    19 Oct 2002
    Thanks Dreamslacker, the barb must have been a slightly different case though, as air bubbles would get in. But its fine already :D
    Afraid is was :wallbash: . But its ok, ive gotten most parts replaced under warranty, except for the graphics which will take a while more.The parts were quite truly dead. :duh:
    Do you mean the black acrylic plastic?
  7. hellas91
    hellas91 What's a Dremel?
    18 Feb 2006
    Optimal realization dude :)
    I like your style ;)
  8. customh
    customh conflagration.
    22 Oct 2005
    I like this, look forward to seeing it come together!!
  9. frankee
    frankee What's a Dremel?
    6 Feb 2007
    its nice. the black acrylic on the white case looks just owesome :rock:
    i wanna see more :D
  10. brinkz0r
    brinkz0r What's a Dremel?
    15 Dec 2006
    I can't believe I missed this one for all this time. I really like the covers and the lasercut parts.
    Continue making quality stuff like this ;)
  11. RxPIXel
    RxPIXel What's a Dremel?
    7 Feb 2007
    god dam thats a clean mod.
  12. Excalib12e
    19 Oct 2002
    Hi all..Now i know its been a whole month since ive posted anything, And im really sorry for the long long wait. All the parts have thankfully been replaced, and im all set to continue with finishing up this project. Just got to work out some odds and ends.
    In the meantime heres a teaser pic of the mother covers somewhat installed (this was before i destroyed the hardware)
    several things will be changed,like the rear plate, as one month has brought some new ideas to mind.As you can see the 4 LED holders are not exactly in order.So the whole plate will be redone and something else installed.Will be back soon.Cheers..
  13. Tale Gunner
    Tale Gunner What's a Dremel?
    15 Dec 2006
    Damn sorry about the damage from the water. Thats why in my build I am building a pump housing with its own PS. That way I can run the water pump filled and watch for leaks prior to adding the motherboard and vid cards. I have too much at stake with dual 8800 GTX vid cards and a SLI motherboard.
    Nice touch with the temperature probe in the 1/2 inch barb. Gives me an idea to use a "Tee" with a temperature probe. Thanks
  14. Excalib12e
    19 Oct 2002
    Well was pretty much carelessness on my part.. :duh: Glad everythings replaced..Your welcome bout the temp probe.. :hehe:
  15. Fozzy
    Fozzy What's a Dremel?
    25 Jan 2005
    I like that you created the temp probe. That's pretty cool. You may want to look into some of the professionally made ones for innovatek or aquacool stuff though. They look a little better.
  16. Excalib12e
    19 Oct 2002
    Thats ok for me, itll be kinda hidden so it really doesnt matter much.Thanks for the suggestion :)
  17. Excalib12e
    19 Oct 2002
    update time..
    apologies.Been struggling to get this project done amidst my work, so far ive been able to do a little, so here goes another update :
    Now I realised that the HALCYON cut out on the pci cover wasnt doing a very good job of providing ventilation holes. Plus I started to find it a bit ugly.So away it went, and in its place, a simple but functional grill, laser cut of course. A large rectangle portion of the cover was also cut away.
    I forgot to get the mounting holes lasered too, so i had to carefully drill them myself. Luckily the acrylic didnt crack..much better ventilation im sure.
    The temperature display on the rear plate had screwed up (digits only half displayed), plus the previous LED misalignment had been bugging me.So a whole new plate was made, and a proper backlit temperature display ordered from frozencpu.
    Now with the LEDs gone from this arrangement, they had to go somewhere else. Oh if i hadnt mentioned this before, the LEDs serve to indicate which temperature the probe is currently measuring. I decided to mount them on the top mobo cover
    Some masking..
    The 2 new added sockets on there are for the LEDs. Plugs from the PCI cover below will connect to them. I kinda wanted the added cabling for looks too.
    Here you can see the plugs...
    Im almost done with fixing things up motherboard covers wise, so i hope to update soon.till then.. :)
  18. Axel
    Axel What's a Dremel?
    20 Feb 2007
    holy ****
  19. elbarto241
    elbarto241 What's a Dremel?
    12 Sep 2006
    holy **** doesnt even begin 2 describe it. speechless.....
  20. jegerjon
    jegerjon What's a Dremel?
    10 Jan 2007
    omg... That's some clean work! Very well done :)
    Can't wait to see this finished
