Project Halo 2 mod box. UPDATE on 6/26
Discussion in 'Project Logs' started by blurredvision, 12 Jun 2004.
  1. R@Mo
    R@Mo What's a Dremel?
    14 May 2004
    Very nice so far. :hip: Can't wait to see all the overall case lit up by the LED's! :rock:
  2. RobbieGSM
    RobbieGSM Banned
    26 Nov 2003
    Howzit,
    Case is looking really nice so far, good job! :D, keep it up boet!
  3. Langer
    Langer Jesse Lang
    24 Jan 2004
    Does anyone else see only x's?
  4. ¿þŘΩĐĮĢΫ?
    ¿þŘΩĐĮĢΫ? What's a Dremel?
    13 Jun 2004
    his sever must be off or his image host is having some problems
  5. blurredvision
    blurredvision What's a Dremel?
    8 Jun 2004
    You guys ate up my 3GBs of bandwidth in a damn hurry, that's what happened! And I have a ton of updates to add, just gotta wait till Thursday (new month) to do it.
    I even got my leds in and I have stuff lit up! If you want a sneek peak, type this link into your browser bar: http://pics.bbzzdd.com/users/blurredvision/IMG_0697.JPG I can't link to it, but you can type it in if you wanna....
  6. ¿þŘΩĐĮĢΫ?
    13 Jun 2004
    link does not work. *sorry* pic does not work
  7. blurredvision
    8 Jun 2004
    Read my post, you have to type it in if you want to see the pic. You can't link refer to it, but you can always type it directly in your browser bar, and hit enter, and it will pop up.
  8. tmod
    tmod What's a Dremel?
    9 Apr 2004
    Ooh...that lighting looks nice. :thumb:
  9. Sc0rian
    Sc0rian Here comes the farmer
    23 Feb 2003
    yep :worried:
  10. andrew
    andrew What's a Dremel?
    11 Aug 2003
    Well I would just like to say how nice this is turning out, especially since it is your first mod. :)
    I have got the picture that you linked above hosted. Here it is for everyone else:
    [​IMG][/IMG]
    You can host your pictures on here :thumb:
  11. Mister_Tad
    27 Dec 2002
    you shouldnt have too much problem finding somewhere to host them, check the "fix your pix" sticky at the top of the PL forum, there are a few people in there who offer free hosting
  12. blurredvision
    8 Jun 2004
    Ok, pics are working again. I'll have to wait for a couple of days to update, however, because my main comp with the card reader is down for a couple of days while I wait on some CH-5 chips to arrive.
  13. Starbuck3733T
    Starbuck3733T Look out sugar, here it comes
    16 Sep 2002
    Love the project so far mang!
    The key to getting perfect paint is prep.. so a few queries:
    -You must sand the factory orange peel off for the mirror finish.
    1.) did you sand the panels before you primered them?
    2.) did you sand them after your primered them?
    3.) did you sand after the color?
    4.) did you hit it with rubbing compound after sanding the top layer (clear coat?)
  14. Stigma
    Stigma Banned
    13 Jun 2004
    Nice
    How can I fix my avatar, it won't work!
    It's marked in the circle where it says "no avatar", I try to remome the mark, but it wont work!! Help me!
  15. Nath
    Nath Your appeal has already been filed.
    28 Dec 2003
    You need 85 posts or more to have a nice avatar like mine....
    read the rules.
  16. Silverstrand
    Silverstrand What's a Dremel?
    29 Jun 2004
    Your doing a great job! Very nice choice with the paint. I'll be waiting for more progress.
  17. Halgy3000
    Halgy3000 What's a Dremel?
    22 Mar 2004
    That looks awsome.
    PEACE
  18. Acid Burn
    Acid Burn ..look but don't touch..
    14 Mar 2004
    Looks sweet! I hope my dragon will light up as nicely as your logo! how did you light it? with leds from the side or with a cathode?
    Mod on mate!
  19. Sol Badguy
    Sol Badguy What's a Dremel?
    29 Oct 2003
    i love it. but the vents on that side panel are ruining the whole thing. are u planning to just add a small window above that logo? i think it would look better than those vents. but thats just me. keep up the good work...
  20. cogitoergosum
    cogitoergosum What's a Dremel?
    14 Jul 2004
    Definietly a cool looking mod. Keep up the good work. Two thumbs way up! :thumb: :thumb:
