Project - Halo crusher - UPDATE recieved some parts
Discussion in 'Project Logs' started by pumagt500, 14 Jan 2005.
  1. pumagt500
    pumagt500 What's a Dremel?
    13 Jan 2005
    Plan - Turn a old AT case into a ATX case
    Reason - Lan parties and all out fun
    Pics - http://51600.cjb.net/halo.html
    Those pictures above will be moved soon to a new domain. Thats the pogress so far. Any new update pictures will be posted here.
  2. Langer
    Langer Jesse Lang
    24 Jan 2004
    Hate to burst your bubble but:
    Also your photography is soo bad that you can't even tell what the pictures are of; lastly I diddn't even see any significant mods on that case.
    Now that that is all out of the way...I'm sure it is a very nice mod. :hehe:
  3. pumagt500
    13 Jan 2005
    Sorry but my camera is a intel play with no flash. If you actually read the page it said the disasembily process. I havent modded anything yet. so sorry to inconvience you :waah: . Im getting a new camera :D .
  4. Langer
    Langer Jesse Lang
    24 Jan 2004
    Wow...I'm an ass; sorry if I came across a bit harsh before.
  5. ¿þŘΩĐĮĢΫ?
    ¿þŘΩĐĮĢΫ? What's a Dremel?
    13 Jun 2004
    darn it LANGER!!!!!!!
    take it easy on the new guys...........
    it's okay, i'll protect from the big bad wolf *waves stick at Langer*
    "Back, BACK!!!!!!!!"
    (j/k)
    Welcome to Bit -Tech, aws Langer said, you should try to hold the cam a bit more steady, and more light, and when you got some modding pics post them on this site, not as a link, and then the admin won't have a problem with ya
  6. Nexxo
    23 Oct 2001
    Welcome to the forums, pumagt500! :clap: Although I eagerly look forward to your mod, the other guys here are right: you have to post pics (not links to pics) and you have to be able to show some modding in progress. Just showing case disassembly on its own is not enough.
    Usually it is best to wait with posting a project log until you are already some way into it, so you have something to show off.
    Also quality of pics counts --light your indoor shots properly, make sure the shot is focussed and use a tripod/support to prevent camera shake/blur. No point in trying to show off a spectacular job with poor pictures.
  7. Langer
    Langer Jesse Lang
    24 Jan 2004
    [off topic]Hey Nexxo when are you going to finish Metaversa? we are into year 3 are we not?[/off topic]
  8. Nexxo
    23 Oct 2001
    You can't rush perfection. :D
  9. pumagt500
    13 Jan 2005
    Thanks. Ill have some updated pictures tonight.
  10. pumagt500
    13 Jan 2005
    What size bit do you recomend for drilling the holes for the mobo standoffs? I gotta tap them too. Or I could buy a mobo tray and rivit it over the old one. what do you think? Has n e one ever put a car radio in a caomputer cd bay. I have a open bay I wont use in this comp. I think it would be awsome especialty at lan partys.
  11. ^_^ babyroach
    ^_^ babyroach What's a Dremel?
    30 Aug 2004
    I cant even see what those pictures are of.. :wallbash:
  12. penski
    penski BodMod
    29 Aug 2002
    I have moved this to Modding for the reasons outlined above.
    PM myself or another moderator when you are ready to turn this into a full and proper project log.
    *n
  13. zerocom
    zerocom What's a Dremel?
    13 Jan 2005
    always happy to see someone starting something new...
    best of luck to your firstone...
    :thumb:
  14. pumagt500
    13 Jan 2005
    The top view of the case after its ben stripped down.
    The front of the case with all the buttons removed.
    Closer view. You can see the keylock that was located all the way too the left and is now gonna be the second too the right. The two left side holes will be filled today.
    The holes.
    [​IMG] ]
    With some of the buttons in place.
    The buttons.
    The rear.
    Keylock.
    Some images of the case:
    That plate I removed it restricted aire flow and got in the way of where the air duct will be.
    [​IMG] [​IMG]
    More updates soon. Sorry I couldnt get much done but there was a death in the familey.
  15. pumagt500
    13 Jan 2005
    http://images10.newegg.com/productimage/11-998-102-05.JPG
    Im getting 2 of these.
    http://images10.newegg.com/productimage/00-883-006-01.JPG
    http://www.newegg.com/app/ViewProductDesc.asp?description=00-883-006&depa=1
    Ill get this is I can take off the voice control portion. Does anyone know if thats possible to bypass the PCI plate stuff in the back and the voice controll box?
    Kinda sucks that the only place around here toget electronic parts is the ratshack. I guess Ill have to take a trip tommrow and spend $600 on two rocker switches and some heat shrink tube.
    -Unless you own Newegg, your'e thieving their bandwidth with those pics, IMG tags removed - Mister_tad
  16. shroom
    shroom What's a Dremel?
    6 Aug 2003
    Judging by the pics, and from my past experience with the "voice activated whatchamathinger" aka sound activated circuit so itll blink to the taps of your hard drive, it should have either an on/off switch, or you could adjust the sensitivity up all the way so if theres something moving in a 20ft radius itll be blink, which will give you a conastant light, considering itll be in a pc case.
  17. pumagt500
    13 Jan 2005
  18. pumagt500
    13 Jan 2005
    UPDATE 1-18-05
    The front before starting on the next update :D
    Closer view (i like closer views :D)
    The rocker switch I bought at the crapshack they only had one in stock so says the cashier
    and some solder
    The front after putting a generous amount of filler in the old button holes. How did the solder get in there.
    The painters tape and the pilot holes i drilled.
    Closer view of filler (first coat)
    The front after the holes have been drilled they still need to be filled and sanded.
    Closer
    Another view
    Closer
    Ill get some more pictures when the first coat drys and sanded. Expect the second coat ether tonight or tommorow and the front primed.
  19. zerocom
    13 Jan 2005
    already making some progress... good :dremel:
  20. pumagt500
    13 Jan 2005
    oops I forgot
    I forogt to take some pictures after i sanded the first coat of filler. Dam but I put on the second coat and pictures are gurunteed tommrow.
