Case Mod - In Progress Project: "Heavy Duty"
Discussion in 'Project Logs' started by makarov7, 9 Nov 2012.
  1. makarov7
    makarov7 What's a Dremel?
    9 Nov 2012
    Hi everyone,
    First let me introduce myself. My name is Nikolay and i am from Sofia / Bulgaria. This is my first post in this forum and right away i appologize for my not so good english :)
    So, let me introduce you to the project that i am working on for the last year. It is a low budget project, but i think it is not so bad. Hope you like it.
    Hardware:
    Case: Codegen ATX Server 9011/C11
    Mb: Asrock Z68 Extreme7 Gen3
    CPU: Intel I7 2600K
    Ram: Corsair Vengeance 8gb kit
    Gpu's: 2x GTX 460 1024mb + GTS 250 Physx (Temporary, hope so)
    PSU: Cooler Master Silent Pro M 1000W
    Fan controller: Kaze Q 4 channel
    HDD: Barracuda 7200 Sata II 500Gb (Temporary)
    SSD: ???????
    Watercooling: (All EK)
    CPU: EK-Supreme HF
    GPU's: EK-VGA Supreme HF (only gtx 460's)
    Pump: Ek-DCP 4.0
    Rads: EK-CoolStream XT 120
    EK-CoolStream XT 240
    EK-CoolStream XT 360
    Res.: EK-Multioption Res x2 150
    So, it's time for some pics:
  2. Cheapskate
    13 May 2007
    Welcome to Bit Tech.:D For a budget build, you have a lot of expensive parts.
  3. Razarach
    Razarach Minimodder
    28 Jan 2009
    Welcome!
    Nice project you have there ;)
  4. makarov7
    9 Nov 2012
    Thanks guys,
    Yes we can say that it is a mid-range budget project, but compare to other ones in this forum i think it's more like a low budget one. :)
    Now, let me post some progress pics for you.
    First i moded the top of the case to accommodate the 360 rad. Also fiiled in the existing hole with metal.
    Moded the rear panel for 120 rad. Normally there was a place for 2x80mm fans.
    Then i test fitted the rads again. No mounts for the 240 rad yet.
    Pics are taken by phone, so the quality is not the best :D
  5. krussellusaf
    krussellusaf What's a Dremel?
    28 Jun 2012
    I wish I could swing that on my budget :D Can't wait to see more. Subbed.
  6. makarov7
    9 Nov 2012
    As you can see, after mounting the radiators in, there was no room for power supply and hard drives, and then the real modding of the case began :dremel:
    First thing, it was necessary to visualise the order and placement of the components .....
    My plan was to extand the case by making a lower compartment for the rest of the components like PSU / HDD's / Pump ..... so i began the work right away :D
    No fancy materials used - only metal (cheaper)
    After adding the lower section it was time to cut the existing floor (i will explane why later :) )
    I know that the cut are a little sharp and edgy but the whole case will be sanded before paint.
  7. makarov7
    9 Nov 2012
    Front mouted rad in place....
    and i closed up the PSU opening.
  8. jay2
    jay2 Indonesian Modder
    3 Oct 2012
    a low budget with all EK...
    people have different math calculation or language definition of "low"perspective...
    welcome to bit-tech..
  9. timerhan
    timerhan What's a Dremel?
    6 Nov 2012
    WOW!!! It's a Russian car VAZ-2106 :D:D:D
    Nice)))
  10. Vetalar
    Vetalar *learning english*
    21 Jun 2011
    novadays is cheaper to get used (or even some of new) WB than made it "@home". raw materials, tools and spare time will cost much more in current situation. 10 (even 5) years ago factory WB were as available as a spaceship in my/nearby country. today couple keystrokes and clicks and one can get nice WB with no hassle to just find good piece of copper...
  11. makarov7
    9 Nov 2012
    Yes it is. We had many of them 15 years ago, but now they are very rare. This one will be transformed into a drift machine because of the RWD. It's a nice old Russian car ;)
    Ps. there are many bottles of vodka in the trunk - for better work progress and to worm up in the winter ..... :)
  12. timerhan
    6 Nov 2012
    :D
  13. makarov7
    9 Nov 2012
    Next step was to close the 5.25'' drive bay....
    .....and fabricate the floor plate for 2x120mm fans. The case will suck fresh air from the bottom compartment and from the 2x80mm situated on the back.
    till next time :D
  14. makarov7
    9 Nov 2012
    update...
    Making some holes for cable managment.
  15. Ragequit
    Ragequit What's a Dremel?
    26 Apr 2012
    Great start! Looks like its going to be quite rugged! Gotta say, love welding parts onto a pc case :)
  16. makarov7
    9 Nov 2012
    Originaly the case wasn't very strong - the materials used are very thin, but now with some welds it is sturdy enought.
    Let's continue with a litlle update. All the radiators will suck air from inside the case, so i needed a lote of fresh air from outside - decided to install two additional 120mm fans in the back side panel to bring air for the front rad. Don't like dust, so will keep positive air pressure.
    Closed the bottom.....
    ..... and start to fabricate the new panels.
  17. Sissilisko
    Sissilisko What's a Dremel?
    26 Apr 2012
    i really wait to see how it end's up, start looks rough, but it's different to the finishing product, i wish you a good luck :)
  18. makarov7
    9 Nov 2012
    PSU mouting bracket .....
    The power supply can be mounted only one way - with the fan pointing down. Like that the psu fan will not fight with the 2x120mm fans on the middle plate.
  19. krussellusaf
    28 Jun 2012
    I could be wrong but I think the top fan of the PSU sucks cold air in and the small fan in the back pushes hot air out. I assume those back 120mm fans are used to pull air out of the case so it seems like the PSU would just be helping in that cause. Please let me know if I am wrong.
  20. makarov7
    9 Nov 2012
    The PSU on the picture is only for test - i will use "Cooler Master Silent Pro M 1000W". The fans situated on the back of the case are 2x80mm not 120mm and they will bring fresh air to the case.
