Case Mod - In Progress Project: "Heavy Duty"
Discussion in 'Project Logs' started by makarov7, 9 Nov 2012.
  1. makarov7
    makarov7 What's a Dremel?
    9 Nov 2012
    Time for closing the case with some panels :)
    Front panel - vents for the rad (2x120mm) and intake (120mm) for the bottom compartment (just in front of the HDD cage). Also two USB 3.0
    Right side panels - intake for front rad.
  2. ghyupdc
    ghyupdc Banned
    28 Nov 2012
    Great start! Looks like its going to be quite rugged! Gotta say, love welding parts onto a pc case
  3. makarov7
    9 Nov 2012
    Update - modding the top panel.
    inside 80% ready.
  4. kelmannen
    kelmannen What's a Dremel?
    5 Feb 2011
    great metal working skill! love the way you build, it's just to bad i really don't like that kind of screws... =P
  5. makarov7
    9 Nov 2012
    Thanks :thumb:
    These bolts are only for testing - different bolts will be used after paint.
  6. makarov7
    9 Nov 2012
    Top panel ready.
    Big side window installed.
    Cover for the rear fans mounted.
  7. KrunchR
    KrunchR What's a Dremel?
    22 Apr 2008
    Built like a tank! This thing would survive a nuke! Nice job.
  8. makarov7
    9 Nov 2012
    Small update - coolant temp gauge installed and power / reset buttons.
    HDD cage and ventilation for the PSU.
  9. makarov7
    9 Nov 2012
    All the panels are ready :D
    Now it's time for sanding and painting.
  10. makarov7
    9 Nov 2012
    Update.....
    Next pics will be with the case painted :thumb:
  11. makarov7
    9 Nov 2012
    Preparation for painting.
    Primer applied
  12. makarov7
    9 Nov 2012
    Case painted. The colour of the paint is "metallic black" .
    Wheels mounted for easier movement of the case and airflow for the PSU.
    It is a lot better now with the paint, what do you think ?
  13. Altom
    Altom What's a Dremel?
    13 Dec 2012
    I really like this project a lot! I joined the forums just so I can sub to this thread and like 2 others (usually I just lurk the forums). I've been following since the beginning, can't wait to see what you will do with it :) The paint/sand job was awesome! Keep up the great work!
  14. makarov7
    9 Nov 2012
    Thanks :thumb:
    Next step is to apply some anti-noise/vibration material where needed.
    Next step will be installing hardware.
  15. makarov7
    9 Nov 2012
    Merry Christmas everyone.
    Seems to have been very good this year, because look what I found under the christmas tree. :D
    But first let continue with the assembly of the case.
    Mid-plate with acoustic absorption material.
    I forgot to make a cpu rear bracket opening for changing coolers without dismounting the motherboard, so ...... :dremel:
    First harware added to the case was the PSU.
    Next step will be mouting the motherboard and starting to assemble the watercooling .
  16. makarov7
    9 Nov 2012
    Happy New Year boys and girls :)
    Lets continue from where we left off.... motherboard intallation...
    Positioning the reservoir and rads.
    VGA in place. Now it's time to think about the tubing routing.
    The tube passing behind the 360 rad will not be visible after i install the fans.
  17. Altom
    13 Dec 2012
    Looking great so far! :) Looking forward to more!
  18. makarov7
    9 Nov 2012
    Update!
    I know that the tubing between the two gtx 460 is not right, but i run out of 90 degree compression fittings. So until the parts arrive .....
    The bottom compartment is a little messy, but it will be arranged later :)
    Tell me what you think so far :thumb:
  19. makarov7
    9 Nov 2012
    more pics ......
  20. kelmannen
    5 Feb 2011
    color does a lot with a piece of steel :)
    keep em' updates coming!
